BA
Google Earth: Pink Blotches On Airport Gate Stands
Fri Jun 30, 2006 1:36 pm
With the recent high resolution imagery update in Google Earth, many new airports were added.
I noticed these pink blotches in several of the gate stands in Beirut airport. Does anyone have any idea what they are? What's interesting is they are only on the outer gates.
I have checked other airports in the region including Damascus and Amman and none have these pink blotches.
Could it be some kind of chemical used for cleaning the stands?
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
Goldenshield
RE: Google Earth: Pink Blotches On Airport Gate Stands
Fri Jun 30, 2006 1:48 pm
Those look like the surface of the jet bridge "danger" area.
jetmatt777
Crew
Fri Jun 30, 2006 2:08 pm
Quoting Goldenshield (Reply 1):
That's what I was thinking...definatley the 'danger' area.
-Matt  Smile
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
OHLHD
Fri Jun 30, 2006 10:04 pm
Anti / Deicing Fluid could be one reason.
lewis
Fri Jun 30, 2006 10:07 pm
Quoting OHLHD (Reply 3):
In Beirut????
lincoln
Fri Jun 30, 2006 10:53 pm
Add a thrid vote to "danger area". If you look at ONT (one airport where I'm positive that I've seen the "Danger" area marked, you can see the same general pattern (just fainter)
OHLHD
Fri Jun 30, 2006 10:58 pm
Quoting Lewis (Reply 4):
In Beirut????
During winter in can be chilly afaik and you even have snow in the mountains.
This is why I suggest it.
Goldenshield
Fri Jun 30, 2006 11:24 pm
Quoting Lincoln (Reply 5):
The danger areas at ONT are striped instead of solid, but it's the same general idea. When HA came to ONT with the 767-300, they had to modify the jet bridge to operate outside of the safety area, as the first time it pulled into the gate, the rampers had to pull the plane 15 feet forward in order to be able to connect it to 2L. This was before Delta brought in their 767-300's.
BA
Sat Jul 01, 2006 1:26 am
Thanks for the feedback, I believe those of you who say that they are the "danger" areas of the jetbridges are correct.
However, this does raise one interesting question though. Why don't the inner gates (gates 7-18) have the "danger" areas?
There are no deicing systems in Beirut.
Quoting OHLHD (Reply 6):
Beirut in the winter gets wet and muggy, but not cold enough to the point that there is a high level of freezing.
It does snow in the mountains at the high altitudes.
Goldenshield
Sat Jul 01, 2006 2:06 am
Quoting BA (Reply 8):
Since those inner jetways are all parallel with the terminal, it would be en educated guess that these gates are fixed, with only 2 ways of travel: up/down, and a telescoping section that would need precise positioning of the aircraft on it's stop line. PHX, and DCA have similar bridges.
BA
Sat Jul 01, 2006 2:19 am
Quoting Goldenshield (Reply 9):
You're right, they actually are fixed jetbridges.
http://img.photobucket.com/albums/v168/mea707/beyamm/100_0081.jpg
http://img.photobucket.com/albums/v168/mea707/beyamm/100_0085.jpg
You know quite a bit about jetbridges.  Smile Are you a ramp agent?
DIA
Sat Jul 01, 2006 2:30 am
You can see a bit of a closer look at it in this photo...to the left.
Photo © Chadi Kassas
Ding! You are now free to keep supporting Frontier.
lincoln
Sat Jul 01, 2006 3:21 am
Quoting BA (Reply 10):
And you can see in the picture, even the fixed jet bridges have danger area markings... they're just smaller  Smile
Lincoln
Goldenshield
Sat Jul 01, 2006 4:37 am
You know quite a bit about jetbridges. Are you a ramp agent?
I was during my tenure at my former employer.
BA
Sat Jul 01, 2006 11:26 am
Quoting DIA (Reply 11):
Indeed, thanks for that.
For some reason I never realized that the jetbridge danger zone would be so obvious and clear from an aerial image.
DIA
Sat Jul 01, 2006 11:49 am
Quoting BA (Reply 14):
Reminds me of those tile-murals on the floor of Concourse A at DIA...you can't make out what they are until you go to one of the floors above...and even at that I still can't make out what some of them are supposed to be.
