apodino
Top 10 Mainline And Express Airports
Mon Jul 31, 2006 3:00 pm
I came across an article at work today that had a list of the top 50 airports served by regional carriers. Then I thought, with all the RJ's flooding the market, which airports have the most mainline service left in this country. So I did a little research, and some of these results may intrigue you guys. One thing to note, these numbers are US carriers only.
Top ten Mainline Airports (Most mainline departures each day)
1. ATL 754
2. ORD 564
3. DFW 557
4. MDW 513
5. LAS 496
6. PHX 489
7. LAX 446
8. DEN 433
9. MSP 332
10. MCO 327
Top Ten Express Airports (Most Regional Carrier departures each day)
1. ORD 593
2. ATL 407
3. IAH 389
4. CVG 356
5. CLT 350
6. DFW 311
7. PHL 304
8. DEN 291
9. DTW 271
10. IAD 259
Some other interesting tidbits I discovered.
Among airports that are considered hubs by major airlines CLE has the fewest number of mainline departures at only 75. Next fewest is CVG at only 81, followed by MEM at 89. (PIT has 87, but its only a focus city these days) Some interesting airports that have more mainline flights than these places include BNA, MCI, and PDX.
Half of the airports that are in the top ten mainline airports are Southwest strongholds.
Both ORD and ATL have more flights per day than all three new york airports COMBINED.
I thought I would throw this list out since we always have these RJ vs Mainline debates, and throwing stats, are there airports you think should see more mainline service, more express service, or what. And if you have any further questions about my research, I will answer them.
WeAreUnited
RE: Top 10 Mainline And Express Airports
Mon Jul 31, 2006 3:07 pm
Does this include all international flights as well?
Quoting Apodino (Thread starter):
Are you considering LAX a WN stronghold?!? I know they are large there- but isn't United the largest carrier at LAX?
LAXintl
Mon Jul 31, 2006 3:17 pm
Thanks for the post, however your numbers seem to be serious flawed when it comes to LAX.
For instance LAX has about 900-950 air carrier departures per day. Your list shows 446 mainline departures, but yet dont list LAX at all when it comes express movements.
Basically your numbers don't come close to the 900+ daily airline departures LAX handles.
SESGDL
Mon Jul 31, 2006 3:26 pm
Quoting WeAreUnited (Reply 1):
LAX is a WN stronghold, they are one of the 3 largest carriers.
Quoting Laxintl (Reply 2):
Something about the numbers is way off. ATL for instance gets over 600 daily DL mainline planes, over 230 FL flights, and about 100 other airline's flights. That should be closer to 950 mainline flights a day to the 754 listed.
Jeremy
apodino
Tue Aug 01, 2006 12:35 am
You didn't read my post carefully at all. The reason I didn't post express movements is because LAX is not in the top ten airports when it comes to express movements. LAX actually ranked 14th in the category. The source of my information is the Regional Airline Association, so the numbers are theirs, except in the cases of LAS and MDW, where I had to look up the info myself at airport websites.
The list I referenced said Daily nonstop departures by us carriers. It didn't specify if it included international or not. If it didn't include international flights, that could explain a few things. But I figured it did, since they actually included YYZ on their list.
Quoting SESGDL (Reply 3):
I am just telling you what the information I had said. Keep in mind, this is only total number of departures, not total number of flights. Also this is from January, when Delta probably had fewer flights per day as well.
commavia
Tue Aug 01, 2006 12:38 am
I thought AA's St. Louis hub had only 50-55 daily mainline departures, no?
LAXintl
Tue Aug 01, 2006 1:09 am
Quoting Apodino (Reply 4):
I read your post a couple times to try to understand the numbers, as they seem inconsistent.
I certainly understand LAX is not in the top-10 express departures category.
But the numbers simply dont add up. Neither international, nor foreign carriers make up the 400 or so daily flights to reach the 900 mark of air carrier departures LAX has.
As is, between between Southwest, United, American they equal about 320 of your listed "446 mainline departures" which would mean every other US airlines mainline departures had to fall within that 125 or so difference. Something simply not possible as other carriers such as America West, Alaska, Delta are busy themselves at LAX, not counting carriers such as Continenatal, Northwest, US Airways, Frontier, Midwest, Airtran etc..
I'd really be curious as to what the source and methodology of data is in the document you are looking at is using.
CentPIT
Tue Aug 01, 2006 4:34 am
Pittsburgh has 43 mainline departures, and 119 express flights, I am not sure where you got 87?? I am hoping to see the number jump back up to around 55 or 60 mainline flights as O&D continues to rise!
Pittsburgh International: US Airways---160 daily departures! (52 destinations)
mtnwest1979
Tue Aug 01, 2006 4:54 am
Quoting CentPIT (Reply 7):
Only 43 amongst all the airlines there? Or only US?
"If it ain't broke, don't fix it!"
vegasplanes
Tue Aug 01, 2006 5:17 am
Quoting Commavia (Reply 5):
I believe Apodino is quoting total mainline ops. (all airlines) for a hub airport, therefore STL has over 110 departures daily easily with AA and WN alone.
N766UA
Tue Aug 01, 2006 8:02 am
It's gotta be more than that. My count for August mainline is:
CO- 63 (give or take a couple, I used the pdf timetable)
WN- 20
NW- 8
U5- 6 (average, not all days have the same # of flights)
US- 3
DL- 2
UA-2
That makes 104, still not the best but better than 75.
[Edited 2006-08-01 01:20:51]
This Website Censors Me
TL8490
Tue Aug 01, 2006 9:07 am
This only makes sense if you read what he said....This are flight schedules for January...not the summer buildup.....
OH-LGA
Tue Aug 01, 2006 9:12 am
Interesting about LAX - would have expected more. In terms of daily departures, SkyWest is actually the largest airline in LAX with 141 daily departures.
Head in the clouds... yet feet planted firmly on the ground.
CentPIT
Wed Aug 02, 2006 4:36 am
Quoting MtnWest1979 (Reply 8):
I meant 43 for US in Pittsburgh! Sorry...
US-43
WN-20
NW-5
CO-2
DL-5
B6-6
FL-5
UA-6
I get 92 as of Aug. 3, 2006...so 87 for Jan. sounds about right!
