VirginFlyer
Can Composite Fuselages Be Kept Unpainted?
Sat Jul 08, 2006 6:51 pm
As we all know, it is possible to keep aluminium unpainted and polished, which results in less weight (thus allowing lower fuel burn, or more payload uplift), but requires more regular polishing and maintenance. Aside from this, it does have aesthetic qualities:
Photo © Matthew C. Lyons
Could the same thing be done with composite fuselages, or would there a requirement for it to be painted to keep it sealed? If it could be left unpainted, would it need more regular maintenance and polishing than a painted composite surface?
I'm not really certain how good a black plane would look, but if it can save weight without impacting on maintenance, then might we see unpainted 787s...
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
kappel
RE: Can Composite Fuselages Be Kept Unpainted?
Sat Jul 08, 2006 7:30 pm
Agreed, we may see some black 787's with some decals on it. I believe the fuselage is corrosion resistant, so I guess it would be possible.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
ehho
Sat Jul 08, 2006 7:35 pm
Quoting VirginFlyer (Thread starter):
Could be pretty cool actually... especially for LCCs, with some big white letters.
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
Beaucaire
Sat Jul 08, 2006 8:27 pm
Although the article does not cover Carbon-fiber fuselages,it gives a good idea on the weights associated to paint-jobs.
It is my understanding that Carbon-fiber fuselage needs protective coverage,since small cracks or scratches would allow water to infiltrate the multi-layered structures and create difficult to locate micro-disbonding.
http://www.boeing.com/commercial/aer...zine/aero_05/textonly/fo01txt.html
Please respect animals - don't eat them...
VirginFlyer
Sat Jul 08, 2006 8:57 pm
Thanks for that very interesting and informative article Beaucaire. I think it even answers my original question:
Protective paint is used in certain areas to prevent corrosion, and it is used on all composites to prevent erosion and moisture ingress.
I guess that puts paid to the idea of a 'bare-composite' fuselage. Then again, I have seen the weave visible in some sporting items (rowing skiffs, yachts etc), presumably with some sort of clear lacquer over it, but I imagine there wouldn't be a huge weight saving over painting it instead, and of course I have no idea if that is the same sort of material as what is being used on the 787...
V/F
JBo
Sat Jul 08, 2006 9:10 pm
Of course, given that unpainted composite is usually black, I'd say that seeing then unpainted would be pretty rare since black absorbs heat.
I'd take the awe of understanding over the awe of ignorance any day.
rikkus67
Sun Jul 09, 2006 5:02 am
let's hope that Beoing can find a "bare-metal" aluminum decal that is lightweight and long lasting....
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
Beaucaire
Sun Jul 09, 2006 5:16 am
Quoting Rikkus67 (Reply 6):
This would highly simplify lightning protection....
lredlefsen
Sun Jul 09, 2006 8:29 am
Quoting Kappel (Reply 1):
Quoting EHHO (Reply 2):
Sounds like it would be really hot, actually...
roseflyer
Sun Jul 09, 2006 8:44 am
What? Are you referring to chrome plating?
You may notice that tails never have the polished aluminum look since they are often made of composite structures that must be painted since they can't be polished.
You can't really polish a composite in the same way that you can polish aluminum. The composite is going to look like whatever the matrix material is, and in the case of the 787 it is not aluminum (it is aluminum in the A380 and thus it could remain unpainted).
JAAlbert
Sun Jul 09, 2006 9:01 am
So assuming AA buys the 787, what will this do to the famous AA livery (red/white/blue stripe over polished aluminum)? Will AA choose some sort of metalic gray/graphite paint as the base, will it rap the plane in applied chrome leaf (if such a thing exists) or will one of the longest running liveries in the airline world be forced to change? And what would it change into??
I know AA's more modern aircraft have many more portions painted gray, which really doesn't look all that great. I hope they don't just paint the fuselage gray!
Stitch
Sun Jul 09, 2006 9:45 am
Hopefully AA will buy the chrome paint McLaren uses on their Formula One cars and not the "ghost grey" they use now on non-aluminum structures.
MCIGuy
Sun Jul 09, 2006 10:17 am
I brought this up myself a while back and got crickets (AA and the 787).
It's my understanding that composite has to be painted, so it's hard to tell what airlines like AA would do. I guess they'd either have to paint and get close, or change their livery altogether.
BTW, bare composite doesn't look all that good anyway. I have a CFRP kayak paddle and the epoxy is very clear, so you can readily see the layup (tape) inside.
Airliners.net Moderator Team
DesertFlyer
Sun Jul 09, 2006 10:57 am
Photo © Bob Garrard
I think black looks pretty cool. In this case, maybe even sexy.  Wink
Maybe AA would launch a new livery if they ever purchased the 787? Otherwise, it'd be a very grey looking plane (think A300s at one point).
roseflyer
Sun Jul 09, 2006 11:58 am
Quoting JAAlbert (Reply 10):
It would probably look like the A300s when they first flew for AA. They were painted a grayish white.
Photo © Jörg Tegen
compared to the new polished scheme
Photo © Jörg Tegen
bombayhog
Sun Jul 09, 2006 12:30 pm
If AA were to get the 787 I reckon they should go for the silvery paint that VS and NW use. I seem to remember reading a while back that the paint has mica in it to get that metallic look. In any case, that might be a nice compromise, though it would of course take away the advantage they now currently have in terms of weight with the polished aluminum. Could it possibly be that they'd be less willing to get the 787 (assuming they get to a point where they can afford it) simply due to this issue of not being able to fly them 'bare'? It's an interesting question......
bohica
Sun Jul 09, 2006 12:35 pm
Just call it euroblack.  Smile
baron95
Sun Jul 09, 2006 12:47 pm
I don't know about carbon fiber fuselages, but I can tell you that it is a CERTIFICATION REQUIREMENT that some composite planes like Cirrus SR20/22, Columbia 300/350/400 and Diamond DA20/40/42 be painted WHITE, with only minor decals and stripping allowed.
The issue has to do with the skin temperature reached if it is not white which can delaminate, warp or affect structural integrity. I think there is an issue with UV and airframe life, but I'm not sure of it.
Killer Fleet: E190, 737-900ER, 777-300ER
Bohlman
Sun Jul 09, 2006 12:49 pm
Quoting RoseFlyer (Reply 9):
And nose and tail cones.
I'm not pro-Boeing or pro-Airbus, I'm pro-crew all the way.
Duff44
Sun Jul 09, 2006 1:02 pm
Quoting Stitch (Reply 11):
That "chrome" might be a thin adhesive sheet, too. I know (from personal experience at Lime Rock) that Penske uses yellow adhesive sheet on the Porsche RS Spyders, because if you look up close you can actually see the overlapping seams in the sheet. Also, they had about 5 rolls of the stuff lying in their pit.
Lots of race cars with fancy graphics do this now for base colors as well.
I'm sure you could coat a carbon fiber/composite plane with large amounts of this stuff, and get the desired result without the weight of paint.
I'll rassle ya for a bowl of bacon!
jbguller
Sun Jul 09, 2006 6:42 pm
We may see airlines covering their planes with al-foil instead of painting them?
Hell, if you wrapped a plane in al-foil maybe it would keep for a few years longer?  Silly
