sbnair3022
PC-12 For Airline Service
Tue Jul 11, 2006 6:34 am
Just wondering, what do yawl think about the PC-12 if it were used on scheduled services. I know there was Westward Airways of NE that operated for a while, not sure how many PC-12 they had, but its a neat little plane, but what would passengers think?? What do you think??
THANKS!
Photo © JumboJim747
Photo © Erik Frikke
SBNair!!
planespotting
RE: PC-12 For Airline Service
Tue Jul 11, 2006 6:44 am
I wouldn't imagine there are enough seats to cover the operating costs, which while being fairly cheap as far as corp. aviation goes, still are a bit high for efficient airline operations.
Do you like movies about gladiators?
glydrflyr
Tue Jul 11, 2006 7:02 am
Unfortunately, many passengers view prop driven airplanes, no matter how expensive, reliable or sophisticated as "Piper Cubs" and won't fly them, no matter what. They would go for the VLJs now coming on the market, since they are "Real" airplanes with jet engines.
if ya gotta crash, hit something soft and cheap!
sbnair3022
Tue Jul 11, 2006 7:15 am
wouldn't the VLJ's have operational costs that would cause it to not even be considered by airlines? I know the PC-12 has operated scheduled service, has a VLJ?
[Edited 2006-07-11 00:30:06]
SBNair!!
Thomas_Jaeger
Tue Jul 11, 2006 8:00 am
There are still some Canadian operators using the PC-12 for scheduled services if I remember correctly.
Swiss aviation news junkie living all over the place
sbnair3022
Tue Jul 11, 2006 9:33 am
If an airline flying the PC-12 was the only airline in town though, do you think people would stear clear of it because it operated a single engine prop plane?
SBNair!!
Boeing Nut
Tue Jul 11, 2006 9:37 am
Quoting Glydrflyr (Reply 2):
As far as the passengers go, it doesn't matter a hoot what the passeners think. It matters what the airline thinks. The PC-12 is an amazing aircraft. In fact, in certain markets, you would either have an hour flight on a PC-12, or you have a minimum of an eight hour drive because there simply is no other alterative. Tell the passengers they have a choice of either that eight to nine hour drive or a flight of less than an hour, then you'll see where the true demand is.
Personally, I think the PC-12 is nothing less than a brilliant idea in certain markets. Especially with it's recent upgrades.
NWDC10
Tue Jul 11, 2006 9:42 am
The PC-12 would be the perfect "air taxi" aircraft to compete against the Light Weight Jets that are due in sevice soon like the Eclipse. But the PC-12 is probably for shorter distance but still a great aircraft to use. Robert NWDC10
connies4ever
Tue Jul 11, 2006 9:51 am
Quoting SBNair3022 (Thread starter):
THANKS!
Quoting Planespotting (Reply 1):
Quoting Thomas_Jaeger (Reply 4):
Bearskin Airlines of Sioux Lookout ON was using them, as I used to see them at YWG quite often. Usually Winnipeg-Red Lake-Sioux Lookout-Thunder Bay, Thunder Bay-Sudbury-Ottawa, and Ottawa-Toronto(Buttonville). However, I just looked at www.bearskinairlines.com and it shows the current fleet makeup as Metroliners, Beech 99 and Beech King Air 100. I suspect Planespotting is right.
bond007
Tue Jul 11, 2006 9:55 am
Quoting NWDC10 (Reply 7):
Right, but you only need to look where small turboprops are used for airline ops ...the King Air has been available for years, and it's use in the airline world is limited.
Now, there is a small market of course...especially where the Cessna 402's are used now for Cape Air etc.
Jimbo
sbnair3022
Tue Jul 11, 2006 10:06 am
How much is the VLJ going to cost? Say the Eclipse, it is a jet so will it cost more the price of a business jet, or more like the operational costs of the PC-12.
Thanks for all this input guys! I just can't find all that much information searching around for the PC-12 in airline service, and I get more straight forward answers on here! Thanks!!
SBNair!!
timeair
Tue Jul 11, 2006 1:15 pm
Peace Air based out of YPE in North Central Alberta operates the PC12 to the following cities....
YYC - YXD. YMM. YXJ. YQU. YOJ. YPE.
YXD - YMM. YOJ. YPE. YYE. YXJ. YQU
YEG - YMM
And will op when loads warrant to YLL. YQF. or YOD from the major centres.
You can't get there from here.
Jayce
Wed Jul 12, 2006 1:56 am
Montair and Airsprint operate them as well, though I'm pretty sure those are just charters. The RCMP and Government of Canada both have a sizeable fleet, though those aren't used in scheduled airline service.
As far as airlines go and in addition to the ones above, Wasaya Air uses them all over Western Ontario from a base at Sioux Lookout. Pascan Aviation uses them throughout Quebec. Up North, Kivalliq Air flies them all around Nunavut and down to YWG.
"Trying is the first step towards failure" -Homer Simpson
yow
Wed Jul 12, 2006 2:28 am
Kivalliq Air in the far north uses them on skeds between places like Rankin and Cambridge Bay. I'm pretty sure Wasaya in Northern Ontario uses PC-12s too.
glydrflyr
Wed Jul 12, 2006 2:52 am
Quoting Boeing Nut (Reply 6):
Well, let's take a look at the logistics. One hour of flying time in the PC-12, at cruise, in no wind conditions, will get you 310 miles from your departure point. The same 310 miles does equal a six hour drive, averaging 50 mph. But, the traveler has to get from their home to the airport, wait one hour, (security, ya know), board, taxi out, fly to destination, (less than 310 miles) deplane, get ground transportation and drive to final destination. The actual time enroute is going to be very close.
Many of my clients (I have a limo business) would not fly on the turboprop short haul flights when they were still operating out of EWR, electing instead to drive to Boston or Washington, or taking the train. They tell us they won't go on those "Piper Cubs". It would be interesting to see, if a traveler had a choice of chartering a VLJ at $1.75 per mile, or going on a PC-12 what they would take.
Air taxi operators envision VLJ charges to the passenger at $ 1.00 to $ 3.00 per mile, with the low end of this rate overlapping our sedan rate. If they can actually make money at these rates remains to be seen, but they will have the added advantage of getting in and out of fields too small to accommodate the PC-12, so perhaps the convenience of getting closer to the actual destination will command a premium rate.
VirginFlyer
Wed Jul 12, 2006 12:43 pm
Quoting Glydrflyr (Reply 14):
I was under the impression the PC-12 was able to handle fairly short fields. I know the Royal Flying Doctors Service (RFDS) uses them out here on some fairly short, unsealed strips. Will the VLJ's actually have better field performance than the PC-12?
Quoting SBNair3022 (Reply 5):
single engine
That's the issue I've heard raised often. I know there are restrictions placed on single engine IFR for regular public transport in this part of the world... I had the opportunity to speak to a sales rep from Pilatus Australia a while back. I asked him about the single engine issue, and he said that yes, there have been some people concerned about it. He pointed out however that there have been more accidents and more fatalities caused by an engine failure in a piston twin than by an engine failure in a turbine single. He also pointed out that if there is an engine failure, the aircraft is able to glide to a landing, and the computer will even suggest the best airport to reach. I asked someone else not associated with Pilatus about this, and they said they'd been up in a PC-12, and asked the same thing, and had it demonstrated to them. So technically, there is no real issue over it being a single. Obviously there are some regulatory hurdles, but the biggest problem is always going to be convincing the general public, who sadly know next to nothing about aviation, and think propeller = old = unsafe...
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens.
Celebrating the Bicentenary of the Birth of Bahá'u'lláh, 21-22 October 2017
highflier92660
Thu Jul 13, 2006 12:40 am
I believe Tradewind Aviation uses PC-12's on a charter route from notoriously short St. Barts in the Carribean to San Juan. The airport was marginally improved recently with the realignment of the road and a small reduction of the hill slope at the approach end of the 2100 foot runway. The runway was re-paved but not extended past St. Jean beach.
bond007
Thu Jul 13, 2006 12:54 am
For flights of one hour or less, that argument is valid for pistons, turboprops, or 4 engine airliners. Almost every flight, however short, takes around 5-6 hours door to door. An airliner really doesn't have much time advantage over a turbine single for short flights ... in fact one might argue that boarding time is negligible (5 mins), and it can fly into an airport much closer to your destination with much faster security, better parking etc. etc.
No, I think you'll find the VLJs will need longer runways than the PC12. The Eclipse is 2200ft vs 1800ft for the PC12 ... and think that's conservative for the PC12.
Quoting VirginFlyer (Reply 15):
Actually more in turbine twins than turbine singles. The PC12 has extremely docile landing characteristics under no or low power (ie slow). Unfortunately there are many twin crashes mainly due to training issues with operating with one engine .... for example shutting down good engine, not controlling excess yaw etc.
Jimbo
We're Nuts
Thu Jul 13, 2006 6:07 am
I'll admit up front I don't know a hoot about the operating economics of the PC-12, but one of the major challenges for local and regional service aircraft is making them not only profitable, but cheap for customers. A thirty-minute flight in a B1900 shouldn't cost anywhere near as much as a two-hour flight in a 737. If the PC-12 doesn't have enough seats to pass savings on to customers, it will drive up fares in every market the airline flies to and send potential travelers looking for alternative modes of transportation.
Dear moderators: No.
ZSOFN
Thu Jul 13, 2006 6:33 am
Having had the pleasure of spending some time in the right hand seat of a PC-12, I have to say it's an incredible aircraft. I doubt it would be well suited for airline ops in most cases; it's designed to be a high performance aircraft (we landed on very short unprepared strips etc), whilst you can easily pack more people and payload into a C208B and get the job done, albeit a little slower but cheaper.
sbnair3022
Thu Jul 13, 2006 7:49 am
if i were a passenger though the PC-12 looks like a more modern aircraft than the caravan, obviously you can get a brand new caravan but the general public doesnt know that, so in your opinion do you think the public would take more of a liking to the PC-12 or the Cessna Caravan?
Also is there a huge difference in the operational costs of these two?
It says on Cessna's website that the Caravan can be profitable with less then 4 passengers, how did they come up with that number??? Anyone have a clue??
SBNair!!
CRJonBeez
Thu Jul 13, 2006 11:47 am
Quoting SBNair3022 (Reply 10):
they're pushing between 1.1-2.25 million
Quoting Bond007 (Reply 9):
tell that to great lakes and commutair with their B190s. the 1900D shares more than a few parts with the bigger king airs
given the statistics of the PC12, Meridian, TBM, etc, that's a lousy comment. i hold no favorings toward any one aircraft, but how do you compare two completely different a/c, one of which hasn't even been certified yet? in 3 years of corporate aviation, i haven't once heard "i would NEVER fly on a turboprop" out of a passenger's mouth. keep in mind that's from the demand of passengers accustomed to part 91/135. it's an uneducated assumption that because planes of yesterday used props, the new ones must be outdated technology. the PT6-X has been a tremendous engine since inception, along with the constant barrage of new avionics offered in the different a/c. TAWS and TCAS systems are constantly being upgraded for improved safety, as well as glass cockpits in general. the garmin G1000 is being fitted in several VLJs, as well as turboprops and pistons.
beech/raytheon was approached by a company a while back about investing in a VLJ project. raytheon stuck to their guns, instead upgrading to the king air C90GT. what happened to that company? they gave up on their VLJ platform. that's not to say that all intro-jets in the new market they're creating will fail, but putting so much faith into one sort of a/c is awfully limiting. i have more faith in eclipse than anybody else, but that doesn't mean the operators won't screw things up.....
bond007
Thu Jul 13, 2006 11:59 am
Quoting CRJonBeez (Reply 21):
Right, but it's not a King Air, or a PC12. The 1900D was designed as a commuter aircraft.
Hey, I'm on your side  Smile
Jimbo
Boeing7E7
Thu Jul 13, 2006 2:37 pm
Quoting SBNair3022 (Reply 3):
I have zero belief in the VLJ having a major market impact. With the exception of Embraer, these were all designed when fuel was half what it is now. The cost model has imploded on them. They are now nothing more than expensive turboprops for the guy that can't afford a Challenger or replacements for aging Cessna Citations and older Lears.
Adam shows a cost model with gas at $3.10 most prices are in the $4.80-5.00 range.
[Edited 2006-07-13 07:49:35]
