drerx7
Southwest 737-300s To Get Winglets
Wed Jul 19, 2006 9:56 pm
http://biz.yahoo.com/prnews/060719/sfw034.html?.v=65
Another interesting site to spot at WN heavy airports.
HOUSTON, TEXAS
KFLLCFII
RE: Southwest 737-300s To Get Winglets
Wed Jul 19, 2006 10:29 pm
Which then leaves only the -500s wingletless...
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
DfwRevolution
Wed Jul 19, 2006 10:38 pm
According to the article:
SEATTLE, July 19 /PRNewswire/ -- Southwest Airlines has taken another step separating themselves from their competition by committing to install Aviation Partners Boeing Blended Winglets on up to 90 of their 737-300 aircraft. The order of 59 firm systems and 31 options follows Southwest's commitment in June of 2003 to install Blended Winglets on all of their 737-700 aircraft. Installations are planned to begin in early 2007.
So that's 59 firm orders for a fleet that consist of about 194 733.
I suppose WN will do an evaluation of these 59 aircraft before proceeding to upgrade the rest of the fleet. Not to mention, some of the first 733 were expected to be retired in 2008 and 2009, so it makes sense that some of the older aircraft will never recieve the upgrade.
dacman
WOW!!!!!!!!!!!!!!!!!!!
This is big news for our airline................last I heard it had been decided not to add them.
I look forward to seeing this new addition to our -300s....awseome!
Mike
dacman
LGB/LAX Local
"Airliner Photography is not a crime"
AA777223
Wed Jul 19, 2006 11:38 pm
I didn't know they could do that to the 733. This is somewhat sad, because it means they are planning on keeping them for the forseeable future. Why would they do that with so many 737-700s on order?
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
planespotting
Wed Jul 19, 2006 11:42 pm
Quoting Dacman (Reply 3):
I thought so too! That something with the 737-300 precluded them from getting the same kind of fuel efficiencies with the winglets that the other a/c had been able to get. Apparently Aviation Partners has found a way!
Do you like movies about gladiators?
PHLBOS
Wed Jul 19, 2006 11:43 pm
Quoting AA777223 (Reply 4):
Probably because those 737-700s that are on order will be used for service expansion and not merely replacing older equipment. Also, it probably takes longer for WN (or any airline for that matter) to receive a new plane than to have an existing plane retro-fitted.
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
PVD757
Wed Jul 19, 2006 11:49 pm
I think its pretty simple - as long as the cost savings from the better fuel burn the winglets provide over the sum of the number of years the aircraft will remain in service is greater than the cost of installing the winglets - it's worth it. Add in the cost savings from extending the payload range of the 733 and any others I haven't thought of, and it becomes even more of a no-brainer.
ScottB
Thu Jul 20, 2006 12:28 am
Quoting Planespotting (Reply 5):
I suspect the issue was more that the -300's are generally used on shorter hops than the -700's owing to their somewhat shorter range; as a result, the savings from installing the Blended Winglets are not as dramatic. However, the equation also changes pretty significantly when oil is at $50-80 for the foreseeable future, rather than below $30 when the winglets were originally ordered for the -700 fleet.
Certain of the -300's are likely to be in service for close to 15 more years, since the last were delivered in 1997. Only the very oldest -300's should be reaching retirement age near the end of this decade. My guess is that the winglets will be installed on the newest -300's in the fleet for now.
Again, because a significant portion of the -300 fleet (69 of 195) are under 15 years old and are unlikely to be retired any time soon; the owned frames are fully paid-for, the Classic 737's are efficient and reliable, and Southwest needs the planes to maintain service and continue growing.
OPNLguy
Thu Jul 20, 2006 12:50 am
Southwest took delivery of its first -300 (N300SW) in 11/1984, and the last one (the newest one) was N656SW on 09/26/1997. The 737-700s started coming shortly after that.
As has been explained to be by some friends over on the MX side, the winglet installations cost more and take longer (due to the internal differences between the -300's wing and the -700's wing). It previously didn't make economic sense to retrofit the -300s, but apparently the price of fuel has since risen to the point where it now makes economic sense to do so.
In previous posts on the subject, I had opined that not all -300s would get them, just the newest half of the fleet. With 59 orders and 31 options (90) that's a little over half of the 194 aircraft in the -300 fleet. It certainly makes no sense to spend the $$$ on retrofitting N300SW (22 years old) since its remaining service life won't recover the winglet costs as far as return on investment (ROI) goes. Likewise to whatever point the fleet age versus the ROI scale tips. If fuel prices continue their insane climb, it's certainly possible that the ROI changes, and another batch of older aircraft could get modified.
[Edited 2006-07-19 18:12:34]
DLCnxgptjax
Thu Jul 20, 2006 1:11 am
Why would they go and do a thing like that..hehehe? Now I won't be able to immediately tell the difference between a 300 and a 700 unless I see the landing lights or until it gets closer....  hissyfit
N1120A
Thu Jul 20, 2006 1:18 am
What is wrong with keeping them? They are excellent aircraft and are still quite efficient. Further, it allows WN to use the -700s to expand long haul while keeping the lighter -300s on shorter hops.
Quoting OPNLguy (Reply 9):
Just under half is what I think you mean  Wink
Quoting DLCnxgptjax (Reply 10):
Just look for the little bits of orange on the pylons
eraugrad02
Thu Jul 20, 2006 1:21 am
Um yes you can the wings are totally different. And on the ground the -300s sit lower than the NG's
Desmond MacRae in ILM
OPNLguy
Quoting N1120A (Reply 11):
Note to self: get fully awake before posting...  Wink
BA787
Thu Jul 20, 2006 1:22 am
They will be used for service expansion and WN have 194 733's which would take a lot to replace and expand
N1120A
Thu Jul 20, 2006 1:23 am
Quoting OPNLguy (Reply 13):
Don't worry about posting. Just make sure you are fully awake before dispatching.
OPNLguy
Thu Jul 20, 2006 1:28 am
Quoting N1120A (Reply 15):
Precisely why I work 1-9, 2-10, or 3-11...  Wink
N1120A
Thu Jul 20, 2006 1:33 am
Quoting OPNLguy (Reply 16):
I want your job
OPNLguy
Thu Jul 20, 2006 1:40 am
Quoting N1120A (Reply 17):
I want your job
After the pounding some of our California desk folks took last night, I know a couple that might have been tempted to give them to you...  Wink
We're Nuts
Thu Jul 20, 2006 1:48 am
Very cool, can't wait to see them. Good to hear the -300's will be around for a while too. I wish the -500's would stay longer!
[Edited 2006-07-19 18:49:12]
Dear moderators: No.
ScottB
Thu Jul 20, 2006 2:05 am
Quoting ScottB (Reply 8):
Just as confirmation of this, Laura Wright (Southwest's CFO) said today that there should be a modest number of retirements of older aircraft (i.e. the oldest -300's) commencing in 2009 or 2010.
OPNLguy
Thu Jul 20, 2006 2:07 am
Quoting ScottB (Reply 20):
That would make N300SW about 25 or 26, so that sounds about right...
steeler83
Thu Jul 20, 2006 4:32 am
Quoting OPNLguy (Reply 21):
Didn't WN take first delivery of the 733, as well as USAir? IIRC, they both were the first operators of the 737-300... US took delivery in November, 1984, and I guess WN took delivery shortly after that. I guess they weren't the launch customer of the -300 then...
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
atrude777
Thu Jul 20, 2006 4:40 am
Quoting Steeler83 (Reply 22):
Good statement, Southwest was considered the launch customer for the 733 because WN flew the 733 first in revenue service, even though US Air received the 733 first.
So in thinking it is defined as the person/business/airline to officially launch them into service, and that goes to Southwest Airlines for first launching the 737-300 into revenue service, again even though, US Air bought and received them first!
Alex
Tom in NO
Thu Jul 20, 2006 4:47 am
Doing a little research here:
USAir took delivery of N353AU on 11/28/84
Southwest took delivery of N300SW on 11/30/84
A quick aside to OPNLguy or others from WN.....is WN considering transferring the CA-1, AZ-1, Triple Crown, etc -300 theme plane liveries over to -700 series aircraft?
Tom at MSY
Capital146
Thu Jul 20, 2006 4:50 am
Here's a -300 already fitted with winglets:
Photo © Harri Koskinen
Photo © Sergio Morchon – Iberian Spotters
Like a fine wine, one gets better with age.
atrude777
Thu Jul 20, 2006 4:52 am
Quoting Tom in NO (Reply 24):
Oh boy that would be wicked! Just like they did with Shamu!
Alex
OPNLguy
Thu Jul 20, 2006 5:06 am
I haven't heard of any specific plans to do so, but it wouldn't surprise me if we did at some point, most likely to coincide with a scheduled paint job. The first Shamu was N334SW, so it's been around awhile. I'll have to check the line numbers of the other aircraft with special schemes and see were they are age-wise.
panam330
Thu Jul 20, 2006 9:19 am
Now if we can only get US to get some of these for their -300s...  stirthepot
LV
Thu Jul 20, 2006 9:50 am
Man, I would love that shift. I used to have that shift, now I am working overnights 11 PM to 8 AM.... think you could talk my boss into move me  Smile
socal
Thu Jul 20, 2006 10:18 am
Good news, those -300's will look very good with winglets.
 bigthumbsup
I Love HNL.............
thering
Thu Jul 20, 2006 10:36 am
Nice!
This goes in line with what WN's CEO said, that the -300s will fly at least till 2012....
They are very good and capable airplanes, and will be sad the they they are gone. Not to say that they will look really nice with winglets.
146 319 320 321 332 722 732 733 734 735 73G 738 742 743 744 762 763 772 773 CRJ ER4 100 F50 F27 M11 D10
Silver1SWA
Thu Jul 20, 2006 3:30 pm
Quoting OPNLguy (Reply 27):
That is something I have often wondered myself. However, I believe all of the themed -300s have been repainted within the past 2-3 years so I'm sure they have a few more years left on that paint. Although, Arizona One was painted less than a year ago and it already looks as bad as it did before the new paint job.  crazy
Anyone know why older -700s were used for the new Shamus? I have wondered why they didn't choose brand new planes for them...
scxmechanic
Fri Jul 21, 2006 12:05 am
Quoting Silver1SWA (Reply 32):
Because it's in the contracted price that SWA has agreed to pay Boeing for each delivery. Any changes to that contract must be agreed upon and in place 2* years before said change takes place. If not SWA pay's a surcharge or something to that effect. In other words it wouldn't be cost effective.
* The time frame could be incorrect but I read it is a long lead time to allow Boeing to tool up for any changes.
Read SWA's financials to find the exact time frame for the lead time changes to the new aircraft production. Its buried in there somewhere because that's where I found it some time ago.
Does anyone know where the current re-paints are being done? The ones coming out look pretty sad after the re-spray. Peeling paint and runs. Not something very noticeable from the terminal but when up close, poor indeed.
OPNLguy
Fri Jul 21, 2006 12:14 am
We were doing some at ROW but I haven't seen any there lately...
scxmechanic
Fri Jul 21, 2006 9:18 am
OPNL,
Thanks... I'll be at HDQ Aug 8th 9th and 10th for some training. I'll ask around and see whats up with the painting.
Silver1SWA
Fri Jul 21, 2006 9:29 am
Quoting SCXmechanic (Reply 33):
Thanks, that makes sense. I figured it dealt with costs. Does that mean MD 1 and Slam Dunk 1 have been in the works for a couple or years? Or did someone, possibly a sponsor like the NBA, agree to pay for the costs involved?
scxmechanic
Fri Jul 21, 2006 10:39 am
Quoting Silver1SWA (Reply 36):
That's something I can't answer... Its above my pay grade.. lol
I can only attest to what I read in the 10k's /Annual Reports.
thering
Fri Jul 21, 2006 12:58 pm
Do they still operates the -500 series? How many of them? They can't get winglets right?
DfwRevolution
Fri Jul 21, 2006 1:01 pm
Quoting Thering (Reply 38):
Yes, WN opperates 25 737-500.
I suppose they could fit winglets to the 735 if they wanted to at some point?
OPNLguy
Fri Jul 21, 2006 1:03 pm
Still have all 25. Winglets could be installed, theoretically, but I don't think FAA has approved a STC for the -500s winglets yet. Not that many -500s around, and might not be cost effective...
AirTranTUS
Fri Jul 21, 2006 2:13 pm
That's what I was thinking! BTW..How do the landing light differentiate a -300 from a -700? I know that the engine exhaust design is different and the inlet is more round. Any other ways to tell the two apart?
I love ASO!
atrude777
Fri Jul 21, 2006 2:21 pm
Quoting AirTranTUS (Reply 41):
Using Reg's.
N3XX, N6XX are -300
N2XX, N4XX and N7XX are -700's
N5XX are -500's
Exhaust is different yes, -700's have red canoes under the wings, top of the engine curves over the wing on the -300, the -700 just stops and flows INTO the wing.
Alex
da man
Fri Jul 21, 2006 2:59 pm
Quoting Atrude777 (Reply 42):
Yes, the -300s have grey flap canoes.
War Eagle!
Silver1SWA
Fri Jul 21, 2006 6:56 pm
Too many...do a search. The differences have been spelled out many, MANY times before. Too tired to go through them all again.  Smile All I will say is the most obvious differences are in the wing. The NG wing is completely different than the Classics' wing. A simple search through the photo database of window/wing views would be a good place to compare the two wings.
N3XX, N6XX are -300
N5XX are -500's
These are only ways to tell WN's 737s apart. There are plenty of distinct differences that are not airline specific.
American777
Wed Aug 02, 2006 10:41 am
Here is a WN 737-300 with winglets:
Modified Airliner Photos:
Design © Bobby Catone
Template © Zachary Chelsky
JOE.  Wink
OPNLguy
Wed Aug 02, 2006 11:25 am
Unforetunately, N303SW sure really won't be one of the ones getting winglets...  Wink
steeler83
Wed Aug 02, 2006 11:34 am
Quoting Silver1SWA (Reply 44):
yeah, like range of aircraft, cabin length, and even looking at individual routes that airlines run using specific aircraft depending on pax loads, range, etc...
On a side note, I guess nobody could tell me whether US 1531 from PHL to PIT on 1-1-2006 was a 733 or 735? I know it wasn't a 73G; it didn't have winglets like my flight out of PIT-PHL on Dec 28th... After looking at the registration numbers, the NXXXX numbers, I didn't catch what that was either. Considering that those could have helped me now, I probably should look at that when observing aircraft in the future...
Quoting OPNLguy (Reply 40):
So what will happen to the -500s? Will they eventually be phased out by more 73Gs over the years as they start becomming of age?
OPNLguy
Wed Aug 02, 2006 11:43 am
Quoting Steeler83 (Reply 47):
Probably. We took delivery of them all in the 1990-1992 timeframe, so based purely on projected -300 retirements, the -500s would be around until at least 2015.
American777
Wed Aug 02, 2006 1:41 pm
Quoting OPNLguy (Reply 46):
I never said N303SW was going to get winglets! That is just a fake picture that was made by a WN fan a long time ago. And how the heck do you know is not gonna get winglets hu!
So just read more carefully the replies before YOU REPLY DISPATCHER!  And check your spelling before posting your post.
JOE.
[Edited 2006-08-02 06:43:51]
