1337Delta764
Flagship Aircraft
Sat Jun 10, 2006 1:09 am
With the thread about flagship routes, we should also discuss about flagship aircraft. While some would say that flagship aircraft means largest aircraft, I don't think that is always true. For example, I do think that United considers the 777, rather than the 747, to be their flagship aircraft.
What I am pretty sure about is Delta. The 777-200ER is the flagship aircraft for international flights, while the 767-400ER is Delta's domestic flagship.
starguy
RE: Flagship Aircraft
Sat Jun 10, 2006 1:19 am
At VS the A346 is the GUCCI aircraft. Although many of the crew don't actually like working on it, it has a much more glitzy cabin.
GVWOW
Sat Jun 10, 2006 1:30 am
Even though the A346 is LH's largest aircraft, the A330 is the only one that has PTVs. I'm not sure if LH advertises it as "their flagship" though. But LX does state that the A340 is their "flagship".
FlyDeltaJets
Sat Jun 10, 2006 1:59 am
Quoting 1337Delta764 (Thread starter):
I would think that flagship a/c would be the 763 being that most intl routes are flown with that plane. 777 only flies a few of Delta's many routes.
The only valid opinions are those based in facts
UAL747
Sat Jun 10, 2006 2:03 am
Quoting GVWOW (Reply 2):
Correct me if I'm wrong, but the 747-400 is LH's largest aircraft.
UAL
KL565
Sat Jun 10, 2006 2:08 am
Would Have to say that that EK's flagship is the A340-500 they use on their DXB-JFK routes. That being said SQ'S would be the same, the a/c as they primarily fly it on their flagship routes SIN-LAX/EWR. But am assuming that when the A380 joins their respective fleets, things will change
shamrock350
Sat Jun 10, 2006 2:12 am
I would think that Aer Lingus' A330-300 is their flagship aircraft. They also have a large A320 fleet of 21 aircraft (3 on order) and is used on most of their routes so that could also be the flagship for EI.
KL565
Sat Jun 10, 2006 2:16 am
KLM's would be the 777-200ER...Would expect that one after they converted their orders to the 777W.
BBJII
Sat Jun 10, 2006 2:18 am
CB D328
VG F50
BA 747
KL 777 ??
Remember: The Bird Hit You, You Didn't Hit The Bird.....
1337Delta764
Sat Jun 10, 2006 2:22 am
Quoting FlyDeltaJets (Reply 3):
Delta has put more features on the 777 in economy class than on the 767-300ER, including PTVs and EmPower. Even the 767-400ERs have EmPower in economy. However, there is soon the possiblity that all aircraft except for the MD-88 and MD-90 will get PTVs, and that includes the 767-400ER (both domestic and international) and possibly the 767-300ER. IMO Delta should install EmPower fleet-wide.
boeingfever777
Sat Jun 10, 2006 2:29 am
I would say that at QF it's Wanula Dreaming and at CO it's Peter Max.
Faire du ciel le plus bel endroit de la terre.
spartanmjf
Sat Jun 10, 2006 2:33 am
Oh to the days of Clipper America and the 747 FriendShip......
"Nuts to the man in 21D!"
daron4000
Sat Jun 10, 2006 2:38 am
While the 777 is newer, I believe that Tilton has called the 747 UA's workhorse and that might make it more flagship. Nevertheless, I'm happy to be on both.
As for BA, I'd say 747 over 777 and SQ, I'd also say 747 over A340.
MaartenV
Sat Jun 10, 2006 2:41 am
Quoting KL565 (Reply 7):
Why not the 747?
Its all about supply and demand...
727tiger
Sat Jun 10, 2006 2:48 am
NW = DC-9
C'mon; someone had to say it.
David L
Sat Jun 10, 2006 3:44 am
Quoting 727Tiger (Reply 14):
NW = DC-9
That's a  redflag ship.
KL565
Sat Jun 10, 2006 4:42 am
Quoting MaartenV (Reply 13):
Why not the 747?
KLM is phasing out it's 747's..That is why they are gradually being phased out on some routes and being replaced by the 777-200ER. Further evidence can be found in that they converted their orders for the 777-300ER, to replace the 747's.
1337Delta764
Sat Jun 10, 2006 4:44 am
Quoting KL565 (Reply 16):
Before Delta got their 777-200ERs and 767-400ERs, I do believe that Delta considered the L-1011 to be their flagship aircraft. I don't think Delta has ever considered the MD-11 to be their flagship.
KL565
Sat Jun 10, 2006 4:55 am
Quoting 1337Delta764 (Reply 17):
So what are you saying....?
1337Delta764
Sat Jun 10, 2006 5:01 am
Quoting KL565 (Reply 18):
Many have considered Delta's purchase of the MD-11 to be a huge mistake, due to the fact that the MD-11 did not meet promised performance. Delta then decided to go with the 777 instead.
UAL777UK
Sat Jun 10, 2006 5:06 am
As i started the thread on Flagship Routes I must have my  twocents , I disagree about UA, I think you will find they consider they 747 is their flagship, as does BA, LH etc.
KL565
Sat Jun 10, 2006 5:25 am
Quoting 1337Delta764 (Reply 19):
I will agree to that...What do you think is KLM's flagship aircraft.
AirEMS
Sat Jun 10, 2006 5:41 am
NW = DC-9
On the same thought....
I'm guessing Southwest is the 737?  duck
Frontier is the A319?  hyper
Fly & Work Safe
-Carl
If Your Dying Were Flying
AlexPorter
Sat Jun 10, 2006 5:55 am
NW's is probably the 744, but the A330 can also compete, but it has no service at NW's home airport in MSP, so I'd say no. Domestically I'd say it's the 753, since it links to the largest markets for NW - intrahub, MKE, BOS, LAX, MCO, SEA.
For US it's definitely the A330.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
yowza
Sat Jun 10, 2006 6:16 am
I would say KL and the MD11 go hand in hand.
I still think of UL and their tristars even though they are long gone.
YOWza
KL565
Sat Jun 10, 2006 6:26 am
Quoting AlexPorter (Reply 23):
The last I checked the A330 flies MSP-AMS....
MaartenV
Sat Jun 10, 2006 6:52 am
They have phased out their 742s and 743s. No 744 has left, they are even refurbishing them at this moment.
Neither is there any evidence that the 773ERs will replace 744s, instead of being used for expansion.
Quoting YOWza (Reply 24):
They go hand in hand, but they are definetaly not the flagship, KLM is putting them more and more on low yield destinations.
UAL747
Sat Jun 10, 2006 7:02 am
While AA's largest plane is the 777-223ER, I think they determine "Flagship" by route length. I can't say for sure, but I think catering for AA puts "International Flagship Service" on all their menus no matter what type of plane you are on.
UAL
MaartenV
Sat Jun 10, 2006 7:07 am
Quoting Ual747 (Reply 27):
While I agree with you on the fact that the 772 is Americans flagship, I have to disagree with your claim that the 772 is largest plane, at least not in seatnumbers, since their A300s can hold more passengers then their 772s.
GVWOW
Sat Jun 10, 2006 7:13 am
Quoting UAL747 (Reply 4):
lol woops, I meant to write "newest"!  Smile. shame, shame.
UAL747
Sat Jun 10, 2006 7:14 am
The 777 is the largest plane in sheer weight, cargo/pax volume, and "possible" seating capacity.
Besides, comparing the A300 to the 777 is like comparing a 1982 Chrysler La Baron to a 2006 Ferrari. The A300 is hardly worth mentioning as a flagship plane..although, AA used to send quite a few over the Atlantic from BOS and JFK to LHR. Lord, I wouldn't want to be on one when I could be on a 777. Thank goodness they don't fly them on European routes anymore. Just Latin American...(And not very far south at that).
UAL
stylo777
Sat Jun 10, 2006 7:31 am
TK...
Their good old A340's or their new A330's??? Or their countless B737-800's???
I would say its the new A330!
For LH in my opinion its definitly the B744.
Ori
AirEMS
Sat Jun 10, 2006 3:47 pm
Quoting BoeingFever777 (Reply 10):
CO it's Peter Max
Ick! I would say the 777 in regular c/s  crazy
IMHO the Peter Max AC is the flagship of a very long A.net post  duck
What about AF? 340, 747, 777 which one would it be?
Fly & Work Safe
-Carl
md90fan
Sat Jun 10, 2006 4:51 pm
MSP
This summer they are flying MSP-HNL IIRC.
But KLM is making the MD-11 more and more of an holiday plane.
Best Regards,
MD90fan  wave
http://www.devanwells.blogspot.com/
SFO2SVO
Sat Jun 10, 2006 6:13 pm
Would it be IL-96 for SU?
318-19-20-21 332 343 717 727 737-234578 743-4 752 763 772 D9/10 M11/8x/90 F70 RJ85 ATR72 SF340 E120 TU34/54 IL18/62/86/9
ZK-NBT
Sat Jun 10, 2006 8:27 pm
For NZ i'd say it's still the 744 over the new 772ER's!
ZK-NBT used to appear in alot of ads and on post cards.
Qantas744er
Sat Jun 10, 2006 8:50 pm
Not really an airlinebut for the Dubai Air Wing
they have 2 744`s plus 747 Sp`s BBJ`s etc
Cheers Leo
You live and you die, by the FMA
BBJII
Sat Jun 10, 2006 9:11 pm
CargoLux is the 747F
FR 738
U2 319
jorge1812
Sat Jun 10, 2006 9:37 pm
Don't want to go on another discussion about LH and PTV's but AFAIK the only two A-330's with PTV were leased and already left the fleet.
Georg
rmcf
Sat Jun 10, 2006 9:43 pm
For Iberia:
A346 international
A320 for short-medium haul
What about Air France? I would say B773 or B747?
bye! rmcf
jbguller
Sat Jun 10, 2006 9:55 pm
Now, correct me if I'm wrong, but I think Virgin Blue's flagship is the 737... anyone disagree? Big grin
AF773
Sat Jun 10, 2006 10:47 pm
Af?
I'd say it has got to be the 777, both versions combined...
Next flights: DCA-ATL-PNS; DCA-LGA-ORD; DCA-JFK-HAV-ATL-DCA; DCA-JFK-ORY-TLN; ORY-JTR; AMS-IAD; DCA-LAX-SFO-MSP-DCA; IAD-CDG-AMS-IAD
B4REAL
Sat Jun 10, 2006 11:10 pm
I disagree with that for DL.
Int'l 763-ER is the flagship and the workhorse of the Int'l fleet, no question.
Domestically, the CRJ (hah!, okay, I'm ducking now for the nasty comments).
What is the criteria for flagship? I think the definition depends on your perspective, if you say to yourself (re International travel), I'm going to another continent .......... picture yourself on the plane .............. Quick, what's the type - for DL, it would have to be a 763-ER.
Domestically, really a blur. If you base your thoughts on ATL, I'd put the 763D as the workhorse and flagship, though that is changing of recent times. There are a lot of MD-88s, 757s, and 738s for DL hauling a lot of mass. If you see CVG more than ATL, then yes, you'd say CRJ.
If you define a flagship another way, you'll perceive it differently. Some may champion the flagship as the aircraft where all passenger services are available, or simply the newest aircraft, or simply largest seating a/c... This is truly arbitrary.
westindian425
Sun Jun 11, 2006 12:31 am
B6 - A320
JM - A340
BW - A340 (wish it were still the L15)
TAM - A330
NK - A321?
AC - 744?
HA - 767
Air Tahiti Nui - A340
Kuwait - A340
LOT - 767
LAN - A340?
SAA - 744 or A345?
Royal Jordanian - A340 (L15 would have been good for this one too)
LY - 744 or 777?
Finnair - MD11?
Austrian - A340
That's all I can think of for now. Correct me if I'm wrong.
Neil
God did not create aircraft pilots to be on the ground
GBOAE
Sun Jun 11, 2006 12:41 am
A few years ago and it would have been Concorde for both BA and AF
Now a days i think it has to be the 744 for BA.
GBOAE
1337Delta764
Sun Jun 11, 2006 12:43 am
I would say for WN the flagship is the 737-700.
dw747400
Sun Jun 11, 2006 1:15 am
Quoting 1337Delta764 (Reply 45):
Flagship doesn't get much more literal than this:
Photo © James Rowson
[Edited 2006-06-10 18:17:49]
[Edited 2006-06-10 18:18:51]
CFI--Certfied Freakin Idiot
rikkus67
Sun Jun 11, 2006 1:28 am
Neil...
AC is, for now, the A340-500. The 3 747-400 were retired a couple years ago, and I do believe at least one might be part of the 787 support program for Boeing (with enlarged cargo area).
When the 777's come online next year, they will replace the A340-500's.
Rik
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
Concorde001
Sun Jun 11, 2006 1:51 am
Quoting GBOAE (Reply 44):
Correct! I love this BA video about Concorde as their flagship...enjoy!
Great video, don't you think?
westindian425
Sun Jun 11, 2006 3:43 am
Quoting Rikkus67 (Reply 47):
Neil...
Rik
Thanks, Rik. I stand Corrected.
I'll add one more:
AeroMexico - 777.
Neil
