Boeing Nut
777LRF Update (Boeing Link)
Tue Aug 01, 2006 11:10 pm
Good article on the status of the 777 freighter program.
http://www.boeing.com/news/releases/2006/q3/060731b_nr.html
Wonder if the Pentagon is looking at this article? Hmmmm...  scratchchin
supa7E7
RE: 777LRF Update (Boeing Link)
Wed Aug 02, 2006 12:55 am
Quoting Boeing Nut (Thread starter):
Great question. The 777F is about the same price as a C-17, but longer range and carries about 20t more cargo.
Nah... the C-17 is a great warplane with capabilities (in-flight refueling etc) the 777F can only dream about.
"Who's to say spaceships aren't fine art?" - Phil Lesh
ehho
Wed Aug 02, 2006 1:05 am
Quoting Supa7E7 (Reply 1):
Now, let's try to land a loaded 772LRF on a 500 yard dirt strip. It's going to be fourth of July like you haven't seen it before.
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
rpaillard
Wed Aug 02, 2006 1:17 am
Hi,
It's good to see that the program is doing well. I'm also very happy to see the high level of interaction between AF and Boeing. I think it will be an trully amazing aircraft in cargo version. it will be interesting to see the cost improvement for AF against the current old 747!
I just can't wait to see it on AF livery.
Raphael
FLY SKYTEAM JETS
OldAeroGuy
Wed Aug 02, 2006 1:24 am
Quoting EHHO (Reply 2):
And how often does the C-17 use this capability? Most of it's missions are flown into paved runways that are useable by the 777F.
With regard to air-to-air refueling, the better MZFW range of the 777F (5000 nm vs 2400 nm) reduces the need for this feature and takes a load off the USAF tanker fleet.
There is probably room for both in the USAF inventory.
NYC777
Wed Aug 02, 2006 1:33 am
I think it would make a great tanker though windtunnel tests would have to make sure that turbulent flow doesn't disrupt the airflow over the wings of the trailing warplanes (fighter, etc).
That which does not kill me makes me stronger.
Stitch
Wed Aug 02, 2006 1:35 am
Quoting OldAeroGuy (Reply 4):
Before Boeing bought McD, they fought hard to convince the USAF to buy 747Fs instead of C-17s as they offered better operating economics and, as noted, many USAF ops are from improved airfields.
Of course, once Boeing bought McD, that went out the window.  Smile And I heard this morning the RAAF just bought four C-17s.  thumbsup
atmx2000
Wed Aug 02, 2006 1:40 am
Indeed, the C-17 is used to move a lot of palletized cargo around between military bases. For overseas missions, that would also require air-to-air refueling. A 777F-based tanker could be used to move more cargo given the higher payload and volume while reducing the need for refueling on long range missions. This will reduce pressure on the C-17 fleet as well, allowing them to be used for missions more suitable to their talents.
pavlin
Wed Aug 02, 2006 2:26 am
The 777F range is just awesome without refuelling. And the C-17 is way to expensive. The only thing keeping it living is taxpayers money. It just couldn't cope on civilian market.
sebring
Wed Aug 02, 2006 2:34 am
It may be the longest range twin ever, but it can't fly nonstop from Hong Kong to the West Coast of North America without refueling. It's no MD-11 or 744F.
OldAeroGuy
Wed Aug 02, 2006 2:39 am
Quoting Sebring (Reply 9):
You're right. The 777F has better payload-range capability than either of these airplanes.
sebring
Wed Aug 02, 2006 2:41 am
It may have better payload range characteristics but factor in the 90-minute fuel stop in Anchorage, with a likely additional crew change. Airlines don't live off specs alone, they also live with labor agreements, greedy airports with their landing fees, arcane customs and new safety regs. Making a stop in a third country is definite issue for carriers.
OldAeroGuy
Wed Aug 02, 2006 2:52 am
Quoting Sebring (Reply 11):
I'm trying to understand your point. The MD11F and the 744F are also subject to this fuel stop. What's the difference? Are you talking about the package freight range capability of the A380F?
To return to the other point, I didn't know the USAF had a labor contract. Why are they concerned about re-fueling stops or 16 hr+ air-to-air refueling missions?
phollingsworth
Wed Aug 02, 2006 2:58 am
Where are you getting this info? The LRF will have the same MTOW as the LR. It also has the same engines, this means that is should be able to take-off from HKG on a std+20°C day at MTOW. Now I don't know what the OEW or MZFW will be but it should allow over 120,000 lb of payload from HKG to the states, which is what the MD11F can deliver.
phollingsworth
Wed Aug 02, 2006 3:03 am
Quoting OldAeroGuy (Reply 12):
It really is about time and money, though the degree to which the USAF cares about this is debatable. fuel stops require friendly airfields (not that hard to find, but could get harder) and take extra time. Refueling is quite expensive I have seen numbers that suggest that tanker delivered fuel costs ~$250/gal.
Boeing Nut
Wed Aug 02, 2006 3:06 am
Off of Boeing's site....
747-400F.........248,600 lb payload - 4,450 nm.
747-400ERF......270,600 lb payload - 4,450 nm. or
.......................248,600 lb payload - 4,975 nm.
777F................229,000 lb payload - 4,895 nm @ 10.2 lbs per cu ft.
