PRAirbus
AA 777 JFK-EZE-JFK Soon!
Fri Jun 30, 2006 4:35 am
According to internal AA news, JFK-EZE-JFK will be upgraded soon to 777 using the equipment coming off SJC-NRT route. Also, first A300 comes off lease on 2008, no decision yet about a type replacement. AA is still debating wether to keep the first AB6's coming off lease or move some 763's to cover A300 flying. They admit their A300s serve well the hi-density/cargo mid-short haul missions flown.
commavia
RE: AA 777 JFK-EZE-JFK Soon!
Fri Jun 30, 2006 4:52 am
AA must be getting another 777 from somewhere, because only the 777 from SJC-NRT won't cut it. That's only one plane. A daily JFK-EZE-JFK rotation with a redeye in both directions requires 2 full aircraft. Perhaps the planes to fly this route could come from the DFW-LGW-RDU-LGW-DFW 2-aircraft rotation? If AA upgrades the JFK-EZE market to a 777, especially for the peak winter season, it certainly would not be surprising, as the market can definitely support it.
My completely unscientific count of AA's 777 utilization this winter, based on the current forward-looking schedule, shows utilization as:
LHR
BOS-LHR: 2 aircraft
JFK-LHR: 7 aircraft
ORD-LHR: 5 aircraft
LAX-LHR: 1 aircraft
MIA-LHR: 1 aircraft*
LGW
DFW-LGW: 1 aircraft
FRA
DFW-FRA: 1 aircraft
NRT
DFW-NRT: 4 aircraft
ORD-NRT: 2 aircraft
JFK-NRT: 2 aircraft
LAX-NRT: 1 aircraft
KIX
DFW-KIX: 2 aircraft
PVG
ORD-PVG: 2 aircraft
DEL
ORD-DEL: 2 aircraft
GRU
MIA-GRU: 2 aircraft
JFK-GRU-GIG: 2 aircraft
EZE
MIA-EZE: 4 aircraft
(JFK-EZE: 2 aircraft)
*aircraft for weekend flights LHR-MIA come from LHR-JFK flights not operating on weekends
Including JFK-EZE, that's a total of 43 aircraft by my count, and AA currently has 44 flying right now (not counting the one on 1-year lease to Boeing). So, I suppose, assuming I haven't counted wrong (which I very well may have), they definitely have the planes for it after cutting SJC-NRT and reducing RDU-LGW and the second DFW-LGW down to 777s.
MAH4546
Fri Jun 30, 2006 5:37 am
It is true. The 772 is going to JFK-EZE between November and early April. I'm not really sure how they are rotating it in to the schedule, but I can confirm it.
a.
commavia
Fri Jun 30, 2006 5:39 am
Thanks, MAH, for confirming.
Also -- caught my own mistake. In my first reply, BOS-LHR requires 3 777s, not 2, which would bring the total count right up to 44, the number AA currently has flying. I should have known better than to think AA would give itself some 777 breathing room -- they always utilize these things intensively!
[Edited 2006-06-29 22:39:56]
adh214
Fri Jun 30, 2006 5:47 am
What is AA's frequency between BOS and LHR? If it is just daily, I would think one aircraft would be sufficient. If you have a moment, please provide more details. Thanks.
I am truly asking because I do not know but am interested. I mean no disrespect. You clearly have a lot of knowledge on this topic.
Andrew
commavia
Fri Jun 30, 2006 5:55 am
Quoting Adh214 (Reply 4):
AA runs double-daily BOS-LHR, which would ordinarily, as you indicate, require 2 aircraft (1 for each flight). However, one of AA's eastbound BOS-LHR flights (not operating Saturdays during the winter) is a morning departure from BOS, meaning that it requires another entire aircraft in order to make a daily rotation in both directions because the planes doesn't get to Heathrow until after 8:00 at night.
No worries -- no offense taken whatsoever.  Smile
baron95
Fri Jun 30, 2006 6:31 am
As an AA frequent flyer on the JFK-EZE and GIG-MIA I'd pop the bubbly everytime AA retires a 767 from a route I fly and replaces with 777. AA's 767s are just disgraceful.
Killer Fleet: E190, 737-900ER, 777-300ER
dc10s4ever
Fri Jun 30, 2006 7:05 am
I think that N7AL will be comming back from Boeing this fall. There is one more aircraft.
thering
Fri Jun 30, 2006 7:21 am
Quoting Dc10s4ever (Reply 7):
Why it was in Boeing?
146 319 320 321 332 722 732 733 734 735 73G 738 742 743 744 762 763 772 773 CRJ ER4 100 F50 F27 M11 D10
thering
Fri Jun 30, 2006 7:25 am
Quoting PRAirbus (Thread starter):
Thee should replace their A300 with their oldest 763s as a temporarly resolution. On the future, they should think of the 787 as a plane that could fly both the 763s and the A300s routes.
commavia
Fri Jun 30, 2006 7:26 am
Quoting Thering (Reply 8):
AA leased the plane to Boeing last fall for up to a year for Boeing to do some testing with the plane. AA obviously felt that the revenue from Boeing would exceed what they could get from flying the plane around for a year.
Quoting Thering (Reply 9):
That's pretty much what everybody is expecting, that AA will eventually replace the A300s with the 787s. The 787's cargo capacity and economics are a perfect fit for the current A300 markets. Most regard that as a matter of "when," not "if."
thering
Fri Jun 30, 2006 7:34 am
Quoting Commavia (Reply 10):
Yes I agree! The 787 in mu sight will be a very versatile airplane, that would fly JFK/ORD or JFK/LHR for example with the same efficiency!
AeroWesty
Fri Jun 30, 2006 7:39 am
Quoting Commavia (Reply 1):
Some of the routes you've listed only require 1.5 aircraft instead of 2. For example, the flight from Tokyo to New York arrives in time to make one of the evening departures to London, same with NRT-ORD and possibly one of the NRT-DFW flights.
International Homo of Mystery
Jj
Fri Jun 30, 2006 7:44 am
One minor correction.
MIA-EZE: 4 aircraft
As far as I know, currently MIA-EZE is served 2x daily. However, one of these flights is on a 763, so that would mean MIA-EZE demands just two 777's.
jacobin777
Fri Jun 30, 2006 7:57 am
LHR
BOS-LHR: 2 aircraft
JFK-LHR: 7 aircraft
ORD-LHR: 5 aircraft
LAX-LHR: 1 aircraft
ORD-LHR goes down to 4x/daily during the winter season...now does that mean they need 5 aircraft, I don't know...
"Up the Irons!"
MalpensaSFO
Fri Jun 30, 2006 8:06 am
JFK-EZE was a 777 in the past with both AA and UA. At one point UA even operated the 747-200 on the route. This is nothing more than a restoration of capacity.
TO FLY IS TO SERVE
NikonDFW
Fri Jun 30, 2006 8:10 am
Also keep in mind that AA is using 777's for military charter work as well.
dc10s4ever
Fri Jun 30, 2006 8:19 am
Quoting NikonDFW (Reply 16):
AA is not currently flying any military charters with 777 at the moment.
PRAirbus
Fri Jun 30, 2006 8:31 am
AA flies 1 777 between BOS-SDQ-BOS only on Saturdays (hi-season). Equipment not used when 2nd BOS-LHR (day time flight) does not fly on Saturdays.
NikonDFW
[quote=Dc10s4ever,reply=17]AA is not currently flying any military charters with 777 at the moment.
No, not at the moment, but for the upcoming holiday season they will be doing a fair amout of R & R flights for the troops.
dc10s4ever
Fri Jun 30, 2006 8:39 am
Quoting NikonDFW (Reply 19):
AWESOME! This is an EXCELLENT source of revenue for AA, plus when we are flying them, the troops REALLY prefer AA!  Smile
AA777223
Fri Jun 30, 2006 8:47 am
Quoting Dc10s4ever (Reply 17):
I know ATA often uses L1011s for military charter into DFW, and just tuesday I was coming into the international terminal D here at DFW from SCL, and I saw a huge group of soldiers that had just come home. I think it was an AA flight. I know the old L10s have to make a tech stop going to Iraq, but can the long legged 772er make the flight from DFW to Baghdad, Doha, Istanbul, or wherever in the middle east they pick up soldiers, nonstop? That would be awesome if it could, an explain why AA has picked up some of the contracts from ATA.
Oh and by the way AA does have 45 777s flying, even with 1 at boeing... they just got a new one about a month ago.
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175, DH-8, ATR-72, DO-328, BAE-146
MAH4546
Fri Jun 30, 2006 9:59 am
Their oldest 767s are older then their oldest A300s and cannot profitably handle the high number of takeoffs/landings the A300 does on routes like MIA-PAP and MIA-MCO, both under two hours.
Quoting Jj (Reply 13):
Effective 4 September 2006, both flights are a 777, year-round.
a.
LAXintl
Fri Jun 30, 2006 10:05 am
The second LAX-LHR flight ends on 10/28 freeing and aircraft also.
argento
Fri Jun 30, 2006 10:10 am
MIA-EZE-MIA will be upgrade from 763 & 772 to 2 daily 772 , begining OCT 06.
Quoting MalpensaSFO (Reply 15):
Before 9/11 & Argentina financial crisis , AA opereted 772 from JFK & MIA (2 daily), before the introduction of 772 ,MIA-EZE was a MD11 route.
UA routes to EZE were MIA, JFK & ORD -EZE all with 772 , until 2002.
MIA-EZE was operated with 741 from 1990 to 1998.
Mason
Fri Jun 30, 2006 12:05 pm
So nice to see 777 operating to South America again. I remember when AA flew 777s DFW and MIA-SCL; those were the days! One can only hope to see that service return. No doubt this move is to compete with LAN, who offeres far superior service on this route, even if it is with 767s.
MAH4546
Fri Jun 30, 2006 3:00 pm
Quoting Mason (Reply 25):
AA and LAN don't compete. They have anti-trust immunity.
The 777 was used to Santiago for cargo capacity. DFW-SCL is a huge money loser in the passenger cabin, always has been, but a huge money maker in the And combine that with the light loads that free up even more space underneath.
a.
tockeyhockey
Fri Jun 30, 2006 9:27 pm
Quoting Commavia (Reply 3):
does this include the one that just rolled out of everett?
PolymerPlane
Fri Jun 30, 2006 9:38 pm
They are testing the new 787 control computer program on the leased AA 777
PP
One day there will be 100% polymer plane
AA777223
Fri Jun 30, 2006 10:47 pm
Quoting MAH4546 (Reply 26):
I can agree here. I just flew this route here and back this past weekend. It was pretty empty, and I was thinking there was no way they were making any profit on those flights with pax. Do they really get anough cargo to justify the route?
incitatus
Fri Jun 30, 2006 11:10 pm
Is American doing this as a pre-emptive move before Delta starts flying between NY and Buenos Aires?
Conservatives against Trump
commavia
Fri Jun 30, 2006 11:38 pm
Quoting Incitatus (Reply 30):
I think it has more to do with it being peak season for U.S.-Argentina traffic, and AA having 777s to spare for the route, which operated with a 777 for several years before 9/11. Besides, who knows when (if?) Delta will be flying JFK-EZE anytime soon.
MAH4546
Sat Jul 01, 2006 3:26 am
Delta isn't starting EZE-JFK. They competed with CO for the route authority and lost.
Quoting AA777223 (Reply 29):
Yes, believe it or not, they do. The cargo on that route has basiclly justified its existence since the flight started.
a.
AA767400
Sat Jul 01, 2006 3:49 am
MAH4546,
Mark do you know of any upcoming routes in the near future?
Any news on anything out of JFK?
"The low fares airline."
