b777a340fan
Smaller Airplanes, Longer Routes?
Wed May 31, 2006 1:15 am
Is it me or do airlines seem to employ smaller airplanes (B737s, B757s, A319s, etc.) for longer routes? Are we seeing a route diversification where airlines want to serve more destinations with smaller airplanes? Sort of boost direct flights?
B6JFKH81
RE: Smaller Airplanes, Longer Routes?
Wed May 31, 2006 2:23 am
Well, in the case of the LCC's, the theory is to have a single or limited fleet type and squeeze as many miles out of them as possible. And with the growing popularity of the LCC's, you are going to see that trend definitely. I think it is also an issue of not overflooding the various markets with ASMs.
superhub
Wed May 31, 2006 2:43 am
Quoting B777A340Fan (Thread starter):
Depends on which airlines you are talking about. In the US, there is a philosophy that routes should be served with smaller aircrafts but with higher frequencies. For example, instead of sending two B744 each day (assume US airlines still have them) from SFO-JFK, an airline would fly 4-5 B757/767 a day. And because there is not enough demand to send 5 B747 services, smaller planes are used.
Asian airlines, however, still tend to stick with larger aircrafts with low frequency of flights. However, there are still destinations which are served by large aircrafts with high frequencies (HKG-TPE is one..flights depart at least once an hour all with heavies) and there is also a trend to use smaller aircrafts but boost frequencies too. CX's HKG-LHR now have four daily flights, most of served by A340.
jetflyer
Wed May 31, 2006 2:46 am
Why put the same passengers on a widebody plane which burns a hell of a lot more fuel....
Modern narrowbody planes have a capability to fly longer routes so bying a load of them only to fly 3-400 miles routes would be a complete waste of money.
[Edited 2006-05-30 19:46:56]
krisyyz
Wed May 31, 2006 3:18 am
If a LCC or even a mainline airline can't fill a B767 or A330 on a long-haul route then logic would dictate that a smaller plane would be more cost effective. LCC as mentioned like fleet commonality, but this trend is growing on bigger airlines as well. Both CO and AA are using winglet-ed B752s on trans-atlantic ops, AC is apparently considering A319 YHX-LHR.
If planes like the B737ER catch on, then you'll see more narrow-bodies on transatlantic and long range flights.
KrisYYZ
B6JFKH81
Wed May 31, 2006 3:19 am
Quoting Superhub (Reply 2):
That is an excellent point. Here in the US, customers expect to see a choice of when they can go on their flight. They don't want to get up too early, or don't want to get in too late, or need to be at a business meeting first thing in the morning....they want the higher frequencies.
IAHFLYR
Wed May 31, 2006 3:58 am
Quoting KrisYYZ (Reply 4):
CO has been using B752's on trans Atlantic ops almost from day 1 of their delivery to CO back in the early to mid 90's, long before the winglets showed up.
I don't mind the single aisle planes so much on long runs but almost 4 hours in an RJ is a bit much such as the IAH-BOI flights.
TurkishWings
Wed May 31, 2006 4:19 am
TK flies 737-800s to places lile ALY, TAS, KHI . It might be economical as loads on these routes would not be high to fill a 310 or a 330 but let me tell you it is quite hard to work on these flights. 6 hours on a 737 is not fun man. Neither for the pax nor the crew.
On top of it, after 9/11, the crew did not stay at the destination until recently. So they did IST-KHI-IST. Uhhh it must have been painful  Wow!
Coffee - Tea or Me?
