speedmarque
Will The 787 Landing Gear Need Redesign?
Sun May 28, 2006 7:03 pm
Hello,
Pics I have seen so far have shown the 787 to have an 8 wheel main gear set-up (4 on each bogey like a 767). My question is will this be enough to cope with the 787-10 length and weight considering a 773 and A346 has 12 main wheels?
Any ideas or has this already been taken care of at Boeing and I have just missed it!
Cheers, enjoy your Sunday!
zvezda
RE: Will The 787 Landing Gear Need Redesign?
Sun May 28, 2006 7:26 pm
The main gear on the B787 are good for MTOW up to about 540,000 to 560,000 lbs. Higher MTOWs will require the addition of a center two-wheel bogey slightly aft of the existing main gear. This is the same solution that Airbus applied to the A340-300 to increase the MTOW for the A340-500 and A340-600.
Rheinbote
Sun May 28, 2006 7:46 pm
Quoting Zvezda (Reply 1):
The adoption of 777-style six-wheel bogies appears more likely. In any case, quite a hassle as the current landing gear bay design probably can't pack a six-wheel bogie, so the rear bulkhead needs to be moved aft and the aft E/E bay with it.
zvezda
Sun May 28, 2006 8:31 pm
Quoting Rheinbote (Reply 2):
Why do you think so?
That is my understanding. It would be astonishing if it could.
Why do you think so? My understanding is that there is space just forward of the pressure bulkhead that would accomodate a two-wheel center bogey.
Adding two tyres would give the undercarriage all the capacity the wings have -- about 640,000 lbs. Being aft of the existing main gear, it would also help with rotation in the case of the longer variants.
dalecary
Sun May 28, 2006 8:44 pm
If the 787-10 stays at the same MTOW as the -9 no landing gear change will be required. However, if Boeing decide to go with a heavier, slightly bigger -10X, changes to the main landing gear will be required.
Rheinbote
Sun May 28, 2006 9:14 pm
Quoting Zvezda (Reply 3):
The current wheel bay and keel beam design doesn't suggest that to me.
SpeckSpot
Mon May 29, 2006 6:48 pm
So with an extra two wheel bogey in the middle, just slightly aft, does that mean that when it is rotating, for a split second it is going to be on only one bogey (th e middle one) which is the last to lift off? I mean, it is possible that the other two main bogeys will still have their rear set on the ground, but how much weight could they be bearing then? Intuitively it seems like the weight (whatever is left of it not being borne by the wings) will all be on that center bogey if it is aft of the other two, and it seems odd. Comments anyone?
zvezda
Mon May 29, 2006 6:57 pm
Quoting SpeckSpot (Reply 6):
Yes.
At any time the center bogey is the only one in contact with the ground, most of the aircraft's weight will be borne by the wings which will be generating a lot of lift.
astuteman
Mon May 29, 2006 7:17 pm
I put this forward without any specific knowledge of the point in case, Zvezda, but, taking technical feasibility as a given, I would imagine that 2 x 6 wheel bogies would be both lighter and simpler (therefore cheaper) than 3 x 4 wheel bogies.
But as I say, that's just me guessing  Smile.
Lumberton
Mon May 29, 2006 8:59 pm
Here's some info on the subject from an article in Aviation Week:
The larger wing will likely be the baseline for the 787-10, the stretch of the -9 now under consideration. The -10 is response to Emirates's interest in a 300-plus-seat aircraft with 787 technology. Boeing expects a formal launch decision in the next 12 months. But the -10's configuration, which is still far from being set, didn't drive the wing change, he insists. He notes that the -10 will keep the same MTOW as the -9 because of limits imposed by its four-wheel main landing gears.
Boeing Revises 787-9 Plan
"When all is said and done, more will be said than done".
Boeing Nut
Mon May 29, 2006 9:25 pm
Quoting Astuteman (Reply 8):
In this case, I believe that a center bogey will be incorporated. Reason - for a six wheeled bogey to be used would take a massive redesign of the fuselage/wingbox/gear stowage area. That would take big R&D bucks to do so. That is, if there is room to do this in the first place. If there's no room then the six wheelers are the only way to go.
But that's just me guessing as well!  wave
Oryx
Mon May 29, 2006 10:55 pm
Quoting Zvezda (Reply 7):
As far as I understand this, the rotation is initated by the deflection of the elevator. Its downward force ads to the weight of the plane. As the most rearward bogey is the rotation point, theoretically all forces act on the last bogey. The wings do only produce lift after the planes has already rotated somewhat.
zvezda
Tue May 30, 2006 12:11 am
There is no proposal for 3 x 4 wheel bogeys. Boeing are looking at adding a 2 wheel (not 4 wheel) center bogey. This is exactly the same solution that Airbus chose for the A340.
Quoting Oryx (Reply 11):
The gear are sprung. The center bogey would be only slightly aft of current main gear. During most of rotation, all ten wheels would be on the ground. Only during the final moments of rotation, when the wings have already taken most of the load, would only the center 2 wheels still be in contact with the ground.
Oryx
Tue May 30, 2006 12:19 am
Quoting Zvezda (Reply 12):
Yep, didn't think of it.
DfwRevolution
Tue May 30, 2006 12:46 am
As well as the DC-10 and MD-11, no?
Quoting Dalecary (Reply 4):
Now I know this is a simple matter of semantics, but when you say "bigger," I assume you mean heavier?
I was under the impression that given Boeing nomenclature the -10X and -10 were the same capacity, but the -10X had a higher MTOW and payload/range.
SpeckSpot
Tue May 30, 2006 1:27 am
Thanks for the answers, Zvezda and Oryx. Nice to know these things  Smile.
That means touchdown will also be on the single bogey for a split second. I believe it, but it just feels bizarre. There's something about touching down on
two bogeys that just feels right  Smile.
Speckspot.
speedmarque
Tue May 30, 2006 1:42 am
Thanks for your insights.
Speedy
Oryx
Tue May 30, 2006 8:12 pm
Quoting SpeckSpot (Reply 15):
Yes, but it will imediately contract like the shock absorbers in a car. So actually only the load of the internal springs are on the gears.
