cessna157
Airline Delay Codes
Sun Jul 16, 2006 3:53 am
Just trying to satisfy my curiosity monkey here.....I assume that airlines' delay codes vary from airline to airline.
Delta, and all Delta Connection flights, use the same delay codes, but I assume that a similarly delayed flight on another carrier would be coded differently?
For example:
Aircraft Maintenance: 03A
Crew late from late inbnd flight: 08J
ATC enroute or at destination: 14B
and so on (there are hundreds of codes...)
Anyone have any insight to this?
LN-MOW
RE: Airline Delay Codes
Sun Jul 16, 2006 3:57 am
Most airlines use the IATA standard as base for their delay codes. Most use the numerical codes, but some prefer the alphabetical.
This is IATA's official code sheet:
http://www.b737mrg.net/downloads/b737mrg_delaycodes.pdf
- I am LN-MOW, and I approve this message.
nwcoflyer
Sun Jul 16, 2006 4:01 am
Correct, I do believe they vary airline to airline. For example at YX, some of our delay codes are:
*03A- ATC/Gate Hold
*61P- Delay- Gate, ticket counter
*67P- Delay- Ramp
Most of our codes are a number followed by and A, and M or a P. We only have a handful of codes that we use on a regular basis (probably about 20).
The New American is arriving.
cessna157
Quoting LN-MOW (Reply 1):
Well, some of those explanations look similar, but Delta's codes are much more specific. There are delay code grounds (01-22) and then there are sub-groups.
For example, group 08 is pilot delays:
08B - Crew scheduling error
08F - Late Check-in
08J - Crew late from delayed inbnd flight
08M - Late completion of manifest and/or checklist
cessna157
Sun Jul 16, 2006 4:07 am
Quoting NWCOflyer (Reply 2):
Awesome. We have probably 200 codes (I've never actually counted all of them), but we also generally only use a handful on a regular basis:
03A - Maintenance
06G - Delayed inbnd from upline ATC
06H - Delayed inbnd from upline maintenance
12A - Predetermined online connection hold
12B - Predetermined interline connection hold
14B - ATC delay enroute or at destination
etc....you probably get the picture
fsuwxman
Sun Jul 16, 2006 4:45 pm
At my airline, here are a few of my more frequent delay codes. We use a three letter code for our delays...
PRF- Crew Rest
MOM- Non Scheduled Maintenance
LQ_- Late Arriving Equipment
SSS- Default Station Delay
PAS- Passenger Accomodation
SRS- Security Screening
IPS- Irregular Procedure- Station
IPF- Irregular Procedure- Pilot
FDI- Flight Attendant Delay
ASOS... Another Shi#y Observation Station
sk601
Sun Jul 16, 2006 9:06 pm
KL uses the IATA-codes as listed in reply 1.
This is the top 3 (not officially, just by my own experience)
1. code 81/89 ATC
2. code 03 missing checked-in passenger at the gate (KL code only)
3. code 41 technical problem (KLC F50/70/100 !!!)
pilottim747
Wed Jul 19, 2006 1:31 pm
Quoting Fsuwxman (Reply 5):
Can you get us some more 3-letter codes?
I've seen ATA, IRM and LND. Not sure whats those mean.
Aviation Photographers & Enthusiasts--Coordinate your life.
Users browsing this forum: A330freak, Baidu [Spider], ChristopherS, dstc47, edina, eta unknown, Faro, FAST Enterprise [Crawler], FlySSC, Google [Bot], KarelXWB, LHRFlyer, LTH, lucce, mjoelnir, PanAm_DC10, Pendennis, SpoonNZ, StTim, TedToToe, TheGeordielad, tortugamon, Tristarsteve, Tvilum, VirginFlyer, WIederling and 4 guests
