Saleem
Flying From La Carolina - Ecuador
Wed Jun 07, 2006 12:39 pm
In the Flight Simulator, I found runway "La Carolina" Ecuador. It looks very difficult to land and take off from that runway. Is that runway under use, which aircrafts, commercial etc.
Needs further information on this runway
I read a thread long ago where a list was provided like these runways, in the valleys, mountains etc. probably that runway was also included in that list
airportmanager
RE: Flying From La Carolina - Ecuador
Wed Jun 07, 2006 2:08 pm
Give the ICAO code for it. Example SEQU= Quito, SEGU= Guayaquil ????=La carolina?
Saleem
Wed Jun 07, 2006 3:46 pm
The code is Z09D, City is La Carolina
airportmanager
Thu Jun 08, 2006 4:54 am
Z09D? Ecuadors ICAO codes are SE??, never seen any with Z.... So there msut be somethign wrong, of course i can be msitaken, but im pretty sure being it "Z" codedm its not ecuadorian
Saleem
Thu Jun 08, 2006 12:03 pm
Yes, most of the Airports of Ecuador started with SE, but in Flight Simulator 2002 there are lot of runways which starts Z09*, like Z09E for Banasur, Z09D for La Carolina, Z09L for La Judy South, Z09F for La Mina, Z09G for La Puntilla, Z09J for Patuca and Z09H for Puerto Villamil.
So may be it helps you
OB1504
Thu Jun 08, 2006 12:18 pm
That probably means it's not even open to commercial use. Some airports in FS have scenery problems, like the ones thousands of feet above the surrounding terrain or others in a deep pit, so that could explain things.
Saleem
Thu Jun 08, 2006 12:20 pm
One important point regarding these runways that most of these locations are relatively lower than the near ground, like a valley, but valley is within mountains these are big round dip in the ground. Right at this time I am not finding good words to explain
cptGirmayTesfa
Thu Jun 08, 2006 12:36 pm
No scenery problems in this case. Fairly long runway. Maybe something military.
