dallasnewark
Turnaround Times For A380
Sun Jul 30, 2006 4:55 pm
Does anyone know, what are the estimates of a turnaround time for an A380?
You can just imagine LH boarding 600 people in Newark the same way Southwest does (i.e. free for all), would it take over 120 minutes?
I'm basing this on their turnaround times of a 747 is roughly over 90 minutes with the bulk of time loading the passengers.
I was on a lot of EWR-FRA flights, and from the time they announced boarding to a time everyone has boarded once I watched 2 quarters of a football game, not that's a lot of time.
A380 and EWR are a perfect fit, a.k.a. delays galore
B732/3/4/5/6/7/8/9, B742/4, B752/3,B762/3/4, B772/3, A306, A318/9/20/21, A332/3, A343/6, MD80/83/88, L1011, TU104/134, F
Aeroflot777
RE: Turnaround Times For A380
Sun Jul 30, 2006 8:04 pm
Well don't quote me on this but I was under the impression that Airbus always stated that their goal was to make the turnaround time the same as the 747. I read that in some press release.
In the long run though.. I really think it will all come down to the airline. Turning a a/c around efficiently means a lot of teamwork on the crew's part. Something tells me it won't be significantly more than the 747...
Aeroflot777
Picard
Sun Jul 30, 2006 9:02 pm
I thought the A380 loads and unloads passengers from both the top and bottom of decks at the same time?
So if the terminal has been designed for this job the turn around times shouldn't be any longer than a 747 / 777 or A346
Sun Jul 30, 2006 9:42 pm
Quoting Dallasnewark (Thread starter):
Airports with upper and lower deck gates, 90 minutes, main deck only 126 minutes, based on 555 pax.
A380-800 ASSUMED TURN-ROUND TIME PARAMETERS PASSENGER BOARDING/DEBOARDING (PB/D)
100% (555 pax) passenger exchange :
. Doors (type A - 42" wide) used : M1L and M2L (main deck) and U1R (upper deck).
. PB/D rate : boarding = 15 pax/min / deboarding = 25 pax/min
. Last Pax Seating Allowance (LPS) = + 4 min
. 60" stair flow rate : up-flow = 14 pax/min / down-flow = 18 pax/min
CARGO
Full LD-3 exchange (22 + 16) LD-3 and bulk exchange of 2 000 kg (4 409 lb) :
LD-3 off-loading/loading times :
off-loading = 1.4 min/LD-3 / loading = 1.7 min/LD-3
Pallet loading times :
off-loading = 2.5 min/pallet / loading = 2.9 min/pallet
bulk off-loading/loading times :
off-loading = 9.2 min/t / loading = 10.5 min/t
REFUELLING
Block fuel for Nominal Range through 4 nozzles :
. 261 200 liters (67 364 US gallons) at 40 psi (48 min)
. dispenser positioning or removal = 3 min (fuel truck change) / if any = 5 min
CLEANING
Full cleaning :
. Crew adapted to match catering time
CATERING
Full catering :
. average truck capacity = 30 Full Size Trolley Equivalent (FSTE)
. simultaneous catering and PB/D = not represented
. inbound/outbound FSTE = mixed in the same truck
. FSTE exchange time :
- dedicated door-galley = 1.5 min/FSTE
- cart circulation (1 seat zone) = + 0.5 min/FSTE
- cart circulation (> 1 seat zone) = + 1.0 min/FSTE
- via lift :
. dedicated door to single lift = 2.0 min/FSTE
GROUND HANDLING/SERVICING
. start of operations :
- bridges = t0 = 0
- others = t0 + 1 min
. vehicle positioning/removal = 2 min (fuel truck excluded)
. upper deck vehicle positioning/removal = 3 min
. clearance between GSE = 0.5 m (20 in)
. Ground Power Unit (GPU) = up to 4 ¡Á 90 kVA
. air conditioning = two carts
. potable water (standard/option) = 1 700/2 500 liters (495/660 US gal) at 60 l/min (23 US gal/min).
. waste water = discharge and rinsing
. dollies per tractor = 4 to 6
solnabo
Sun Jul 30, 2006 9:52 pm
Quoting Zeke (Reply 3):
Jeeh Zeke, that to me sounds like a Carnival cruise ship at Miami Harbor...
Thx for info.
Micke//SWE  wave
Airbus SAS - Love them both
cedarjet
Mon Jul 31, 2006 8:27 am
I wouldn't think it would take long. I've been doing a lot of longhaul on 747s recently and it never seems to take more than about 20 mins to load the aircraft. And unloading is always very fast - about eight minutes for a 747 to empty.
corey07850
Mon Jul 31, 2006 8:31 am
Quoting Cedarjet (Reply 5):
Say what?!
I fly a lot on 752's and the board time is always scheduled for 45 minutes before departure time... There's no way you can board a 747 in 20 minutes, assuming a decent load... And 8 minutes to deplane a 747 is just plane silly
dallasnewark
Mon Jul 31, 2006 8:54 am
Usually it takes over an hour to load the EWR-FRA flight on a 747, next time you're there take a look.
As far as eight minutes for a 747 to unload, that's sounds a bit too optimistic, I'd say at least 20-25 minutes for that thing to unload
AC320tech
Mon Jul 31, 2006 8:55 am
Quoting Corey07850 (Reply 6):
I agree, its about more than 20 minutes from first person on board to last person sitting down on a A340/330.
