1337Delta764
Any Mainline Delta Service In ATL Concourse D?
Wed Jun 07, 2006 2:38 am
The wikipedia article about Atlanta airport says that Delta has both mainline and Connection flights in Concourse D. However, when I was at ATL on June 1, I did not see any mainline aircraft in Concourse D. Does anyone know if there are still mainline Delta flights in Concourse D?
7e72004
RE: Any Mainline Delta Service In ATL Concourse D?
Wed Jun 07, 2006 2:39 am
I saw a DL MD-88 parked on the D concourse when i flew through there in December.
The next generation of aircraft is just around the corner!
ATLFlyer323
Wed Jun 07, 2006 3:36 am
Quoting 1337Delta764 (Thread starter):
Yes they do operate mainline in D, the only concourse that doesn't see Delta Mainline is Concourse C. Concourse C handles Delta Express/Connection and AirTran.
~Brandon
[Edited 2006-06-06 20:37:15]
deltairlines
Wed Jun 07, 2006 4:11 am
Delta mainline has basically left Concourse D - it seems like all of Comair, ASA's ATRs, some Chautauqua (not the ones using B19/B20) and some ASA RJs use D. I haven't seen a Delta mainline bird over on D since November - in my about 10-15 trips through ATL since then, it's been all Delta Connection.
Jeff
litz
Wed Jun 07, 2006 5:09 am
They use one of the gates way out on the end, on the corner (like D33 or something like that) for occasional overflow. The jetways are usually rolled up against the walls, to allow for the little jets to pull up, as they deplane to the tarmac. I don't think they can reasonably pull anything bigger than an MD88/90, or a 737 in there, though.
- litz
