airnewzealand
Qantas Avod Aircraft, Here Are The Regos And YVR..
Sat Jul 22, 2006 10:43 am
Here are the regos for all those wanting to know about QF AVOD aircraft...
Regos Are...
VH-OEB/OED/OEE/OEF
VH-OJE/OJG/OJI/OJJ/OJP/OJS/OJU
So there are 11 aircrafts with AVOD on it.
QF73/74....SYD-SFO-YVR v.v will ALWAYS have an AVOD aircraft scheduled.
Currently -OED and -OEF are operating this trip.
Hope this is of some assistance!!
All the best
optionscle
RE: Qantas Avod Aircraft, Here Are The Regos And YVR..
Sat Jul 22, 2006 3:23 pm
I flew on OJJ less than two weeks ago and it did not have AVOD. Was it done between then and now?
ZK-NBT
Sat Jul 22, 2006 8:27 pm
Quoting OptionsCLE (Reply 1):
Hmm, interesting, from the lists I have seen I thought OJJ was one of the first aircraft to get AVOD. Maybe not.
airnewzealand
Sat Jul 22, 2006 8:32 pm
OJJ certainly has AVOD...
I have operated on this aircraft more than a dozen times.
The AVOD system is still experiencing problems, thus, if you were in YC you would of been blocked out from using the features and only allowing around 10 movies which operate in a cycle.
Hope that helps.
SA7700
Sat Jul 22, 2006 9:53 pm
Quoting Airnewzealand (Reply 3):
Any idea when it is going to be rectified? I came back home on OJJ, at the end of June and the system was virtually unusable. Fortunate for me I had some work to do. The fact that we had the most superb cabin crew, that I have ever experienced in J-class, on the upper deck; made the flight a breeze.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
optionscle
Mon Jul 24, 2006 6:49 pm
Thanks for the info. I was, indeed, in Y and we had 10 channels running 2.5 hour cycles as you said.
