tcfc424
US And HP Fleets
Wed Jun 14, 2006 12:47 pm
I apologize if this has been discussed ad nauseum here since the merger of HP and AWA, however I did try searching but could not find anything regarding this, and after passing AUS today for the first time in a while, it sparked my interest.
Have HP and US integrated their fleets regarding city pairs, routing, etc or have they primarily maintained the structures pre-merger?
Perhaps to clarify, would it be unusual to see a US aircraft parked at AUS, whereas pre-merger the only service was from HP? I only noticed HP aircraft today, but I was driving, so I had to watch the road somewhat...of course being able to see the aircraft at the terminal while on 183 is quite tempting...
Any info would be appreciated, and flames will be directed to the complaint department at 1-800-***-**** promptly. (haha)
Mike S. in AUS
HPRamper
RE: US And HP Fleets
Wed Jun 14, 2006 12:49 pm
For the most part, the routes have stayed separate, but there are some selected routes that have gone from HP to US and vice versa.
atrude777
Wed Jun 14, 2006 12:50 pm
In STL US Airways and America West have completely merged, everything is all US Airwasy except the ATC sign on the arrival and departures I think.
AWA and US Airways aircrafts over lap their routes at STL.
Alex
m180up
Wed Jun 14, 2006 12:52 pm
the certificates are still separate, so you wont see a US airplane operating a HP route yet or the other way around, until the certificates are merged it will be possible
Werner from SAL
MCOflyer
Wed Jun 14, 2006 12:54 pm
Heres what I know about the A/C sitution.
The 767's will get new interior's and will stay. Heard a rumor AVIOD will be installed.
US will buy any used ETOPS 757 w/ RR engines
The 737's will recieve new paint jobs
A330's will be delivered in 2008
I've seen HP aircraft in ORF, CLT, and PHL. So yes the transition has began. A US pilot told me a 737 is in new c/s. Can anyone confirm? I know once the 333's go in for m/x, they will recieve it.
MCOflyer
MCOflyer
Wed Jun 14, 2006 12:56 pm
Same for MCO. I meant to say US is looking for more used 757's with ETOPS. The crews really like them.
MCOflyer
AlexPorter
Wed Jun 14, 2006 1:02 pm
HP is operating PDX-PHL now.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
HAL
Wed Jun 14, 2006 3:09 pm
There were a few switches in the routes for the sake of efficiency, i.e. LAS-MIA going to US, while HP picked up a daily PHL-SEA and PHL-PDX. But except for some senior management positions, they are completely separate airlines, and will remain so until there is a combined seniority list and contract for the pilots, and the FAA signs off on the combined certificate. That means the FAA has to agree to a new training program for pilots & F/A's, manuals, procedures, and everything else that will make two airlines into one. It is impossible (and illegal) for a US pilot to fly an HP plane or HP pilot to fly a US plane (or route either). You may see one of the HP planes in AUS that is painted in the new US colors, but until the airlines merge under one operating certificate next year, it won't be a US plane or crew.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
N1120A
Wed Jun 14, 2006 3:12 pm
Quoting Atrude777 (Reply 2):
The ATC sign for the combined airline is going to be Cactus.
Quoting MCOflyer (Reply 4):
Avoid what?  Silly I think you meant AVOD
HPLASOps
Wed Jun 14, 2006 3:52 pm
Quoting HAL (Reply 7):
Currently, LAS-FLL, PHX-MIA, LAS-MIA and LAS-RDU are being flown on east metal.
I believe March of 07 is the target date for full integration and certificate merging.
"Just because I know how to get off a freeway doesn't mean I know how to get back on!" - Retard Joe
A330323X
Thu Jun 15, 2006 10:25 am
Quoting M180up (Reply 3):
You will and do indeed see plenty of US airplanes operating routes in the "traditional" HP system and vice versa. They have scheduled a number of such instances, to improve utilization. They have also covered for each other a number of times on an unscheduled basis, when one airline has a spare available, and the other airline has a cancellation or needs an extra section.
What you won't see are US crew operating HP planes, or vice versa.
There's nothing at all stopping them from scheduling (or using on an unscheduled basis) US crew *and* US metal on PHX/LAS-AUS.
All that matters is that the crews and the airplanes are on the same certificate. The routes are completely irrelevant. (Aside from a few international routes for which only one carrier has operating authority, but even there they have nearly all their authorities aligned, except a very few instances where prohibited by bilateral.)
I'm the expert on here on two things, neither of which I care about much anymore.
ca2ohHP
Thu Jun 15, 2006 12:41 pm
That was the original plan, but because of much higher than estimated maintenance costs, retirement will be moved up significantly. US is currently in preliminary talks with Airbus and Boeing on a replacement for the 733's and 734's.
FCYTravis
Thu Jun 15, 2006 4:34 pm
Quoting A330323X (Reply 10):
Wouldn't the lack of SABRE-connected legacy-US terminals at AUS hinder the operation of the flight, because the computer systems are still separate? I know at PHX the US aircraft only use a few specific gates at the end of the low-B concourse that have been outfitted with US East SABRE computers, because they have to have access to US East systems.
USAir A321 service now departing for SFO with fuel stops in CAK, COS and RNO. Enjoy your flight.
HAL
Thu Jun 15, 2006 4:37 pm
Actually not. According to the transition agreement between the company and the pilots, they can not have one carrier fly the other carrier's routes. AWA had a problem with aircraft availability one day last year on the PHX-LAX route and put a US plane & crew on it. You'd think the world had ended by the ruckus put up by the AWA pilots. The company agreed that they'd erred, and haven't done it again. It's a matter of protecting what you already have, and not letting management step all over you. Some may see it as petty, but given all that management has done to the AWA pilot group over the years, they needed that protection.
HAL
m180up
Fri Jun 16, 2006 2:14 am
sorry, this is what i was trying to say, guess my words weren't so clear, they are already operating some od the routes of the other airline, but I was trying to mean a US metal operating a flight scheduled as HP, or HP crew operating a US flight
Werner from SAL
USAir734
Fri Jun 16, 2006 4:30 am
It is happening, here in ALB we've had some HP CRJ's operating flights to Phillie
pgtravel
Fri Jun 16, 2006 5:39 am
Quoting USAir734 (Reply 15):
That's not an HP CRJ. That's a YV CRJ in HP colors. YV was a partner with both HP and the old US, so they can swap aircraft around their system however they want to.
USAir734
Fri Jun 16, 2006 5:53 am
Quoting Pgtravel (Reply 16):
well, needless to say, we didn't get them prior to the merger
AirframeAS
Fri Jun 16, 2006 6:55 am
Dude, quit listening to those people!
Quoting Ca2ohHP (Reply 11):
Get the 73G & 738, US!!! C'mon!!!
A330323X
Fri Jun 16, 2006 7:13 am
Quoting HAL (Reply 13):
Then please explain to me how they've gotten away with scheduling and flying such routes as PHX-BOS/CUN/ORD/SEA, LAS-FLL/MIA/RDU/TPA, PHL-PDX/SEA, all with the "wrong" carrier's equipment and crews.
Here is the ALPA transition agreement, as I've posted a dozen times before. Please show to me the language that prohibits one carrier from flying the other carriers routes. (Hint: it's not in there.)
There is language that limits flying the other airline's routes to Hawaii/Europe/Caribbean, but nothing that limits domestic flying. Even the international flying is merely limited, and not prohibited; US will soon be flying PHX-CUN with US metal and US crews.
Actually, it was the flight attendants who freaked out--and they were wrong.
No. The company did say they wouldn't do it again, but they did not agree that they were in error, since they were not. The company pay-protected the affected HP crews, which was all they needed to do per the HP-AFA contract. Just because the HP AFA MEC filed a grievance does not mean that the grievance was sustained.
And since the AFA reached their transitional agreement, the company has indeed used one airline's aircraft to fly extra sections on the other airline's routes, though I'm not sure if they've covered for cancellations.
HAL
Fri Jun 16, 2006 2:10 pm
OK, I erred in saying "routes". I meant "flights". If AWA is scheduled for flight 539 LAS-CLE but has a mechanical, the airline can't put US metal on the flight and run it. That is what they did in the PHX-LAX example, and that is what got the pilots so upset (yes, the pilots - I was one of them at the time, so don't lecture me on what happened).
HAL
A330323X
Fri Jun 16, 2006 3:04 pm
Quoting HAL (Reply 20):
Yes, they can. Just because the HP employees complained doesn't mean they were right. US/HP pay-protected the affected crews, and that's all that was necessary. (Last year, when a deicing boom fell on a US A330 in PHL, US wet-leased a First Choice 763 to fly PHL-LGW for a few days. What happened here was even less controversial than that, as the HP code was never placed on these flights.)
From the HP ALPA contract, there are two relevant sections. If you can find something in the contract that says otherwise, please point it out.
The first relevant section is on scope:
The Company may only engage in Subcontracted Revenue Flying under the
following circumstances: Subcontracted Revenue Flying may be engaged in
for a period not in excess of ninety (90) days per occurrence during the term
of this Agreement when (i) such Subcontracted Revenue Flying is necessary
to accomplish the needs of the service of the Company, and (ii) the Company
determines that it does not have sufficient or appropriate aircraft, or sufficient
or appropriately trained Pilots, available to perform the Subcontracted
Revenue Flying, and (iii) the Company does not furlough any Pilot as a direct
result of such engagement in Subcontracted Revenue Flying. Provided,
however, said ninety (90) day period may be extended by mutual agreement
of the parties. It is understood and agreed that nothing in this Subsection
1.D.1.b. will prevent the Company from furloughing Pilots for economic
reasons independent of or unrelated to its engagement in Subcontracted
Revenue Flying.
That section isn't even technically relevant to what happened then, as HP did not place its code on the US flights. The US flights were run as US extra sections, and HP merely signed its tickets over to US, as if it were rebooking its pax on any other airline. But even had HP placed its code on the flights and wet-leased the planes from US, it would have been allowed under this section.
The other relevant section is on scheduling:
A lineholder who is rescheduled or rerouted shall receive pay and credit for
the actual pairing flown or the originally scheduled pairing, whichever is
greater.
HP did indeed pay-protect the affected crews without argument.
There were about 7 flights that US operated that day. PHX-DCA/LAX/PHL/PIT if I recall.
The pilots merely complained; the flight attendants filed a grievance. (I'd bet that the reason the pilots didn't grieve it is because they knew there was nothing to grieve.)
oakjam
Sat Jun 17, 2006 1:58 am
At OAK the newly painted HP aircraft have the US Airways NC as I flew out of there 1 month ago. There I saw the new US airways colors on a flight to PHX. I wonder if they have the new colors on aircraft to Los Cabos and Las Vegas?
HAL
Tue Jun 20, 2006 11:03 am
A330323X,
The point I was trying to make was that it was the transition agreement, not the ALPA contract that the company was abusing. Here is an excerpt from a recent letter from the HP union to the pilots. It explains the problem better than I have:
SYNERGIES: “WHAT THE TA ALLOWS”
In a recent issue of “About US” the company presented an article on synergies being implemented this summer. The main point made was that the company is shifting East flying onto routes traditionally flown by the West side system. Management continues with the assertion that this adjustment to the schedule provides opportunity to the West side system to re-enter and develop new markets. We have heard your concern about the announced flying and are all concerned with ensuring our contractual rights are protected.
What are the facts? The fact is that the Transition Agreement language protects only “known and announced” flying between points west of the Mississippi to Hawaii and east of the Mississippi to European and Caribbean destinations. The language cannot be interpreted otherwise as the intent of the negotiators was to only protect this high-value flying and allow for the Company to get a “taste” of potential synergies to be attained after the integration is completed.
What your MEC sees as a violation of the TA are the repeated attempts by the company to replace East or West side aircraft and crews on flying currently scheduled on the HP or US code. A dispute under the TA exists on these continued attempts by the company to interchange flights when circumstances arise and we are currently in the process of selecting an arbitrator to hear this issue. The West side operation recently attempted just such a substitution with a proposed Phoenix-Charlotte flight in lieu of the regularly scheduled US flight. The captain on this flight rightly refused the assignment and your Reps will vigorously defend this pilot should the company decide to pursue the issue. Meanwhile, if you are asked to operate any flight which you know to be a substitute flight for a known US scheduled revenue flight you should contact the Duty Officer and ALPA representation. It is ALPA’s view that these flights are extra-contractual and until a satisfactory resolution is reached between all parties we must defend this position aggressively. Your Representative will advise you of your contractual rights. If you are unable to contact your ALPA Rep before the flight is scheduled to depart, fly the assignment provided it meets all FAA, Company and contractual parameters ( i.e. flight is to an approved America West regularly scheduled destination etc.)
HAL
PVD757
Tue Jun 20, 2006 10:37 pm
I clearly heard a US management type say that HP cannot operate into cities that were previously US (east) only stations due to the reservations systems not being compatible yet - not so much so due to the labor agreements.
