Curious
Why Do Airlines Still Use The 732
Wed Jul 26, 2006 2:12 am
Why do some airlines(esp in developed countries) still use the 732? it cant just be the cost of fleet renewal?
SLCUT2777
RE: Why Do Airlines Still Use The 732
Wed Jul 26, 2006 2:14 am
Quoting Curious (Thread starter):
Probably the same reason NW still uses the DC-9.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
DIJKKIJK
Wed Jul 26, 2006 2:16 am
It is not just the cost of fleet renewal. The 732 is an excellent airframe, and several of the ones which are still flying have a number of hours left on them. So there is no reason to replace them.
Never argue with idiots. They will bring you down to their level, and beat you with experience.
UN_B732
Wed Jul 26, 2006 3:22 am
Yep, Aerosvit Ukrainian has one for example, UR-BVY. They don't want to get rid of -BVY, regardless of how beat up it is, since it's owned, like the NW DC-9
-Mr. X
What now?
flydreamliner
Wed Jul 26, 2006 3:23 am
Quoting SLCUT2777 (Reply 1):
What is everyone going to talk about on A.net after NW retires the last DC-9?
"Let the world change you, and you can change the world"
SPREE34
Wed Jul 26, 2006 3:27 am
Because they can make money flying it. $$$$$$
I don't understand everything I don't know about this.
gunsontheroof
Wed Jul 26, 2006 3:30 am
Because they're sweet!
Seriously, I'll be sad when they're gone and I never got a ride.  Sad
Picked a hell of a week to quit sniffing glue.
MCOflyer
Wed Jul 26, 2006 3:36 am
AS, DL, and AQ uses them in the US.
AS uses them for freight ops but is replacing them with 734F.
http://www.alaskasworld.com/NEWS/2006/06/28_freighter.asp
DL is replacing them with CRJ's, and another type (presumbly 738).
AQ uses them for inter island routes and for freighter routes. I guessing the 738 will replace them if the load factors demand it. Otherwise im guessing the 736, or the 735. In another thread it said the 732,735 and 736 had the same specs.
MCOflyer
zvezda
Wed Jul 26, 2006 3:41 am
Airlines evaluate the higher cost of operating older aircraft versus the cost of buying newer aircraft. It's about that simple. In the particular case of the B737-200, it the operating costs on very short routes are not too bad compared with newer aircraft. For longer routes, it's worth replacing them.
Curious
What about fuel, they do drink a lot?
isitsafenow
Wed Jul 26, 2006 4:07 am
Quoting FlyDreamliner (Reply 4):
The Aloha 737-200..........
 boggled  safe
If two people agree on EVERYTHING, then one isn't necessary.
yow
Wed Jul 26, 2006 5:16 am
Some airlines like First Air and Canadian North still use them as there is no viable alternative jet to use on gravel air strips.
rwy31r
Wed Jul 26, 2006 5:33 am
SV continued to use thier sterdy 732's years after they recieved the total 29 MD-90's they purchased to repace the 732.
I believe the main reason they kept them was because a few airports in Saudi were not ready to handle anything bigger or planes that needed longer runways, like BHH.
By now, with the introduction of the Embraer 170 they have retired them where many of them are stored at ELQ.
I will miss the long JT8D engines. Classic and unique!
"Saudia Three Five hold short Three One Right"
N231YE
Wed Jul 26, 2006 6:23 am
Quoting MCOflyer (Reply 7):
Actually, I read somewhere that Aloha was in the market for used 737-200's, having something to do with the CFM-56s of the later 737s burning more fuel on such short inter-island flights than the P&W JT8Ds, making them uneconomical.
A332
Wed Jul 26, 2006 6:35 am
Ugh... if it's not about Northwest DC-9s... it's about 737-200s being old, unsafe, beyond their time... geez.
Bad spellers of the world... UNTIE!
474218
Why do some people drive old Minis, maybe it's because that's all they can afford.
Quoting Curious (Reply 9):
You can buy a lot of fuel for the price of a 373NG or an A320. By the way they burn the fuel, they don't drink it.
MCOflyer
Wed Jul 26, 2006 6:39 am
They do to the 732 to what FX did to the DC-10 30/10 series. It'd be a hellva site. At least install hush kits to the 732's.
MCOflyer
FL370
Wed Jul 26, 2006 9:16 am
they use the plane because its a classic, a plane that everyone loves and will miss. like the 707, and the 3holers that NW flies. classic that will never leave.
darrenthe747
Wed Jul 26, 2006 9:34 am
it's too bad the 727 is retired. oh how i miss her. Sad
All animals are created equal, but some are more equal than others.
PGV
Wed Jul 26, 2006 9:37 am
Quoting A332 (Reply 14):
Yup...
But when the 9's are gone, who else will be left around to shake windows and lay down the smoke on take-off!?!
"To hell with a Ferrari...give me a Super 70!"
KELPkid
Wed Jul 26, 2006 9:41 am
Compare the MTOW of the 732 against later variants (especially the NG series...).
It becomes apparent that the 737 series has evolved (along with customer needs) from being primarily short-haul, medium capacity lift to being on the mid to high end of the narrow body spectrum, medium range. Along with that, the later 737's are carrying around lots of extra weight-not needed for the short-haul role it was originally built for. Therefore, the newer 737's are burning a lot more fuel on the 30 to 45 minute hops with quick turns that the 732 was designed for...
AirbusA6
Wed Jul 26, 2006 9:51 am
Quoting KELPkid (Reply 20):
Surely there must be some older 733s and 735s going cheap now? These would be more economical....and pass noise and pollution emissions rules
it's the bus to stansted (now renamed National Express a6 to ruin my username)
KELPkid
Wed Jul 26, 2006 10:05 am
Quoting AirbusA6 (Reply 21):
From A.net's own AC data entry on the 735:
The 737-500's main appeal is for operators of large 737-400 and 737-300 fleets, as because the 500 is a shortened development of the 300, it still carries much of the structural weight needed for the higher weight models. This makes it less efficient than if it was designed specifically for its size category, however for operators of large 737-300/400 fleets, the extensive commonality benefits more than compensate for this.
The 732 isn't nearly as dirty as, say, the Convair 990, the 707 w/Conways, or a myriad of other vintage jetliners that I've seen leave smoke trails  Smile
thering
Wed Jul 26, 2006 10:11 am
A fleet renewal is not that simple and easy. Beleive me, if it was, you would only see 737NGs, A320s, 777s, A330s, A340s flying around...
146 319 320 321 332 722 732 733 734 735 73G 738 742 743 744 762 763 772 773 CRJ ER4 100 F50 F27 M11 D10
zippyjet
Wed Jul 26, 2006 10:33 am
An addage in our industry: We use everything from the piggy except the squeal! or, everything on the cow except the moo!
These old birds may consume fuel the way Christy Brinkly's cad hubby consumes teen girls but, if they hold up, it is still cheaper than buying new.
I'm Zippyjet & I approve of this message!
afterburner
Wed Jul 26, 2006 11:18 am
For some of them, especially startup LCCs, it's the only type of aircraft that is affordable.
Wed Jul 26, 2006 11:32 am
How are they unsafe? Old does not mean unsafe.
jetdeltamsy
Wed Jul 26, 2006 11:54 am
Because they're paid for.
Tired of airline bankruptcies....EA/PA/TW and finally DL.
ba286
Wed Jul 26, 2006 11:56 am
Quoting Isitsafenow (Reply 10):
   safe
I get to fly on one in a week from Honolulu to Hilo. According to other a.netters i have asked the Aloha 732s are in good shaped and well maintained. They are about 25 years old.
BA286
E190 A318 A319 A320 A343 ATR42 717 732 733 734 735 737 738 744 752 772 DC-10 MD-11
pwm2txlhopper
Wed Jul 26, 2006 12:12 pm
I believe in the case of Delta, some of their 737-200's were some of the last off the production line. That was in the late 1980's and that wasn't all that long ago. I'm sure there are plenty of 757s, 767s, A320's, MD-80s that are older than some of the -200's still in the sky.
I just watched one of Delta's 737-200's depart PWM for CVG a few hours ago and it was a beautiful machine that I wouldn't hesitate to step onboard. With the new paint it looked as good as new.
[Edited 2006-07-26 05:17:46]
[Edited 2006-07-26 05:18:06]
[Edited 2006-07-26 05:18:29]
