nwafflyer
Self Reclining Seats
Wed Jul 26, 2006 8:39 am
I've flown too may NWA flights lately, where the seat (first class) - reclines the moment you sit in it -- same seat has you upside down during takeoff
It doesn't matter what you do with the button on the side - the seat does it all by itself
I don't think this is particularly safe, so - first time it happened, I notified the flight attendant - next thing I knew, I was back in middle seat, aisle 12. That isn't satisfactory, so now I try and literally hold the seat in it's position, and I don't report it (or my back/neck muscles) to the FA
Are there any other alternatives?
brettdespain
RE: Self Reclining Seats
Wed Jul 26, 2006 8:47 am
Keep reporting it. It is a safety issue for ground evacuations. If you keep having problems, write a letter to customer service. Often, they can offer you some incentives to keep you as a customer.
I know this sounds terribly obvious, but also make sure your leg or knee isn't touching the button. (I know, I know but it still happens to me once in a while.)
Brett
V1...Rotate.
SFOMB67
Wed Jul 26, 2006 9:10 am
These are called "rockers." Broken recline mech.
cvg2lga
Wed Jul 26, 2006 9:49 am
WOW! I thought maybe I was just crazy the first time, but then today I thought well I should get to the gym. Now I realize its probably a little of both and this new revelation. I flew ORD-LGA on 7/22 and the seat would not stay up, made me feel like an idiot the whole flight to LGA, especially on t/o and landing. Then this afternoon, I board another flight back to ORD and the same dang thing! But what can you do? Just go with the flow.
And I did make sure, cause at first I thought ok I must be touching the button, but after careful consideration not too it still happened. Great service on AA this weekend.
Tchau
DA-
They don't call em' emergencies anymore. They call em' Patronies.
Outlier
Wed Jul 26, 2006 10:26 am
This really should be "Broken Seats"
Motorhussy
Wed Jul 26, 2006 9:56 pm
Fly a different airline perhaps?! Unless you're in Detroit.
MH
come visit the south pacific
bond007
Wed Jul 26, 2006 10:20 pm
Quoting Nwafflyer (Thread starter):
In First Class seats it seems to be fairly common. I fly 4 legs/week and I must have been in 2 or 3 seats past few months that had the same problem.
Quoting Brettdespain (Reply 1):
Keep reporting it.
Problem is....2 weeks ago I was on US air flight. Guy in FC reported problem ... engineers came onboard and spent an HOUR trying to fix seat. Couldn't fix it and ended up removing seat! The poor guy who had a FC seat had to get next flight!
Jimbo
baroque
Wed Jul 26, 2006 11:04 pm
You are lucky the FA did not blame you for causing the problem! Gulf FAs especially do not like to be told of faulty seats, you end up feeling you personally caused all the trouble.
L1011
Thu Jul 27, 2006 6:09 am
Over the past two weeks I was on two different KLM MD-11s in economy, and both times the seat kept reclining by itself. I tried to keep it up during takeoff and landing when the flight attendants walked by, but it was impossible to keep it up all through the meal service. Thankfully, the person behind me didn't complain. I've had this happen on quite a few flights. I don't report it before takeoff on a full flight because they might put me off. I usually tell them as I am deplaining, since by then I am already at my destination.
Bob Bradley
Richmond, VA
Fly Eastern's Golden Falcon DC-7B
JAFA
Thu Jul 27, 2006 2:09 pm
If this happens please tell the crew otherwise it won't be fixed. As a last resort tell they crew before deplaning. Otherwise it will continue to fly around that way. Preflight checks don't involve checking the recline mechanism.
Some seats can be fixed by pulling forward and then pushing it back into its upright position. Others can be fixed by holding in the recline button and "pumping the seat back" between its reclined and upright postition.
Mendaero
Thu Jul 27, 2006 11:12 pm
The recline actuator (hydrolok) could be stuffed, or it could be the recline button/cable could be binding, or the adjustment nuts on the end of the actuator could have come loose, stoping the actuator from locking. Either fault, it is not usually a bid deal to fix, given 30 mins max. Locking it up is usually the quick fix. But if it cant be fixed or locked upright, the seat should not be sold.
ie "tray tables must be stowed and seats in the upright position for takeoff and landing"
bond007
Fri Jul 28, 2006 1:16 am
Quoting Mendaero (Reply 10):
On the US flight I was on, something like a metal pin actually sheared off! They tried to fix it so it was fixed in upright position but couldn't...after one hour delay missed my connection!
Jimbo
ZSOFN
Fri Jul 28, 2006 1:30 am
I remember a few years back my dad telling me that on an AC 744 flight (YYC-LHR) he reported the same problem, with much regret as it turns out, as the F/A reported it up front and departure was delayed a good 45 mins as someone came on to try to fix it. Apparently they were adamant that the aircraft was "unsafe" until fixed.
JohnKrist
Crew
Fri Jul 28, 2006 2:20 am
I had an experience like that on a UN leased Tu-154, when I sat down I fell into the lap of the person behind me and I had to sit upright for 4,5 hours with no backrest. When I complained to the russian crew they only said "no understand, no understand". That's safety at it's best, and not to mention the radial thread sticking out of the very well worn tires Big grin
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, 50mm 1.4, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
