luisde8cd
Continental Flight, What Is The Amadeus Res #?
Fri Aug 04, 2006 3:34 pm
Hi guys,
I bought a ticket with legs in both Continental and Copa. I wanted to check my itinerary through checkmytrip.com but I had no luck. From what I got from my travel agent, he gave me two confirmation numbers. One for the Copa flights and another for the CO flights. Both are 6 digits/letters codes.
None of them work in that website. Is there a way to find out which is the amadeus reservation number for my trip?
Thanks a lot for your help.
Saludos desde Caracas,
Luis
PA110
RE: Continental Flight, What Is The Amadeus Res #?
Fri Aug 04, 2006 4:04 pm
Luis,
Checkmytrip.com requires the Amadeus locator, not the individual airline's locator. That's why it won't work. If you have an invoice or itinerary copy from your agent, there should be a booking reference code printed towards the upper right portion of the document. This is the locator you need to use.
It's been swell, but the swelling has gone down.
haggis79
Fri Aug 04, 2006 4:07 pm
I have a similar question: I have booked a trip on Delta via their website - quite naturally I got only their locator, but not the Amadeus one. Are there any possibilities to find out the Amadeus locator as well?
Harald
300 310 319/20/21 332/3 343 AT4/7 143 B19 732/3/4/5/G/8/9 742/4 752/3 763/4 77E/W CR2/7/9 D95 E45/70 F50 F70 100 M11 M90
PA110
Fri Aug 04, 2006 4:08 pm
Perhaps I'm misunderstanding your situation... If you booked your trip on Delta's own website, there won't be any Amadeus record locator, because Amadeus has nothing to do with the booking. Delta does not use Amadeus.
haggis79
Fri Aug 04, 2006 4:24 pm
Quoting PA110 (Reply 3):
oh, ok... I didn't know that.... thanks for enlightening me  Smile
dcrusafon
Fri Aug 04, 2006 4:58 pm
You can only check itineraries with Amadeus locator in checkmytrip.com and Galileo locators in https://www.viewtrip.com/en-US/ViewTrip.asp
Dario
ehho
Fri Aug 04, 2006 6:17 pm
Anyone know for LX? I've booked on their website, and also got an alphanumeric code of 6 values, and also no luck on either Amadeus or Galileo..
Max
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
