gayrugbyman
Oldest 747 Still In Service?
Thu Jul 06, 2006 8:31 pm
Who operates the oldest Boeing 747 still in regular passenger service?
a300
RE: Oldest 747 Still In Service?
Thu Jul 06, 2006 8:47 pm
Iranian Air Force has some early made ones in the tanker/transport role. Iran air has several from mid-70s.
Boland Aseman Jayegah Man Ast.
Tg 747-300
Thu Jul 06, 2006 9:09 pm
Orient Thai should have some good old 747's Not saying their the oldest, but I'll think they might be close.
tg 747-300
intentionally left blank
CHRISBA777ER
Thu Jul 06, 2006 9:13 pm
I believe its an Evergreen 741. Do a photosearch maybe?
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
TriStar500
Thu Jul 06, 2006 9:14 pm
Quoting CHRISBA777ER (Reply 3):
On a passenger service?
CHRISBA777ER
Thu Jul 06, 2006 9:23 pm
Quoting TriStar500 (Reply 4):
LOL oops sorry my bad.
In that case the IR 742.
Thu Jul 06, 2006 9:30 pm
Quoting A300 (Reply 1):
You are right... It is reported, that Iran AF is flying one B747-100 c/n 5!! but too little is known, if still active...
On passenger service, I would guess KABO AIR Nigeria... But also, too little is known, if these a/c still operates...
CO7e7
Thu Jul 06, 2006 9:38 pm
What about this bird??
If you read the comment, it seems as though this plane has been around for a while...
Comments ?
Photo © Erezms
a300
Thu Jul 06, 2006 9:51 pm
I have seen some of the Iranian Air Force 747s landing at Tehran-Mehrabad. I couldn't see the registration to know if it was in fact c/n 5 aircraft.
AMSSFO
Thu Jul 06, 2006 10:00 pm
Quoting Debonair (Reply 6):
Iranian Air force has indeed several of the oldest B747s still active, but these are freighters/tankers.
The oldest active pax 747 might be 5N-EEE c/n 19732
Photo © Ger Buskermolen
but I don't know whther it's still active nor do I know whether it's doing regular services. It was last seen in 2004.
You might be closer than you thought. If Kabo Air isn't doing any regular operations, the oldest one that is doing regular pax services is likely Oreint Thai's HS-UTP 20530
Photo © Tamon Takeoka - AirTeamImages
Titch
Thu Jul 06, 2006 10:09 pm
Quoting AMSSFO (Reply 9):
Kabo Air actually have another 747 in pax configuration that's actually older than 5N-EEE; 5N-RRR (c/n 19765) was originally delivered on March 7th 1971, two months before 5N-EEE. Whether it's still flying or not is a different matter.....
Titch
I'll make weapons out of my imperfections
LVZXV
Thu Jul 06, 2006 11:15 pm
With regards to Kabo Air, the latest available information on its 747 fleet is the following:
Type: B.747-136
Serial: 19766/111
Engines: JT9D-7A
1st Flight: 13-02-71
1st Delivery: 14-03-71 (BA)
Reg: 5N-JJJ
Operator: Kabo Air
IATA code: N2
Status: Derelict at KAN
Remarks: 109,944 hours
Last update: 16-Dec-2005
Type: B.747-136
Serial: 20952/246
Engines: JT9D-7A
1st Flight: 20-09-74
1st Delivery: 06-11-74 (BA)
Reg: 5N-OOO
Operator: Kabo Air
IATA code: N2
Status: Stored
Last update: 20-Jan-2006
Type: B.747-136
Serial: 19765/109
Engines: JT9D-7A
1st Flight: 10-02-71
1st Delivery: 05-03-71 (BA)
Reg: 5N-RRR
Operator: Kabo Air
IATA code: N2
Type: B.747-243B
Serial: 19732/134
Engines: JT9D-7J
1st Flight: 28-04-71
1st Delivery: 07-05-71 (AZ)
Reg: 5N-EEE
Operator: Kabo Air
IATA code: N2
Type: B.747-287B
Serial: 21189/274
Engines: JT9D-7J
1st Flight: 11-11-75
1st Delivery: 16-12-76 (AR)
Reg: 5N-NNN
Operator: Kabo Air
IATA code: N2
Status: Stored
Type: B.747-238B
Serial: 20842/238
Engines: JT9D-7J
1st Flight: 13-05-74
1st Delivery: 24-05-74 (QF)
Reg: 5N-PDP
Operator: Kabo Air
IATA code: N2
Status: Active
Last update: 15-Jun-2006
Type: B.747-238B
Serial: 20921/241
Engines: JT9D-7J
1st Flight: 28-06-74
1st Delivery: 10-10-74 (QF)
Reg: 5N-PPP
Operator: Kabo Air
IATA code: N2
Source: www.aerotransport.org
So basically, Kabo have just one 747 still flying (5N-PDP), and as far as surviving 747s go, she is not the oldest in the world. That honour apparently falls to:
Type: B.747-238B
Serial: 20009/147
Engines: JT9D-7F
1st Flight: 08-07-71
1st Delivery: 30-07-71 (QF)
Reg: 3D-NED
Operator: Northeast AL
Status: Active
Remarks: 71,415 hours, 16,108 cycles
Last update: 12-Jun-2005
Photo © Konstantin von Wedelstaedt
However, for those of you who are, as I am, not convinced that this bird is still flying, the oldest would have to be this one:
Type: B.747-246B
Serial: 20530/196
Engines: JT9D-7AW
1st Flight: 23-08-72
1st Delivery: 03-11-72 (JL)
Reg: HS-UTP
Operator: Orient Thai AL
IATA code: OX
Status: Active
Last update: 14-Aug-2005
Photo © K.L.Yim
Orient Thai is also the operator of the last basic B747-100 in passenger service, 1975-build HS-UTD:
Photo © YK
ZXV
How do you say "12 months" in Estonian?
Fly2CHC
Thu Jul 06, 2006 11:58 pm
What about the Saudia B747s?
Titch
Fri Jul 07, 2006 12:07 am
Quoting Fly2CHC (Reply 12):
The oldest 747 that Saudi Arabian operates is HZ-AIB (c/n 22499), delivered on April 2nd 1981.
Quite a bit younger than some of the other machines out there.
Titch
LVZXV
Fri Jul 07, 2006 12:15 am
They are of the younger -100B model of '80s-build, an "afterthought" of the 747-100 if you like.  Wink
ZXV
Magyarorszag
Fri Jul 07, 2006 12:19 am
Don't forget that SV B747-100s are -100B which were all delivered in 1981/82, and followed some years later by a batch of B747-368.
bennett123
Fri Jul 07, 2006 2:34 am
If you read this, I think that they are referring to our birds.
Sleeping at Kano clearly nor recommended.
http://www.sleepinginairports.net/africa/kano.htm
LVTMB
Fri Jul 07, 2006 3:38 am
Quoting LVZXV (Reply 11):
Type: B.747-287B
Serial: 21189/274
Engines: JT9D-7J
Reg: 5N-NNN
Operator: Kabo Air
IATA code: N2
Status: Stored
LVZXV, slightly off-topic but speaking of old 747s, I believe that, although this ship was originally built for AR (-87), it was never taken up (i.e., not delivered to AR). I believe that after changing hands several times, it became VS' first ship. On the other hand, AR got its first 742s in 1978, as I recall. Is this your understanding as well?
MB
ba747yyz
Fri Jul 07, 2006 3:45 am
In terms of a major commercial airline KLM still operates at least one 747-200.
kl5147
Fri Jul 07, 2006 5:38 am
Quoting BA747YYZ (Reply 18):
I am very curious to know which a/c it is then
"The world is just a click away!"
KLMNW
Fri Jul 07, 2006 5:50 am
Quoting KL5147 (Reply 19):
Same here  Wink
phkrs
Fri Jul 07, 2006 6:09 am
KLM doesn't fly any B742 anymore as their last B742 (PH-BUK) is on display at Aviodrome Lelystad
MP still operates B742F;
So I think you mean AF still flies B742 ?
[Edited 2006-07-06 23:11:34]
DIA
Fri Jul 07, 2006 6:16 am
This was KLM's last 742:
Photo © Tim Rees
Out of service in 2003...
Ding! You are now free to keep supporting Frontier.
starguy
Fri Jul 07, 2006 6:17 am
Just looking at those old birds terrifies me. I would never get on one as I scared of old 747s. I would be paranoid that there would be an inflight break up. I don't know why I link the two but I do.
bennett123
Fri Jul 07, 2006 6:31 am
B18255 and JA8119 both broke up.
However the common factor seems to have been inadequate repairs in both cases.
see reports in www.aviation-safety.net
N867BX
Fri Jul 07, 2006 6:49 am
Does anyone know who has the oldest 747F? Kallitta perhaps?
777STL
Fri Jul 07, 2006 6:54 am
Quoting N867BX (Reply 25):
UPS would certainly be up there, their oldest active bird was #57 off the line in 1970. Though it did start life as a pax bird, it's a freighter now.
PHX based
PipoA380
Fri Jul 07, 2006 7:26 am
Photo © Tommy Desmet
Here's an old bird too, delivered in July 1973 c/n 20682/202
It's not about AIRBUS. it's not about BOEING. It's all about the beauty of FLYING.
YULYMX
Fri Jul 07, 2006 7:28 am
Was thinking about Air force one
Anyone got the date of those 2 birds?
PipoA380
Fri Jul 07, 2006 7:43 am
Quoting YULYMX (Reply 28):
Only one but:
Reg: 92-9000
Boeing 747-2G4B (VC-25A)
USAF United States Air Force
Delivery date: 20.12.1990
Not that old  Wink
Tiger119
Fri Jul 07, 2006 7:47 am
- It was right before Bill Clinton took office as president.
- When did Boeing quit making the 747-SPs and 747-SRs? Are there any still flying and what are the differences in the two models?  airplane
David
 wave
Flying is the second greatest thrill known to mankind, landing is the first!
PipoA380
Fri Jul 07, 2006 8:23 am
Quoting Tiger119 (Reply 30):
Yes, Saudi Arabian government still flies 2, and some Governments mostly in the middle-east fly them too (Oman, Yemen, Qatar, Bahrein...)
Syrian Arab still flies 2 as pax it seems, Iran Air flies one and Saudi Arabian flies 1 too.
Quite a rare bird as there are 13 still active around the globe!
Photo © Phil haslam
jfk69
Fri Jul 07, 2006 11:59 am
How old is that LY 742 that was passenger but recently turned into freighter service?
AA777223
Fri Jul 07, 2006 12:36 pm
Does that mean there are no more 741s still in service? Too bad!
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175, DH-8, ATR-72, DO-328, BAE-146
777STL
Fri Jul 07, 2006 1:59 pm
Quoting AA777223 (Reply 33):
Pax service, maybe not. There are 741 freighters out there, again, UPS for instance, they have some of the oldest active 741s out there right now.
PHX based
LVZXV
Fri Jul 07, 2006 2:00 pm
Quoting LVTMB (Reply 17):
This ship was in fact delivered new to its intended customer as LV-LZD on 16-12-76, flying her inaugural service on 06-01-77 (note how its 1st flight was over a year earlier--yes, there were complications with this aircraft). I nickname this aircraft El militar (LSD was her official "nick") as it flew for AR for almost the duration of the military government, returning to Boeing in either 1982 or 1983--can't remember when--as N354AS.
Photo © Eduard Marmet
Photo © George Canciani
Photo © Frank C. Duarte Jr.
Photo © Johan Ljungdahl
As you rightly say, she went on to become VS's first 747 (G-VIRG Maiden Voyager) in 1984, serving the trendy British carrier until 2001 before joining Kabo Air of Nigeria. I would guess that little life remains in her by now.
It is a curious fact that neither AR's first 747 (LV-LZD) nor 727 (LV-MCD) stuck around for long, and that the second of each type were widely assumed to be the first (LV-MLO in the former case, LV-MIM in the latter). LV-LZD was returned to Boeing as part of a debt repayment of sorts if I recall correctly--undoubtedly stemming from these giants exceeding AR's (admittedly limitless) budget.
It might interest you to know that at this point neither one of AR's two surviving 742s (LV-MLR & LV-OEP) are flying. As though history were repeating itself, parent company Air Plus Comet "borrowed" the engines of these aircraft to supply the 742s said company "borrowed" from AR...
Must leave now as I have a plane to catch (SK518 LCY-ARN) for a nice weekend with my Swedish in-laws, back on Sunday evening.
Saludos!
ZXV
TheSonntag
Fri Jul 07, 2006 6:09 pm
There is still one 747-100 of Iran Air in service... It was in CGN last year and might come again this year...
AMSSFO
Fri Jul 07, 2006 7:03 pm
Quoting 777STL (Reply 26):
Quoting 777STL (Reply 34):
Iranian Airforce does have several very old 741. Don't know whether they currently are all active.
Photo © Frank de koster
The oldest B747F in active service would, however, be this UPS B747-121SF, N681UP c/n 19661, line number 70. First flight 24.07.1970. Might be stored however.
Photo © Jay Piboontum
There's one older 741 that might still fly, although not regular. That's this General Electric test bed: N747GE c/n 19651 line number 25. First flight 03.03.1970.
Photo © Serge Bailleul - AirTeamImages
Quoting JFK69 (Reply 32):
I guess you mean 4X-AXQ? Which is c/n 20841 line number 233. First flight 28.02.1974
