atlaaron
HP/US Into ATL
Sat May 27, 2006 8:09 am
My fiance recently flew from ATL-PHX on HP/US on a A320 and the flight was oversold. From some people I talked to in the gate area I guess it is like that a lot.
I'm a little surprised by that. Apparently HP/US may be doing as well as the press says. Or perhaps it is because there is no FL flying there.
Any thoughts?
jpetekyxmd80
RE: HP/US Into ATL
Sat May 27, 2006 8:13 am
It's a great route for them also because Southwest doesn't fly into ATL either. This is definitely a route they should do well on. The only experience I have with this was on the LAX-PHX segment with the flight continuing on to ATL. There was definitely a full load.
The Best Care in the Air, 1984-2009
SonOfACaptain
RE: HP/US Into ATL
Sat May 27, 2006 8:15 am
Quoting ATLAaron (Thread starter):
Umm, do you think the press is making this up?
-SOAC
Non Illegitimi Carborundum
atlaaron
RE: HP/US Into ATL
Sat May 27, 2006 8:28 am
Quoting SonOfACaptain (Reply 2):
Do you believe everything you hear or read in this industry? I certainly don't.
A330323X
RE: HP/US Into ATL
Sat May 27, 2006 8:36 am
PHX-ATL has been a successful and profitable route for HP.
They're also shortly adding a 5th daily roundtrip on the route.
I'm the expert on here on two things, neither of which I care about much anymore.
atlaaron
RE: HP/US Into ATL
Sat May 27, 2006 8:40 am
Quoting A330323X (Reply 4):
How about LAS-ATL for them? Same thing?
A330323X
RE: HP/US Into ATL
Sat May 27, 2006 8:58 am
Quoting ATLAaron (Reply 5):
No, LAS-ATL is a mediocre performer, nothing special.
Bridogger6
RE: HP/US Into ATL
Sat May 27, 2006 9:01 am
They actually has a fifth dailty flight for a couple of months, it was operating at a redeye out of Phoenix, leaving about 1115 or so... I can tell you, it was never even close to half full... so I am not sure why they're bringing it back, but apparently someone saw some good in it.
HPLASOps
RE: HP/US Into ATL
Sat May 27, 2006 9:04 am
Quoting A330323X (Reply 6):
Really? 611 is almost always full. I know full planes doesn't always translate into profitable flights, but people are flying us. We just recently converted one our morning PHX flights into a direct flight to ATL. Even 619, the night flight inbound is usually full. My impression is that ATL has been a flight we could bank on for success. I don't know how many frequences DL throws at Vegas, especially with one of them being a 767, that's gotta be tricky to compete against. FL also does a few flights too that we compete against.
[Edited 2006-05-27 02:06:09]
"Just because I know how to get off a freeway doesn't mean I know how to get back on!" - Retard Joe
SonOfACaptain
RE: HP/US Into ATL
Sat May 27, 2006 9:11 am
Quoting ATLAaron (Reply 3):
So are you saying US is still doing badly?
-SOAC
A330323X
RE: HP/US Into ATL
Sat May 27, 2006 9:16 am
Quoting HPLASOps (Reply 8):
Bingo.  Wink
I never said that HP didn't get a good load factor on LAS-ATL; it does. But the yields positively *suck*. Put the two together, and you get a mediocre flight. It's not awful, and it's not great.
iowaman
RE: HP/US Into ATL
Sat May 27, 2006 9:25 am
Quoting A330323X (Reply 10):
I wouldn't be surprised if yields "suck" on most HP routes out of LAS.
ATLFlyer323
RE: HP/US Into ATL
Sat May 27, 2006 9:37 am
Quoting SonOfACaptain (Reply 9):
Umm I do not believe he said that at all, he simply responded with a VERY logical answer. Please don't tell me you believe every single thing you read now do you? You could have been a little nicer and simply said yes what he was reading was in fact true, that US is doing better than before, and moved on.
Brandon
HPLASOps
RE: HP/US Into ATL
Quoting Iowaman (Reply 11):
Would the same hold true for WN?
atlaaron
RE: HP/US Into ATL
Sat May 27, 2006 9:53 am
Quoting ATLFlyer323 (Reply 12):
Thank you. Correct, of course I believe US is doing well/better. It was just a comment about the press.
iowaman
RE: HP/US Into ATL
Sat May 27, 2006 10:19 am
Quoting HPLASOps (Reply 13):
Most likely. But nothing is too low yield for WN.  Wink
HPLASOps
RE: HP/US Into ATL
Sat May 27, 2006 10:47 am
Quoting Iowaman (Reply 15):
Apparently ATL, JFK, EWR, LGA, SFO, and DFW are.
ca2ohHP
RE: HP/US Into ATL
Sat May 27, 2006 11:07 am
Actually in September the 17:15 flight to PHX is upgraded to a 757. ATL does really well to both PHX and LAS. There just isn't the aircraft available to dramatically increase service.
jpetekyxmd80
RE: HP/US Into ATL
Sat May 27, 2006 11:38 am
Quoting HPLASOps (Reply 16):
Low yield is not the reason they are not in those markets.
HPLASOps
RE: HP/US Into ATL
Sat May 27, 2006 11:45 am
Quoting JpetekYXMD80 (Reply 18):
Actually, yield is the closest thing the airline biz has to a bottom line - if you can't make money on a flight, then you shouldn't operate it. WN doesn't think it can make money on these flights overall, so they don't fly there.
iowaman
RE: HP/US Into ATL
Sat May 27, 2006 12:05 pm
Quoting HPLASOps (Reply 19):
Correct, however WN seems to charge around the same fares by distance in all their markets (excluding the new ones). When the loads aren't there is when WN doesn't make money.
jpetekyxmd80
RE: HP/US Into ATL
Sat May 27, 2006 12:12 pm
For the aforementioned airports, there are many individual factors that combine to show why WN hasn't started service there. No destination on that list would really classify as the common 'low yield' destination such as LAS (they certainly dont have a problem flying there).
For instance, WN pulled out of SFO in favor of OAK/SJC and one of the reasons was delays. As for the others, the main factor would be the competition and not the 'low yield destination'.
SonOfACaptain
RE: HP/US Into ATL
Sat May 27, 2006 1:08 pm
But it could be implied that way.
It first started with his remarks of...
From that I got the feeling that he didn't think US was doing to hot.
So I asked him this...
It was a simple question that related directly to his remarks.
He followed up with saying...
Which implied the he doesn't believe the press, and in return, doesn't think US is doing very well.
So with that being said, I asked him this...
Which goes along perfectly with all these quotes that have been said.
I personally don't feel my remarks where armful, and if you, or he, took offence to what I said, then well, I don't know what to say.
Quoting ATLAaron (Reply 14):
No it wasn't. It was directly related to the well-being of US.
-SOAC
ATLFlyer323
RE: HP/US Into ATL
Sat May 27, 2006 10:15 pm
Quoting SonOfACaptain (Reply 22):
Yes but notice his statement only says that they are doing good, maybe in fact he didn't think they were doing all that great.
Its a simple question with a kind of sarcastic reply, you sound like your talking to an idiot in which I'm sure hes not. Besides the way you handled that was kinda rude, you could have instead confirmed that US was doing good and to believe the stories he reads because Doug Parker is doing a great job at US.
It does not say that at all, he was not defending himself cause your replies have never answered his originally questions without badgering him a little. He never expressed that he thought US was doing badly just that he didn't know if the press was hyping up little success (because we all know the press NEVER hypes up anything, shoot they loved JetBlue til they didn't make money then they went all dooms day on them).
Well when I make armful remarks I usually apologize or at least give the person the satisfaction of answering there question tastefully.
So now your calling him a liar and putting words in his mouth? MAYBE he was just referring to the press, like he said.
~Brandon
srbmod
RE: HP/US Into ATL
Sun May 28, 2006 12:05 am
Between FL and DL, there are 10 regularly scheduled RTs on the route a day (DL does have some frequencies that aren't dailies). Of these 10 regular flights, only 4 of them are on widebodies (763s); FL's three flights are on 73Gs, and DL's other 3 flights are using 752s.
Just wait until the flights to Hawaii start. Flights to Las Vegas and Hawaii are among the most popular routes for frequent flyers to cash their miles in for, which is why for most airline employees, non-revving on those flights are practically impossible, as between the frequent flyer tickets and the general popularity of those places anyway (Both of my flights in the past to LAS from ATL have been full, and one of these was on Easter Sunday), open seats are few and far between.
