MastaHanky
Concorde Flight Paths Across The Atlantic.
Mon Jun 19, 2006 1:30 am
I hope this isn't a silly question, but I've been curious about it for a while.
I was wondering if the Concorde had to take a different flight path across the Atlantic versus the paths that traditional jets take.
The cruise altitude of the Concorde was about 60k feet. Is that sufficient seperation to prevent wake turbulance for an aircraft flying at 40k feet? Did the FAA/CAA/whatever body governs TATL flights have different seperation requirements for the Concorde? How would an aircraft flying at supersonic speeds affect other aircraft in the area?
fbgdavidson
RE: Concorde Flight Paths Across The Atlantic.
Mon Jun 19, 2006 1:37 am
Quoting MastaHanky (Thread starter):
I believe they did. Somewhere at my home in Britain I've got Concorde High Altitude Jeppesens from a flight in 1996.
Photo number 5 on an album of souvenirs had a 'Point of No Return Map' which you may be able to decipher.
Next time I return home I may take some photos of the Jeppesen for you, although I believe Christopher Orlebar's 'The Concorde Story' has some scans of the Jeppesens in the front and back covers so I think someone may beat me to it.
LAXintl
Mon Jun 19, 2006 1:58 am
The Concorde had its own route structure across the Atlantic. If I remember there was 6 (3 west, 3 east) fixed routes. They were plotted primarily to reduce the affects of sonic boom on land.
Regarding ATC procedures the only real difference I am aware of was the Concorde was often given somewhat prioritized handling in terminal areas due to its high speed requirements and inability to comply with standard speed/altitited crossing requirements(remember it had no real flaps). On departure for instance it was also standard for the Concorde to exceed 250kts below 10,000ft.
Dont recall any special wake turbulence procedures.
B2707SST
Mon Jun 19, 2006 3:58 am
According to Concorde FO Christopher Orlebar's The Concorde Story, there were three fixed supersonic tracks: SM (westbound), SN (eastbound), and SO (not used in scheduled service). SM is the most northerly and is approximately the shortest great-circle route that avoids placing a boom on Canada or Ireland. SM, SN, and SO had about one degree of latitude in lateral separation.
On the other hand, the seven subsonic transatlantic tracks are not fixed; they are recomputed every day based on wind patterns. Head- and tailwinds had a much smaller effect on Concorde due to its high cruising speed, so it was not worthwhile to vary the supersonic tracks.
Here is a scan from The Concorde Story showing the SM track and the subsonic tracks on one particular day. Diversion airports are also shown.
Wake turbulence was not an issue. Even if the subsonic and supersonic tracks happened to coincide on a given day, vertical separation between Concorde and other aircraft generally would have been 15-20,000 feet. Much heavier subsonic aircraft routinely fly with just 1,000 feet of vertical separation on the subsonic tracks.
Concorde's unique delta vortices also dissipated much more quickly than the wingtip vortices left by other aircraft, so I doubt wake turbulence was a problem at takeoff and landing.
--B2707SST
Keynes is dead and we are living in his long run.
vc10
Mon Jun 19, 2006 4:17 am
The reason that winds were of little significance to the N Atlantic Concorde operation was because at the heights that Concorde operated the winds were normally very light usually only something like 10 - 20 kts.
little vc10
