twolz2rn
Putting Winglets On A 757
Sat May 27, 2006 3:51 am
How long does it usually take to put winglets on an aircraft? How much extra range does it add? If the airlines get winglets have they also had them ETOPS certified? Lastly, which US airlines have not put winglets on thier aircraft?
777STL
RE: Putting Winglets On A 757
Sat May 27, 2006 3:56 am
For the 757, it takes quite a while, ~21 days for AA on their recent modifications. Reason being, the 757 takes quite a bit of modification to the wings to accomodate the winglets, more so than an aircraft like the 737NG that was specifically designed for them.
AFAIK, AA and CO are the only US operators utilizing winglets. NW, US, UA, DL don't.
PHX based
kc135topboom
Sat May 27, 2006 3:59 am
The winglets on the B-757 or B-737 reduce drag by about 7%.
Quoting TwoLz2Rn (Thread starter):
Winglets would not effect ETOPS certification.
EMBQA
Sat May 27, 2006 5:40 am
Quoting KC135TopBoom (Reply 2):
Correct. 80% of ETOPS is manuals and procedures... only 20% has to do with the actual aircraft and even then it's mostly items the normal passenger would never see.
JRadier
Sat May 27, 2006 5:55 am
Quoting 777STL (Reply 1):
Not completely correct. Allthough all 737NG's (I believe, can someone confirm for -600 and -900 (non-ER) are built with winglet provisions, the first hundred-something (someone got the complete number) NG's we're build without it, and the wingletmodifications on that bird require quite some wing modification. On the newer aircraft it's basically snap-on.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
B6JFKH81
Sat May 27, 2006 6:23 am
I wish AA would PAINT the winglets. I was watching the AA 757 with the winglets come in the other day here at JFK, and it is this dull grey color just like the tail. I think they would look great if they were red or blue or had the AA red and blue stripe or something!
Seeing CO's 757 with the winglets, the blue looks really nice.
777STL
Sat May 27, 2006 12:52 pm
Quoting JRadier (Reply 4):
Split hairs much?
PHX based
JRadier
Sat May 27, 2006 4:49 pm
Quoting 777STL (Reply 6):
Split hairs much?
come again?
ba1978
Sat May 27, 2006 6:35 pm
Quoting B6JFKH81 (Reply 5):
They do paint them with the stripes, albeit very small!
Photo © Michael Carter
There are other ways and there's British Airways
