fewsolarge
Delta & LAX: Back To The Future
Tue Jul 25, 2006 10:07 am
We all know the story of Delta's squandering of the LAX hub inherited from Western. Then there's the complete dismantling of the Transpacific experiment in the 90's, which included nonstops from LAX.
Now some of Delta's reorganization attention is starting to focus on Los Angeles. New routes, albeit mostly on RJs, are starting to a variety of destinations in Mexico. Also, as confirmed by statements by Jim Whitehurst to employees, Delta is considering L.A. as its West Coast staging location for anticipated Transpacific growth (when aircraft permit).
Can Delta accomplish what it failed to do before, in the face of established international incumbents and strong domestic LCCs? They have the gates and a good overall presence in the West. But they lack service in the most important markets, up and down the coast.
How would UA, AA, NW, and CO respond? If there were a melee at LAX over the next few years, who would be the last ones standing?
STT757
RE: Delta & LAX: Back To The Future
Tue Jul 25, 2006 10:11 am
Has DL sorted out it's gate lease problems with the LAX folks?
Alitalia744
Tue Jul 25, 2006 10:22 am
Quoting STT757 (Reply 1):
they're working on it but i wouldn't expect any gates to be returned at this point.
Some see lines, others see between the lines.
worldtraveler
Tue Jul 25, 2006 12:09 pm
in a nutshell, yes, DL can do what it couldn't do before. Former management simply failed to execute against some pretty basic aspects of making their transpac operation work - like having LAX-FLA flights connect w/ flights to Japan. Current management isn't taking excuses of why things can't work as evidenced by the success of JFK. If DL is able to do at LAX half of what it has done at JFK, DL should have no problem doing what it wants to do.
As for the competitive response, no other airline has the facilities and airplanes to stop DL. AA would be the most likely candidate but they don't have the airplanes unless they pull planes off of some current routes. Rumors do say they are cancelling several flights so the question is what they will do with them. Other than AA, I don't see any other US carrier as a real obstacle to DL accomplishing what it might want to do.
SLCUT2777
Tue Jul 25, 2006 12:21 pm
Keep in mind DL still has quite a significant feed into LAX from both hubs at SLC and ATL. The previous management regime knew nothing about how to make LAX work as Grinstien, Whitehurst and Bastian. Keep in mind Grinstien was the last CEO of Western Airlines and the primary architect of the Western merger with Delta back in 1986-87. LAX is clearly the best trans-Pacific point on the west coast of North America, much as NYC-JFK is on the eastern shore for the Atlantic. DL can probably do more with it than people realize, and yes they will have new wide-bodies coming on line sooner than later.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
rwsea
Tue Jul 25, 2006 12:41 pm
LAX has a few things going for it as a DL gateway. Obviously the huge O&D, which often can command good fares. While LAX is well-served by international carriers, the only non-stops to Asia by US carriers are all to NRT, which in my opinion means that the airport is underserved.
However, LAX is not a good location for a hub or gateway, and it is further from Asia than SEA or SFO. Either of those cities would make better gateways if DL wanted to focus on connecting pax. But if they wanted to focus on the LAX O&D pax, it would be a great place for them to do it.
Quoting SLCUT2777 (Reply 4):
Disagree. SEA-NRT and SEA-HKG are about 700 miles shorter than LAX-NRT and LAX-HKG respectively. NRT-SEA-JFK is 736 miles shorter than NRT-LAX-JFK (I know JFK-NRT would probably choose to go non-stop, but that's moot for the sake of this argument). SFO is about 300 miles closer to Asia than LAX. Most flights from SEA to Japan at least can be operated with only one aircraft; LAX generally requires two. Obviously LAX's passenger base would help compensate for these geographic shortcomings, but I wouldn't call it the best trans-Pacific point. If we're comparing to the Atlantic, LAX would be more comparable to ATL than JFK in terms of location.
centrair
Tue Jul 25, 2006 12:57 pm
DL could come back big time. But they don't have the planes to do it.
Though LAX is furhter south than SFO or SEA, it has a much larger and diverse population that can contribute to higher O&D. There is also the economic factor. LA has more money to spend as a metro area than the other two (corporation wise). Now SFO has the tech valley and SEA as Tech and industry, LAX has those two and more.
The key for DL will be to have good connections from LAX to other parts of the US and South America. They will also have to have a large variety of destinations out of LAX. It is't about NRT, KIX, NGO, PEK, PVG or HKG. Its about the up-and-coming destinations.
DL will have to do to LAX was CO did to EWR. Thin Hub-point routes to destinations underserved that can produce O&D and C/F passengers. DL served four destinations in Japan before pulling out. They would have to go back and re-open NGO, KIX and FUK. Plus they would have to tap MNL, CTS, TPE, KHH, CAN, CKG, DLC, and a ton of airports in China that will be opening to international service in the next few years. These are places where a 777-2 or SMALLER might be needed but could produce great revenue for DL.
I for one think that this is going to be the next big thing. But DL can't do it. They don't have planes and will not for years. NW will have their 787s up by 2009 and have options for 30 more or something. They can build up MSP, SEA and DTW big time and sooner than DL could even get started at LAX.
My name is Centrair but HND is closer. Let's Japanese Aviation!
SLCUT2777
Tue Jul 25, 2006 3:11 pm
Quoting RwSEA (Reply 5):
That is my point, the size of the LA market (roughly 17 million and change!) makes it the ideal west coast gateway to the US. It is 2.5 times the size of the San Francisco Bay Area and much bigger still then Seattle. SEA-TAC might be the closest west coast airport to Asia, but it is inhibited by its proximity to YVR which is better still and is also Canada's Pacific gateway. Much of the Puget Sound people go ahead and drive 3 hours north and deal with the border to get a much larger selection of trans-Pacific flights out of YVR, and similarly people from metro-Vancouver drive down to SEA-TAC to catch a domestic USA flight rather than deal with the premium price charged for a trans-border flight into the US.
DAL767400ER
Tue Jul 25, 2006 5:51 pm
IMHO, the future of DL at LAX will depend what loads they can achieve on their new flights. Their advantage is that they have started a few routes that were not served from LAX, like CMH, BDL or RDU, and will add a few more, especially in Mexico, as ASA's application for 6 news routes has been granted except for one, which DL delayed themselved due to security issues (don't ask the city names, can't access the DMS site at work).
If these flights prove successful, and DL continues to focus on markets not yet served from LAX, and don't try to enter already saturated markets, like the intra-California market, LAX might have a good shot at finally becoming a VIH (Very Important Hub) for Delta again. Even more so if DL were to finally get EMB-190s, which would allow them to add even more thinner transcons, e.g. to JAX or TPA for example, perhaps even YYZ, and upgrade the Mexico CRJ routes. Don't really see too much activity coming south of the border except for Mexico, and Asia is still quite a few years off.
worldtraveler
Tue Jul 25, 2006 9:48 pm
Geographically, it is true that the Bay Area and the Pacific NW are better positioned but it doesn’t make any difference if there is no market there. UA is huge in SFO in addition to all of the Asian carriers. AA tried to capture a piece of the market from SJC and failed. The only way another US airline will be flying a large Asian operation from the Bay area is if they buy it from UA.
SEA doesn’t have the airport infrastructure to handle a large int’l hub operation and if they did the carrier setting up that operation would have to compete with AS to set up the domestic connecting flights.
LAX is a huge market which has largely not been developed by US airlines. I hope DL does move in and aggressively develops LAX. It will work very well as a southern tier gateway to Asia in addition to serving the huge Southern California market.
Quoting Centrair (Reply 6):
…and probably will by only after they get their house in order on the east coast.
We may begin to see some longhaul flying from LAX by next summer but it probably will begin developing LAX-Asia before this decade is out. In order to make LAX work, DL needs to:
- finish the terminal negotiations and not lose control of any gates.
- continue to succeed over the Atlantic and be comfortable that they have taken a leadership role in the markets they deem important on the east coast. It makes no sense to begin developing LAX if they leave NYC open for a competitor to come into markets or regions DL has set up to win in.
- improved product. Asian airlines offer very high quality products. DL is moving in the right direction but they need a consistent high quality product to succeed in Asia. DL has historically had one of the best airlines from a customer service perspective and they will need to be at least that good if not better to succeed in Asia.
- longhaul airplanes. The 767 can fly LAX-Japan but there is a lot more of Asia than Japan. DL could have 4 more 777s by 2008 which would be enough to pick off a couple of key longhaul routes in addition to what the 767s can do but it is doubtful that DL will start building up LAX until it knows it has the financial capability to acquire more longhaul airplanes. The 777 or 787 could work. Asia will require new airplanes to develop while DL has largely been able to grow over the Atlantic through fleet reallocation.
- domestic feeder traffic. There is no reason DL can’t provide it but no one just rolls over and opens their markets. Several carriers are bigger than DL at LAX and DL must increase its overall domestic presence at LAX in order to provide the efficiencies necessary to support an int’l operation.
DL can certainly do all of these things but they will only take on LAX-Asia once they have the financial strength and the international successes over the Atlantic to justify developing a new frontier.
panamair
Tue Jul 25, 2006 10:29 pm
Quoting WorldTraveler (Reply 9):
Couldn't agree more. While it is certainly possible for DL to develop LAX into an international hub, the effort and money required, not so much for the physical elements (e.g., terminals, aircraft), but for the 'softer' aspects such as marketing or re-orienting (no pun intended) people's views about DL as a significant transpac carrier out of the West Coast, will make the recent transatlantic and JFK expansion look like a walk in the park. At JFK, DL has already had a "Top Three" presence for a while now, including an already-established transatlantic presence; this round of JFK buildup as a real hub is relatively inexpensive compared to what it would take at LAX. DL needs to focus on making JFK a success first before turning to a riskier and more complicated situation such as LAX.
BigGSFO
Tue Jul 25, 2006 10:57 pm
I always thought the three major Skyteam airlines could establish a world class hub at LAX: DL, CO and NW. Hear me out: they develop T2 and T3 into one big terminal and combine schedules of the three carriers. NW/KL could use their expertise across the Pacific (NW), Atlantic (KL/AF) and Midwest (NW); CO through the West/Latin America; DL the East, Caribbean, Mexico. Although an expensive and complicated undertaking, it's feasible and could operate nicely. Each airline could claim LAX as a hub with a minimal dedication of resources.
I know it's a crazy thought, but it's possible...
DAL767400ER
Tue Jul 25, 2006 11:30 pm
Quoting BigGSFO (Reply 11):
If such a close cooperation were to ever happen, it would be from T5 and T6, due to a few reasons:
-DL and CO are already there, with both of them having a larger LAX presence than NW.
-More gates and newer interiors
-Underground tunnel beyond security between the 2 terminals.
airzim
Wed Jul 26, 2006 12:09 am
Statements like this show you have no credibility. I think UA, AS, WN, and AA would beg to differ on your assumption. Delta would get slaughtered in LA if they tried to set up a hub. They also don't have near enough planes and facilities to handle the fantasy hub.
I hate to burst your little pie in the sky bubble, but LA is tapped out. Airlines are retrenching from LAX to Asia not increasing. Why? Because new aircraft like the 777 are able to overfly West Coast hubs nonstop to most Asian destinations from pretty much anywhere in the US. There is absolutely no rational argument to not justify keeping LAX exactly what it is, a high yield O&D station.
Asia is primarily driven by wholesaler traffic in the back cabin. Lots of negotiated volume discounts. There is already way too much capacity to Japan and the only way NW and UA make it work is by hubbing Narita.
Overall point-to-point traffic is weak between the US and Asia. AA and CO's recent flights to China have not been performing that great. SQ has said both their EWR and LAX flights are not profitable. TG's services to LAX and JFK are also not profitable.
Outside UA and NW, why do no other US carriers fly to Seoul, Taipei, Singapore, and Bangkok when they have planes already capable to flying to those places? Because the markets are just not that great and the NRT hub for UA and NW is the only way that makes it work. There are a few select markets that justify nonstops from interior US but not many.
Lastly cargo is highly directional. They come over full but fly back with junk.
Asia is not as great a market as many people think.
MalpensaSFO
Wed Jul 26, 2006 1:20 am
DLC, CKG to LAX? That would be stretch of the immagination.
KHH would work with CI using a 343
CTS would work on NWA using a 332
MNL is served by PR 2x daily and is low..low.. yielding
TPE is served 39 x Weekly by CI, BR, SQ, MH
CAN is served daily with DL partner CZ with the 777.
TO FLY IS TO SERVE
travelin man
Wed Jul 26, 2006 1:44 am
I think you have to look at LAX from an Alliance perspective, not just an airline perspective. The reason US airlines have not aggressively developed trans-Pacific routes from LAX is because for the most part, their alliance partners have handled it.
For instance, United only has two Asian/Pacific destinations on UA metal (NRT, SYD) from LAX. However, through its Star Alliance partners, UA actually offers the following destinations:
AKL (NZ)
APW (NZ)
BKK (TG)
ICN (OZ)
NRT (SQ, NH)
PPT (NZ)
SIN (SQ)
TPE (SQ)
So basically, LAX is acting as a Star hub.
For AA, LAX is in a similar situation, with JL, CX, and QF providing most of the trans-Pacific operations. So AA provides one Asia/Pac destination on AA metal (NRT), but its alliance partners are currently offering:
AKL (QF)
BNE (QF)
HKG (CX)
KIX (JL)
MEL (QF)
NRT (JL)
SYD (QF)
DL is in a different situation, because Skyteam is pretty weak at LAX. The only trans-Pac Skyteam flights are NRT (KE, NW), ICN (KE) and PPT (AF).
That would mean DL would have to generate a lot of its own traffic (much moreso than UA or AA). Combining efforts with CO and NW may help, but Skyteam's weakness at LAX is a pretty significant barrier to overcome. And DL really doesn't have the planes right now (as noted).
I think DL's strategy of starting secondary North American markets with no current service to LAX could be a good one, however. If that feed could link into future Pacific expansion, it might work. But DL will be facing some pretty entrenched competition. And DL has cut LAX so significantly, that I will have difficulty believing it until I actually see DL putting more effort into the West Coast.
cxb744
Wed Jul 26, 2006 2:15 am
Also weather. When SFO gets socked in with fog, they go down to one runway operations. Not good for connecting passengers. Until SEA, gets there third runway up and running, which is soon, they are confined to one runway ops during bad weather. And both these cities see a lot of bad weather. LAX doesn't.
Quoting Airzim (Reply 13):
There are only two cities over-served based yours and MalpensaSFO's data: Narita, & Taipei. Everywhere else passengers have to pay a premium to fly other "nonstop" cities because there is no competion on those routes. People "in the back cabin" will go to their destination via the cheapest route and right now that's through Tokyo because of the competition. If DL enter the picture with non stop flights to Asia from one US city, like CO is doing from EWR, then prices will start to moderate and load factor should rise = profit.
What is it? It's A 747-400, but that's not important right now.
MalpensaSFO
Wed Jul 26, 2006 2:54 am
Quoting CXB744 (Reply 16):
What?
Seoul is served 35 x per week - No need for additional service
Hong Kong is served 21 x per week - No need for additional service
Bangkok is served 4 x per week - Yields are not grear as per Thai
Singapore is served 14 x weekly 1 stop/7x weekly nonstop - Delta would be better off commiting suicide than going up against old partner SQ.
Shanghai is served 7 x per week - No need for additional service
Beijing is served 7 x per week - No need for additional service
Possible holes in the LAX crown:
SGN - Served with UA from SFO via HKG
NGO - Served with UA from SFO
KIX - JL will discontinue in October? Served with UA from SFO
DPS/CGK - Low Yield, ex GA route
Upcoming additions (rumoured):
PR CEB-ICN-LAX via 343
That theory may have worked a few years ago when Continental started is Newark bombardment of the international market. Todays World is different. While Delta may be able to make Europe sustainable from JFK. LAX will never resemble ATL or JFK for Delta Airlines. Delta gave up a number of years ago on service to Taipei, Seoul, Hong Kong, Bangkok, Singapore, Osaka, Nagoya, and Fukuoka. Since then the 777 and 343/346/345 have entered the market and other airlines have gained as Delta has slept in Atlanta with the Euro saturation. The branding of Delta in the Asian region has faltered over the years, and Continental and American along with old hats United and Northwest have all been more than happy to see Delta Airlines when they left the markets.
TO FLY IS TO SERVE
cxb744
Wed Jul 26, 2006 2:59 am
Quoting MalpensaSFO (Reply 17):
Appartently CX disagrees with you as they are thinking of adding a 4th daily service to LAX. There is still room for flights between LAX & Asia.
You are right, Delta should study hard before picking routes.
MalpensaSFO
Wed Jul 26, 2006 3:20 am
Quoting CXB744 (Reply 18):
There is strong talk of a TPE-SFO via CX or 2nd HKG-SFO by CX, as well..
Delta, has missed the boat as far as LAX to anything East is concerned..
TO FLY IS TO SERVE
airzim
Wed Jul 26, 2006 3:43 am
There are only two cities over-served based yours and MalpensaSFO's data: Narita, & Taipei. Everywhere else passengers have to pay a premium to fly other "nonstop" cities because there is no competition on those routes. People "in the back cabin" will go to their destination via the cheapest route and right now that's through Tokyo because of the competition. If DL enter the picture with non stop flights to Asia from one US city, like CO is doing from EWR, then prices will start to moderate and load factor should rise = profit.
I could not disagree more. Couple of things you've overlooked, the demand to almost every Asian destination except NRT and MNL is small compared to the beyond connection opportunities. Korean Air and Asiana are carrying local Korean traffic and bucket fares to SGN, India, China and Manila. Same with Cathay Pacific, China Airlines, Eva Air etc. Similar to UA and NW, the hubs on the Asian end are the only justification for flying as much capacity as they do. Plus for years the 747's were the only planes that could actually make it nonstop to the US, that's changing with more Asian carriers flying 777's to the States.
Let me assure you, there is no "premium" on nonstop flights. Most Asian carriers negotiate the bucket fares on the O&D not on the routing. Plus your example about Tokyo is actually the inverse, since NRT actually enjoys a significant yield premium over any beyond city in East Asia.
"If DL enter the picture with non stop flights to Asia from one US city, like CO is doing from EWR, then prices will start to moderate and load factor should rise = profit."
This statement makes absolutely no sense.
I'm shocked but I actually agreed with MalpensaSFO for once. Except when he started blabbing about Delta branding in Asia. For 90% of the econ Asian passengers on transpac flights, they are only flying on that carrier since Good Fortune Travel agent on Kowloon negotiated a good rate that day on that sector. Same is true of KTB, KNT, and JTB in Japan. They're all negotiated volume discounts done twice a year every year for the last 50 years. You don't get FFP miles on these bucket fares so trust me, they could care less who they fly. It's whatever travel agency put their package together.
cxb744
Wed Jul 26, 2006 5:08 am
Quoting Airzim (Reply 20):
Maybe not from Asia, but from the US, you bet there is premium to fly non-stop to Asia. Look at any major US travel website.
Example: LAX-HKG, its cheaper to go on United via Tokyo, or China Airlines via Taipei than it would to go non-stop on Cathay.
Why? Because Cathay as a monopoly on the non-stop service. Having 3 flights a day discourages any other airline from entering the non-stop market for fear of not making money on the route (over capacity).
If DL will have the balls to take on these routes, especially into China, they can make money on the passengers to Asia, and Cargo on the return journey.
Same for travelers from the US. However, the farther you travel non-stop the more you pay, i.e. traveling from the West Coast of the US to Europe; it's cheaper to connect throught ORD or the East Coast than to go non-stop.
Again, why? No competition on the long distance routes.
lincoln
Wed Jul 26, 2006 5:36 am
Quoting DAL767400ER (Reply 12):
I think what you're saying is makes sense, but I think if (and that's a gigantic if) this were to ever happen, terminal 2 would be involved.
The biggest reason.... Northwest (along with a two or three others, including if I'm not mistaken Hawian, via LAX TWO Corporation) physically own -- not lease, but own -- the Terminal 2 building, where Delta and CO lease their space in Terminals 5 and 6.
Terminal 2 is also easier to get to at LAX, second only to, well, um-- Terminal 1. The underground cross-terminal access issue could be delt with in a number of ways from some sort of overhead bridge to a shuttle service to even digging a tunnel.
I would also hesitate to call CO an expert in the West, I consider them (but by no means am an expert) to be much more of a midwest/east-competent airline... However, all of the airlines (or at least, NW and CO) have a close relationship with Alaska, who if I'm not mistaken is already in T3 at LAX who could fufill the west-coast needs quite well.
Though DL's new podiums in T6 at LAX look quite nice... now if only UA and CO would replace their cardboard crap that's falling appart. (the DL podium at gate 69A, in particular looks way out of place between the UA and CO podiums)
Lincoln
MalpensaSFO
Wed Jul 26, 2006 5:37 am
Quoting CXB744 (Reply 21):
False!
That is false if I have ever heard it!
LAX
XSFO UA 1154 Q * 20NOV 1000 QLXAPHK 20NOV20NOV PC
HKG UA 0869 Q * 20NOV 1215 QLXAPHK 20NOV20NOV PC
XSFO UA 0862 Q * 27NOV 1250 QLXAPHK 27NOV27NOV PC
LAX UA 0979 Q * 27NOV 1020 QLXAPHK 27NOV27NOV PC
USD 929.00 20NOV06LAX UA X/SFO UA HKG460.00QLXAPHK UA
X/SFO Q4.25 Q4.25UA LAX460.00QLXAPHK NUC
USD 180.00YQ 928.50END ROE1.000000
USD 5.00YC XT USD 14.50US USD 14.50US USD 5.00XA USD
USD 77.43XT 7.00XY USD 7.50AY USD 15.43HK USD 13.50XF
USD 1191.43 LAX4.50SFO4.50SFO4.50
150.00 USD PENALTY APPLIES
ENDOS VAL UA/NONREF CNL PENALTY CHANGE FEE APPLIES
LAX
HKG CX 0885 H * 20NOV 1125 HLXSPCL 20NOV20NOV PC
LAX CX 0882 H * 27NOV 1625 HLXSPCL 27NOV27NOV PC
USD 897.00 20NOV06LAX CX HKG446.50HLXSPCL CX LAX Q
4.25 446.50HLXSPCL NUC897.25END ROE
USD 115.60YR 1.000000
USD 63.43XT 7.00XY USD 2.50AY USD 15.43HK USD 4.50XF
USD 1081.03 LAX4.50
100.00 USD PENALTY APPLIES
ENDOS NONEND
PAYMT NON-REFUNDABLE
25JUL06 PER GAF REQUIREMENTS FARE NOT VALID UNTIL TICKETED
NOVEMBER
CATHAY PACIFIC IS LESS EXPENSIVE THAT UNITED AIRLINES
LAX
HKG CX 0881 H * 20APR 0155 HLWSPCL 20APR20APR PC
LAX CX 0884 H * 27APR 1320 HLWSPCL 27APR27APR PC
USD 969.00 20APR07LAX CX HKG482.50HLWSPCL CX LAX Q
4.25 482.50HLWSPCL NUC969.25END ROE
USD 1153.03 LAX4.50
ENDOS NONEND
LAX
XSFO UA 1154 Q * 20APR 1000 QKWAPHK 20APR20APR PC
HKG UA 0869 Q * 20APR 1303 QKWAPHK 20APR20APR PC
XSFO UA 0862 Q * 27APR 1145 QKWAPHK 27APR27APR PC
LAX UA 0858 Q * 27APR 1055 QKWAPHK 27APR27APR PC
USD 1019.00 20APR07LAX UA X/SFO UA HKG505.00QKWAPHK UA
X/SFO Q4.25 Q4.25UA LAX505.00QKWAPHK NUC
USD 180.00YQ 1018.50END ROE1.000000
USD 1281.43 LAX4.50SFO4.50SFO4.50
APRIL
CATHAY PACIFIC IS LESS EXPENSIVE THAN UNITED AIRLINES
TO FLY IS TO SERVE
airzim
Wed Jul 26, 2006 5:51 am
If Asian originating traffic wasn't 75% of the load, this statement may actually have credence. In the case of the Japanese carriers, its closer to 90%.
Looking a published fares on the web to determine fare premium is like asking a fortune teller what you'll have for breakfast in two weeks.
This would only be true if every passenger on CX's flights was from LA. All Asian carriers have interlines with every US inbound carrier to LAX. In the published world, why connect when you can go nonstop from LA. But the majority of pax are from around the US so they are competing with UA, CO, SQ, and AC for one stop flights non stop from the mainland, in addition to the multitude of connections over Tokyo, Seoul, Taipei etc. Even though I keep saying the published fares don't matter, but comparing Tulsa or Miami would be more fair. Secondly you assume all things are equal, we have no idea what the traffic mix and yield dynamic is on the CX flight. You're looking at a snapshot in time, not a very good baseline in my opinion.
I'm not picking on Delta, nobody can do this. China is not a great market, the traffic is overly one directional (from Asia), and the cargo yield from the US to Asia is abysmal. LAX is never going to be a good Asia hub for any US carrier.
Give the airlines like AA a little bit of credit. Don't you think AA, with by far the strongest potential in LA, would fly all over Asia if there was potential? Or even UA? Fact of the matter is, outside Tokyo which supports local traffic and connection feed on partners, is the only city that will work from most spots in the US.
Comparing apples to oranges. Asian and European traffic are completely different beasts. I'd agree that nonstops will GENERALLY demand a higher yield premium. But not always.
Actually the only way to understand airline pricing is to not try and find logic in a nonsensical business. In some cases I've built itineraries that became cheaper the more segments I added.
But here's where the Asian and European examples merge, the European airlines dominate the transatlantic market from the West Coast and JFK. Why? They have a hub on the other end to distribute the network. No US carrier can honestly say they have a capable European hub on the West Coast. That's why UA and AA can't support many flights and only to major business centres like LON. I would argue the same is true of JFK since neither UA or AA have a hub there. UA can support 5 flights a day from ORD to LHR because of the hub, no other reason.
Jamake1
Wed Jul 26, 2006 6:20 am
If one thing the legacy airlines have learned in a post-9/11 environment, it's that it is extremely difficult to play second fiddle to another carrier's encumbent service at a hub city. That is why United left Miami, Delta left DFW, and AA having nearly surrendered San Jose. It would take considerable (limited) resources to build up a sizable trans-Pacific operation at LAX and my sense is that Delta will not have the means to devote its resources to such an undertaking, freshly out of Chapter 11. The risks, IMHO, would be too great as Delta still lacks a significant market presence on the westcoast.
United's B747-400. "She's a a cruel lover."
cxb744
Wed Jul 26, 2006 7:37 am
Quoting Airzim (Reply 24):
 checkmark
Quoting MalpensaSFO (Reply 23):
NOVEMBER
APRIL
On United I stand corrected. But, with China Ailines, Delta (Korean Air), Asiana and EVA, I'm right both dates mentioned!
kaitak744
Wed Jul 26, 2006 7:46 am
Well, I think its a great idea for a U.S. carrier to finally get in on the huge LAX-Asia market here. A few aspects run in its way. As it was mentioned earlier, their isn't much skyteam partnership at LAX, hence code-shares would be harder. And, the terminal problem. T5 has only 1 gate for 777 sized aircraft right? That would permit say around 9 daily departures. So, NRT, KIX, TPE, PVG, PEK, SYD?, AKL?, ICN, CAN. Wouldn't they want to do more than that?
And it is very unlikely DL would move out of T5.
skgsjulax
Wed Jul 26, 2006 8:48 am
Quoting MalpensaSFO (Reply 19):
 checkmark   checkmark   checkmark
...and the boat aint comin back
Omnium curiositatum explorator
ikramerica
Wed Jul 26, 2006 9:45 am
The real question is: would DL be smart to use jets on those routes to asia or instead to use jets to expand to other locations, since their long range jets are scarce. It's not just a matter of working in a vacuum, but opportunity cost of not spending your capital elsewhere...
The flight ran for far too many years for you to make this kind of statement. SJC-NRT made sense for years and years until the tech sector in the bay area began to cool as well as become more decentralized.
Further, when AA de-hubbed and then de-focused SJC, it cut out the residual feeder traffic for this route.
Finally, AA added LAX-NRT, and "reversed" the feed on this route. Where 3 years ago from LAX, AA would book you LAX-SJC-NRT, now form the bay area they will book you SJC-LAX-NRT.
Times change, markets change, but considering the flight ran for a good 15 years, it's harsh to call it a failure...
murrayusa
Wed Jul 26, 2006 10:23 am
I would love to see Delta make LAX a hub but honestly I do not see it happening. As stated earlier they do not have enough fleet at this time.
The complex economics that LAX presents is why I assume why Continental walked away from this market as a major hub in the 1990’s and focused on IAH and EWR. I know they still have plenty of flights and an alliance with Alaska on the west coast. When I traveled to the west coast a bunch on 2000 I used to fly the America West code share because they offered so many options and super easy upgrades, however,I boarded an American West air craft it seamed a much lesser product than Continental.
As a side note, when I read Boeings plans for the 787 and 777 ER I think there are so exiting options for airlines that want to expand their Asia operations from many airports that in Southern California will be perfect for these planes.
Sorry if my post is a bit off topic but I am on major pain medications from a sinus surgery today.
 cloudnine
ikramerica
Wed Jul 26, 2006 10:37 am
Quoting Murrayusa (Reply 30):
Had the same experience.
B777ER
Wed Jul 26, 2006 3:28 pm
Quoting Fewsolarge (Thread starter):
IMO, too many Intl carriers and US legacy already clog LAX-Asia routes. Wish they would go back to PDX like they did in 80's/90's and stage out of there.
worldtraveler
Wed Jul 26, 2006 10:02 pm
If you would read what is written in context instead of cutting and pasting a sentence just for the sake of argument, we could actually have a discussion. Every paragraph above my posting and all of the paragraphs since have talked predominantly talked about transpac service. To throw WN and AS in the discussion shows you either want to argue more than discuss or you shoot your own credibility to pieces.
Face it, you have tried to shoot down my credibility regarding DL time and DL again and yet time and time again I have demonstrated that I am in fact right. Within a couple weeks, we’ll see DL’s financial results and they will be in complete contradiction to your assertion that DL was a hopeless basket case that would never survive. In fact, I’m certain you’ll see more international service announced in the next couple weeks.
Quoting Travelin man (Reply 15):
I have said before and will say again that airlines do not make network decisions based on their alliance partners; they make them with their own profitability in mind. Alliance partners can help make a flight work and fill in the map where a carrier cannot fly with its own aircraft but carriers WILL serve a route if it makes sense for them to do it regardless of what their alliance partners think. CO, DL, and NW have not focused on the LAX-Asia market because of network strengths elsewhere. That doesn’t mean they are giving it up to Skyteam partners.
I’m sure the airlines of every one of those countries would argue strongly against you. S. Korea is one of the top 10 economies in the world. To say there is no market there is simply ridiculous. Taipei is indeed much smaller while SIN and BKK have been beyond the range of nonstop flights from the US. The A345 changed that although the economics won’t work for that plane but it sure will for the 777-200LR, the 787, and the A350 when it finally flies.
Interestingly, Seoul and Taipei are the home of 2 DL partners. KE is a founding partner of the Skyteam alliance yet no US carrier serves ICN (PRG is the other Skyteam partner not served by a US carrier which also argue for why CO and DL are interested in serving PRG). There is probably a very good likelihood that CO, DL, and NW will all begin ICN service in the next 2-3 years just because KE is a well-run airline now and ICN provides great access to Asia.
All Asian airlines serve the consolidator market but a major benefit of an alliance is the ability to provide enough connections to help fill a plane. That is precisely why KE can operate far more transpac service that their local market would dictate but that is the nature of int’l aviation. ATL alone cannot support the 20 or so transatlantic flight DL offers each day; MIA could not support the dozens of flights AA sends to S. America; EWR could not support the dozens of flights CO flies to Europe by itself. Every one of these cities benefits from the hub that exists in that city and allows the hub carrier to offer more service than the local market would allow. And it is not necessarily low value traffic. To say that KE only carriers trash beyond ICN is completely false. Every hub airline has a mix of lower yielding traffic to their gateway and beyond but KE could certainly not sustain flights to SE Asia without some decent yielding transpac connecting traffic. And you also fail to note that the entire Asian travel market is growing very quickly, meaning that even if DL gets in on the growth now, they will get a piece of the action even if they always remain well behind other established carriers in size.
UA is clearly set up in SFO so it’s a lot easier to see why they have not tried to develop LAX. The fact that they gave up any growth aircraft for several more years is probably the other, making it impossible for them to defend their Asian franchise.
AA can’t seem to figure out what it wants to do in Asia. First, they say they re dying to buy UA’s Pacific network, then they try to build their own Asian gateway (more later), and now they are picking off a few routes here and there from their hubs. The answer may be because AA doesn’t have that many 777s available for transpac growth and because AA has some of the highest costs in the industry.
In fact, UA and AA are both right back where they were at 9/11 with the highest costs in the industry among their US peers. High costs don’t work at home but they sure don’t work to Asia where the home carriers are very competitive. CO, DL, and NW all will have lower costs than AA and UA and have the resources to grow to Asia in the next couple years. UA will be doing good to defend what it has while AA will have to pick off a few strong routes from their interior hubs, unless they get their costs down and acquire aircraft to grow.
Quoting Jamake1 (Reply 25):
While true, no legacy carrier truly dominates LAX in the sense that occurs at a true hub. And legacies also duplicate each other’s service on the same routes. Like BOS, LAX is ripe for a legacy carrier to come in and take a leadership position at the airport. And DL has shown at JFK that even with a LFC present, it is very possible to build a strong domestic presence, esp. if the domestic presence is primarily there to support a large international operation. UA and AA’s domestic flying at LAX has little support or connection to its international operation.
Quoting Ikramerica (Reply 29):
SJC-NRT is not the only transpac flight AA ran from SJC. You’ll recall that AA pulled its short-lived TPE flight at 9/11. Coincidentally, DL pulled back its west coast transpac flying after 9/11 too. How can you brand DL as a loser when AA did the same thing except that AA continued to operate their SJC-NRT flight even though AA execs say it has lost money for years.
DL simply had the good sense to pull back from west coast-Asia after 9/11 and is now ready to return to the market with a new cost structure, improved service levels, and with the financial strength to buy and retrofit the aircraft necessary to win in the market.
LAX continues to be an undeveloped market from the perspective of US network carriers who manage to compete effectively against foreign flag carriers in every region of the world. Sure, developing an LAX-Asia presence will be tough but nothing in life that is worthwhile is given to you easily. DL can and will win in Asia and they have stated they intend to make LAX their primary gateway to Asia. I don’t think we’ll see new route announcements to Asia from DL in the next couple weeks but we will see them in the future and DL will win, just as it has in all of the markets it has successfully launched this summer against equally long odds.
airzim
Wed Jul 26, 2006 10:42 pm
Quoting WorldTraveler (Reply 33):
Buddy that is exactly what you said. If you can't write in context that's not my problem. Are we suppose to just guess what you're thinking?
You are so full of yourself. I don't recall anytime where you've proven me wrong against any of your assertions.
I'm sorry but that is in fact the case. You go on and on in mundane paragraphs talking in circles and fantasy to try and prove that you can actually construct a logical thought. Trying to refute your ridiculous statement is like talking to a wall. Fact is your just babbling garbage.
I'll say it again, I'm not picking on Delta. No US carrier can build a logical transpac hub in LAX. Never.
I've listed the reasons above, and you've attempted to refute them, except only with conjecture.
Where do you get this stuff? Seriously are you in third grade? I'm telling you nobody can make LAX work. If Delta moves into LA they will get there ass handed to them just like every other time they've tried to fly to Asia. Oh and by the way, the Asian carriers can destroy any US carrier on CASM Full Stop. Delta's apparent cost cutting isn't going to make any difference to Singapore Airlines or Cathay Pacific.
LOL. You're a joke, what is this high school.
Come on Delta, you just didn't try HARD enough last time. The new uniforms and seats are going to make a huge difference this time around. No, that's not it, it's the new cost structure that's going to beat everyone that's been flying to Asia for 50 years. Geez if you only prayed a little harder last time maybe it would have worked. I mean don't even worry about the market dynamics since they apparently irrelevant to World traveler.
I wouldn't be surprised if Delta starts back up to Asia. It just solidifies that morons continue to run that company. Good luck in the blood bath.
panamair
Thu Jul 27, 2006 12:06 am
yet no US carrier serves ICN ..... There is probably a very good likelihood that CO, DL, and NW will all begin ICN service in the next 2-3 years just because KE is a well-run airline now and ICN provides great access to Asia.
I assume you mean no US carrier currently serves ICN from LAX...NW does NRT-ICN while UA serves SFO-ICN. For Skyteam's purposes, ICN is still not that developed a hub yet (e.g., some markets only have single daily flights that are mis-timed for certain connections). KE may have to grow some more or consolidate more of its onward connecting intra-Asian flights into specific times in order for ICN to be a truely powerful hub.
[Edited 2006-07-26 17:07:37]
travelin man
Thu Jul 27, 2006 1:12 am
I think you totally missed my point about the strength of alliances at LAX. I'm not saying that airlines within an alliance "ask permission" to fly a particular route. I'm saying the flights coming into an airport can make a flight work, whereas if an airline was trying to basically go it alone (a la DL at LAX), it would be MUCH MUCH more difficult.
For instance QF feeds AA domestic at LAX. AA feeds QF trans-Pacific at LAX. Do you think that AA has given a second though to flying to SYD using their own metal? Of course not! They don't need to!
However, given Skyteam's weakness at LAX, the business proposition for DL starting trans-Pacific flights is totally different. They will be mostly relying on their own limited feed for travelers going TO Asia, and relying on their own feed + limited KE and NW travelers FROM Asia.
You said:
"carriers WILL serve a route if it makes sense for them to do it regardless of what their alliance partners think."
Well, yes. But a strong alliance presence definitely helps on the "making sense" part of that statement.
You said:
"I have said before and will say again that airlines do not make network decisions based on their alliance partners; they make them with their own profitability in mind."
Quite frankly, those things are not mutually exclusive. It's not an either/or situation. In general, a strong alliance presence at an airport will determine the profitability. Or else do you really think AF would be flying CDG-CVG?
ikramerica
Thu Jul 27, 2006 1:20 am
I didn't. You bitch about being misquoted and then you just make things up about other people. Talk about hurting your own credibility.
The only argument I have against DL at LAX is that they have better opportunities elsewhere and have limited jets to do it with. You have yet to address that...
incitatus
Thu Jul 27, 2006 1:36 am
Isn't it a **LITTLE** early to claim success?
Conservatives against Trump
worldtraveler
Thu Jul 27, 2006 2:05 am
Quoting Incitatus (Reply 38):
No. Not regarding DL's current restructuring and not regarding ts ability to succeed in LAX or any other gateway it wants to develop, even if some people who profess to be from a particular country that starts w/ Z are so hell-bent in denying DL's ability to successfully restructure itself and grow that they wouldn't admit that DL has succeeded if God Himself told you so. And if I was so inclined, I could pull dozens of Mr. Z's postings and show you line by line where he wrote that DL would fail on issue after issue and yet they have succeeded. He and everyone else knows what he wrote and his hatred and inability to recognize DL's ability to turn itself around will belong increasingly obvious, making him look more and more like the mental midget he tries to make others out to be.
ord
Thu Jul 27, 2006 2:10 am
Quoting Airzim (Reply 34):
United already tried taking a dominant position at LAX. Back in 1995 they had 183 daily flights (mainline, not express). This was boosted to 217 flights to 54 cities by 1999, when LAX became an official United hub and United had a 30% share. But United could not compete on many shorthaul routes with the likes of Southwest. Several markets were eventually turned over to United Express.
I just can't see Delta becoming the dominant airline in LAX. United had a far greater presence to start with and could not make it work. And LAX is not ripe for an airline to dominate. The market is too fragmented with United, American and Southwest all having large shares.
For a trip down memory lane, check out part of this 4/27/99 United press release:
"United Airlines today officially designated Los Angeles International Airport (LAX) as a hub for the airline, a status marked by the frequency of flights and number of destinations served by United from LAX and highlighted by the completion of extensive terminal renovations and other passenger amenity improvements. United's $260 million upgrade at LAX is scheduled for completion on May 15, 1999.
'A world class city needs a world class airport,' said Pete McDonald, United Airlines managing director -- Southern California. 'The improvements we've made at LAX provide customers with the facilities and services that they'd expect at a hub. In designating Los Angeles as a hub of the world's largest airline, we are confident that our facilities and services are up to the standards we require for a hub airport.'
Carrying 30 percent of all passengers to and from LAX, United is the airport's largest airline by a significant margin. This includes United's domestic and international mainline service, as well as United Express service to local California markets and United Shuttle short-haul service to major West Region destinations. United's LAX hub offers customers 139 destinations worldwide, including 37 transcontinental flights to nine U.S. East Coast business centers. The airline also offers 48 non-stop flights to other key U.S. cities, the most non-stop flights offered by any carrier at LAX. United also offers 12 non-stop international departures -- more than any other carrier."
airzim
Thu Jul 27, 2006 2:13 am
Quoting WorldTraveler (Reply 39):
Which is funny since you have refuted nothing I've written except with fantasy statements and conjecture.
Time will tell if DL succeeds in their current strategy. It's way too early to call it a success. But any rational analysis looks like they are doomed to failure.
and yet you continue to spew nonsense statements like this. Get over yourself.
ORD, I didn't write what you quoted, but I agree with you 100%
[Edited 2006-07-26 19:18:46]
Alitalia744
Thu Jul 27, 2006 2:16 am
Quoting Airzim (Reply 41):
Typical response from your mouth.
airzim
Thu Jul 27, 2006 2:26 am
Quoting Alitalia744 (Reply 42):
could say the same about you. Others are more diplomatic than me, but what ORD posted is exactly the type of analysis needed. You continue to ignore reality is your problem.
For some earthly reason, Delta lemmings think Delta miracuolusly works in another universe where logic doesn't exisit. Hate to break it to you, they're not.
You want to follow management down the garden path, good luck to you.
I stated no airline can make LAX a viable transpac hub. ORD proved that United couldn't even do it who undoubtedly has/had the best opportunity. Why you chose to believe Delta is any different is beyond me.
worldtraveler
Thu Jul 27, 2006 2:33 am
Every analysis has some basic assumptions and presuppositions that shape how the data is analyzed. You found plenty of people who came up with a “rational” expectation that DL would fail. I found equally as many that said DL would successfully restructure. I didn’t call you inability to read or do your own analysis – you’re just wrong. You can try to rationalize the reasons why you are wrong. All I care about is that you were wrong. And your ability to talk intelligently about DL is permanently colored by your errors.
I have plenty of UA timetables w/ their large LAX operation and I’ll been to their sprawling complex at that airport. It says nothing about DL’s ability to make LAX work because UA decided not to. I’m sure one of the reasons DL chose to downgrade DFW and CVG is because they were too close to ATL just like AA chose to downsize STL because of its proximity to ORD. Very few airlines have hubs as close together as LAX and SFO are; even fewer have large international operations at hubs that close.
Of course it’s too early to say with certainty that DL will succeed. However, I have posted over and over again that I exhibit far more understanding of what is going in the industry by being able to post something well before the press releases come out than those of you that jump on the bandwagon once it becomes apparent something is winning. It doesn’t take a whole of intelligence to be a naysayer until the facts come out that ultimately contradict your incorrect “forecasts” at which time you finally become a reluctant supporter.
FlyPNS1
Thu Jul 27, 2006 2:46 am
Quoting WorldTraveler (Reply 44):
Like that time last spring when you said DL would not file bankruptcy. Yeah, you're a real Nostradamus!!
As for LAX, I wouldn't get your hopes up. While DL may grow LAX some, major transpac expansion is not in the cards. Any transpac growth for DL will come from the East Coast before the West.
Alitalia744
Thu Jul 27, 2006 3:01 am
Quoting Airzim (Reply 43):
AirZim - find me a quote where I said Delta was smooth sailing and I'll buy you a beer.
Do I want Delta to succeed? yes they're my favorite airline. Do I think they can do so easily? NO! They've made a series of bad business decisions stemming from bad management, lack of direction, no objective and throwing widebodies blindly at competing routes just to maintain market share. Furthermore, a few months of a "operating profit" do not indicate future success.
As for being a lemming who does not see things for what they are and continuing to ignore reality? Sorry bro, I live and breath in reality everyday and if you want to have a discussion on that, let's. Sitting in the hospital and watching friends die from HIV is the everyday reality I live in, so the next time you wanna question that, feel free, but realize what a stupid comment it is.
If you have anything else to say, please do.
incitatus
Thu Jul 27, 2006 3:04 am
No.
It is. Regardless of whatever writing comes out of other posters - sometimes apparently intent on raining on your parade - you do come across as somebody writing from inside the fish bowl.
For Delta to claim success at JFK, the operation has to be sustained for a good two years. We haven't even seen a Winter yet. Delta keeps tweaking frequencies across the Atlantic, most often down. Even a major route like JFK to Rome will be down to only 5 times a week in the off-peak months.
To claim that Delta can come from a loser position in L.A. and make it into a big operation is another very long optimistic stretch. Anybody can fill up flights to Asia, but it's another story to be able to do it and charge more than $199 each way.
ord
Thu Jul 27, 2006 3:14 am
I apologize, my mistake. The quote should have been attributed to WorldTraveler.
ord
Thu Jul 27, 2006 3:25 am
I'm sure one of the reasons DL chose to downgrade DFW and CVG is because they were too close to ATL
I'm a big fan of Delta, but DFW was not downgraded in part because of its proximity to ATL. If anything, DFW was in a prime spot to flow traffic from places like Louisiana, Alabama, etc. (Delta strongholds) to the west coast. The hub was closed because it lost money in something like 13 out of the last 15 years and Delta simply could not compete with American in that particular market.
