wardialer
Taking PC Onboard/Suggestions Highly Needed Please
Fri Jul 21, 2006 9:45 am
I am moving to Europe and I want to take my PC computer with me onboard on the aircraft. Its a tower PC...Not that big but its a mid-range type personal PC.
The major issue is this. I dont want to check-it in a baggage because those guys WILL either drop it, throw it, or handle it roughly....Thats why I wish I want to take it with me on-board inside of the aircraft. Or...is there a huge enough hand-bag thatwill fit inside of the bag to bring it up the aircraft?
I have even have very very sensitive data on that PC and I just have to take it onboard with me. What I'll do is I will call the airline and verify.
I am 100 percent sure that the TSA agents will use an explosive nitrate testing swab kit...for sure...That does not bother me at all. I just wanna get thing onboard.
If....not, what can I do?
I have several options myself. Either call the PC manufacturer to send me an empty box with some good foaming material and fragil stickers everywhere. And then, I can have a freight take it..BTW - I called DHL and Fedex and they said it would be a $1,000 at least to ship it overseas by freight...I dont wanna do that either.
Can I take a PC onboard an aircraft?? And then stow it on the overhead panel? I dont think they will allow that for sure...But I need your guys help and suggestions on this. Please, and thanks in advance!!
highflyer9790
RE: Taking PC Onboard/Suggestions Highly Needed Please
Fri Jul 21, 2006 9:48 am
current carry on dimensions are 22x10x15 for most airlines, so im sure it would fit into carry on. as far as handling goes, you can never be sure with the TSA... sarcastic
121
Bobster2
Fri Jul 21, 2006 12:24 pm
Remove the hard drive(s) and carry it(them) with you.
Take the rest to The UPS Store and pay them to ship it for you.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
LOT767-300ER
Fri Jul 21, 2006 12:37 pm
I took 2 PCs with me to Poland and checked them along with CRT monitors. One went ORD-LHR-WAW and the other ORD-FRA-WAW with me. Nothing happened and they work to this day.
PDXLVR
Fri Jul 21, 2006 3:35 pm
Quoting Bobster2 (Reply 2):
This is what I did when I moved a PC via air. Checked in the rest of the computer in its box, carried the hard drives in my carry-on luggage. Had no problems.
I left my heart in PDX
ANother
Fri Jul 21, 2006 6:10 pm
Quoting Wardialer (Thread starter):
If it's very very sensitive - I assume you've got backups of the data. Take a backup of the backup and ship your computer (don't go for next-day - which, as you observe, costs a bit).
Are you sure your PC will work here? i.e. 220v 50hz. You will have to change the plugs too - if it's not so new, buy yourself a new PC (including Apples) over here.
PhilSquares
Fri Jul 21, 2006 6:31 pm
I'd suggest getting another quote, US$1000 seems extremely high. Another option is to remove the hard drive and take it with you. Purchase another computer in Europe and add the second hard drive in.
I assume you realize your CRT monitor, if you have one, won't work in Europe. So it might be cheaper just to get a whole new unit.
Fly fast, live slow
eddieho
Fri Jul 21, 2006 6:37 pm
Quoting ANother (Reply 5):
Most ATX towers do have power converter switches at the back, accepting 110v and 220 v.
ANother
Fri Jul 21, 2006 6:42 pm
Quoting Eddieho (Reply 7):
... and many are smart enough to do this without a switch - but I suggest that the threadstarter might just want to check this small detail.
SkyexRamper
Sat Jul 22, 2006 5:44 am
$732.75 FedEx International Economy Freight®
For a computer box 36"x36"x24" valued at $1200 @ 20lbs to be shipped from MKE to Berlin.
Though my best suggestion for making sure your pc arrives there in one working piece if you're truly worried. Ship a new case to your new address and then just take out all your pc parts and put them into a suitcase (provided you have anti-static bags for everything.
[Edited 2006-07-21 22:46:45]
Good Luck to all Skyway Pilots! It's been great working with you!
adh214
Sat Jul 22, 2006 6:09 am
For $1,000 pull the hard drive and buy a new computer when you get to Europe.
or
Remember, the computer got to your home somehow. I don't think Fed Ex is any more delicate with parcels than baggage handlers. If you pack it well, it should be fine. Clearly you need to have a back up of your "Very sensitive" data.
Finally,
If the data is really that sensitive (meaning it would be valuable to someone else) take the hard drive with you in your carry on.
Just note, because the data is valuable to you does not make it valuable to someone else. No one really cares all that much about your iTunes collection or porn.
Andrew
wardialer
Sat Jul 22, 2006 11:49 pm
I have a power supply thats meant to convert from 115 to 230....No worries there, and yes, I got like 12 plugs...
Jano
Sun Jul 23, 2006 12:20 am
Ship the PC (without HDs) by USPS. A friend of mine was moving back to the Czech Republic not too long ago and she paid $1.6 per lb. However, it took about 6 weeks for her boxes to arrive.
The Widget Air Line :)
474218
Sun Jul 23, 2006 12:29 am
I think you may have problems with customs when you arrive, they may want import duties. Unlike laptops, which are portable, a full sized PC is not meant to be carried with you and they will think you are bringing it in, but will not take it back out.
727EMflyer
Sun Jul 23, 2006 1:30 am
I agree with those suggesting you hand carry the hard drive and buy a new machine when you get there. Heck, with companies like Dell who deliver the units via mail, you might be able to coordinate a new one arriving at the same time so you don't have to go shopping!
But if you insist on keeping the old machine, it really is a better idea to check it. You can contact the manufacturer for original packaging which will protect it very well, or you can invest in a good hard-side shipping case. There are a lot of good manufacturers, notably Pelican. All the cases will come with plenty of foam lining, and many even have wheels to make moving it around a cinch.
Ken777
Sun Jul 23, 2006 2:14 am
Personally I would get on the internet and price computers and computer parts in the country you are going to. It might be significantly cheaper to take the HD, stick in a cheap one and sell your computer before you go - buying a newer one in Europe. The other option is to buy a laptop here, transfer the software and data to it and sell your old tower.
I prefer the notebook option as I use one and hook it up to a 23" display in the office. They have also jumped up in power recently - even the iBook replacement (the MacBook) from Apple comes with a dual core processor and using an app called Parallels allows you to run both OS X and Windows at the same time.
APFPilot1985
Sun Jul 23, 2006 2:55 am
Quoting Ken777 (Reply 15):
its actually called boot camp
Stand Up and Be Counted Visit Site Related to Voice your opinion
