Flying-Tiger
CRJ200PF Launched!
Fri Aug 04, 2006 9:10 pm
Well well well... very slow forum today  Wink
04.08.2006 07:15:00West Air Europe to Acquire First Bombardier CRJ200 Aircraft for Cargo OperationsBombardier Aerospace Launches Package Freighter Program
TORONTO, ONTARIO -- (MARKET WIRE) -- August 03, 2006 -- Bombardier Aerospace today announced that West Air Europe of Gothenburg, Sweden has signed a contract to acquire two previously owned Bombardier CRJ200 regional jets for conversion to an all-cargo configuration. Bombardier Aerospace has simultaneously launched the CRJ200 PF (Package Freighter) program.
West Air Europe, Sweden´s largest air freight carrier, currently operates scheduled and charter small package and airmail services within Sweden and to other points in Europe. Its current fleet is comprised of 17 turboprops.
"We require the Bombardier CRJ200 PF aircraft to fulfill specific customer demands for higher than turboprop speeds on routes of more than 575 miles (925 km)," said Gustaf Thureborn, President, West Air Europe. "So we are pleased to place this order with Bombardier. It is confirmation of our mission to meet the demand for efficient freight transportation with a customized aircraft fleet."
"The CRJ200 PF aircraft allows direct flights on longer, thin routes that are currently flown by larger aircraft," said Rod Sheridan, Vice-President, Asset Management, Bombardier Regional Aircraft. Since the introduction of the concept, considerable interest has been expressed by many prospective customers."
In the all-cargo configuration, the CRJ200 PF aircraft will have a cargo volume of approximately 1,700 cubic ft. (48.2 cubic m) and 14,000 pounds (6,350 kg). Maximum take-off weight will be 53,000 pounds (24,040 kg), the same as the high gross weight version of the CRJ200 aircraft.
About Bombardier
A world-leading manufacturer of innovative transportation solutions, from regional aircraft and business jets to rail transportation equipment, Bombardier Inc. is a global corporation headquartered in Canada. Its revenues for the fiscal year ended Jan. 31, 2006, were $14.7 billion US and its shares are traded on the Toronto Stock Exchange (BBD). News and information are available at www.bombardier.com.
Bombardier and CRJ200 are trademarks of Bombardier Inc. or its subsidiaries.
Contacts:
Marc Holloran
(416) 375-3030
www.bombardier.com
SOURCE: Bombardier Aerospace
Flown: A319/320/321,A332/3,A343/346, A380,AT4,AT7,B732/3/4/5/7/8/9,B742/4,B762/763,B772/77W,CR2/7/9/K,ER3/4,E70/75/90/95, F50/70/100,M11,L15,SF3,S20, AR8/1, 142/143,...
pavlin
RE: CRJ200PF Launched!
Fri Aug 04, 2006 9:19 pm
Quoting Flying-Tiger (Thread starter):
This is going for over a week now. Maybe all are on vacations.
I don't like that. It is really small
tinpusher007
Fri Aug 04, 2006 9:30 pm
Quoting Pavlin (Reply 1):
Consider a small cargo carrier, like Airnet for example. I wonder if they would any interest in this aircraft to replace their aging learjets.
"Flying isn't inherently dangerous...but very unforgiving of carelessness, incapacity or neglect."
Fri Aug 04, 2006 9:32 pm
So finally the daily ATP services by West Air at AMS will go to CRJ?
cobra27
Fri Aug 04, 2006 9:33 pm
Quoting TinPusher007 (Reply 2):
Small yes, but not economical
mauriceb
Fri Aug 04, 2006 9:35 pm
Oke it isn't much of cargo but they will use them for small private cargo loads, now how much space do you need when you wan't to send a ''small amount'' of cargo?
And there isn't a real competitor for this plane. i mean look at this:
AN-32 , pay load 6700 Kg, range 1200 km (fully loaded), speed 450 Km/h, fuel usage 2,4l/km
ATR-42-500, pay load 5810 Kg, range 1555 km, speed 460 Km/h, fuel usage 1,38 l/km
BAE / HS 748 Freighter , 5.000 kg 1.865km, 1.61 l/km, 450 km/h
BAE ATP Freighter, 6.700 kg ,1.065,km, 1.57 l/km, 470 km/h
BAE 146-100QT , 7.770 kg ,1.760km, 4.13 l/km ,800 km/h
Bombardier CRJ 200ER, 6,350kg, 2.570km, 2.28 l/km, 820 km/h
planes that carry more cargo are way slower, Use almost 2 as much fuel, and can't even come near the range or speed of the CRJ. I think there is a real market for the older CRJ's...
Not true at all, see the figures  Wink
[Edited 2006-08-04 14:36:23]
DAL767400ER
Fri Aug 04, 2006 9:38 pm
Why not do it? After all, there are enough used CRJs out there sitting in the desert, which could be bought/leased at VERY favorable prices. Now, I doubt there will be a flood of CRJ freighters coming, but there will definitely be a few hundreds in upcoming years. Never forget, cargo/parcel doesn't give a sh!t whether windows are on eyelevel or not  Wink .
mauriceb
Fri Aug 04, 2006 9:40 pm
True, and for the bigger parcel company's as FedEx it could be a really good plane for the routes that the ATR can't make, Wich they do have enough....
Buyantukhaa
Fri Aug 04, 2006 9:50 pm
Great idea!
Quoting DAL767400ER (Reply 6):
 Smile And it may not even have windows. That would be one great looking cargo plane!
I scratch my head, therefore I am.
LawnDart
Fri Aug 04, 2006 11:02 pm
Back in June of 2005, in a thread titled "Fed Ex 727 Replacement?", I stated:
As for smaller cities, what about a conversion for the CRJ? Payload wouldn't be that much of an issue, and CRJs will be available for 10 cents on the dollar in a couple of years...
A response followed from another member:
"Jets just are not and never will be as efficient as turboprops on short stages, and cargo isn't time sensitive (when you're talking the 10 to 15 minute difference between a jet and a prop) nor does it care that its being carried on a prop. Props are also much much cheaper to acquire. "
and my response was:
"I never said anything about short stages. And I understand that a 10 minute difference on a short segment isn't critical. My comment was in regard to smaller cities, but I should have clarified by stating "long, thin routes", where time becomes much more sensitive, especially to FedEx.
I realize FedEx (or a contractor) is using ATRs, but not sure if there are that many around - also, the used market appears to have picked up a little bit for them.
Mike Boyd believes (and I tend to agree) that the 50 passenger RJs have reached, or even passed their peak. If Independence goes belly-up, that's a chunk of potential conversions right there, and the price would certainly come down if a company approached the owners and offered to take the whole lot off their hands. Initial acquisition costs could even be lower than the larger ATR72.
I'm not technically savvy enough to know whether the CRJ could be converted, what type of performance penalty it would take, or if it would gross out (is that the term? Funny...) prior to bulk out. However, FedEx did start with the Falcon 20..."
Quoting MauriceB (Reply 7):
Alright, guys...let's scare up a couple of millionaires with money to burn and start a business!
tinpusher007
Sat Aug 05, 2006 1:05 am
I honestly think a company like Airnet could be interested in this aircraft. After all they use very old, and small, less fuel efficient Lear 35's...why not 'upgrade' to a CRJ/PF. Also remember with the new electronic checks, the need to fly cxld checks is diminishing and these types of carriers are shifting their business in response to that.
717-200
Sat Aug 05, 2006 2:59 am
Quoting TinPusher007 (Reply 10):
Another similar cargo operator that could possibly use the CRJ/PF is
Ameriflight who also have aged Learjets in addition to the hodgepodge
fleet of props.
72S 733 734 735 73G 738 742 752 763 E190 M82 M83
warreng24
Sat Aug 05, 2006 3:43 am
Quoting LawnDart (Reply 9):
Where have you been? Indy's long gone. Haven't you noticed the improvement at IAD?
CPDC10-30
Sat Aug 05, 2006 3:59 am
Quoting Warreng24 (Reply 12):
Here's your answer:
OMA2FAI2SAV
Sat Aug 05, 2006 4:56 am
The improvement at IAD? If you are talking about improvement in service, you must not have been there recently. It is back to UAX and their awful service. At DH, the agents were atleast friendly. And they tried. Something I have never seen a UAX employee even try.
If the best things in life are free, why am I always so broke?
bahadir
Sat Aug 05, 2006 5:08 am
You people suggesting this aircraft for AirNet; when was the last time you checked the company financials? AirNet is in no shape and form to afford these planes..
Earthbound misfit I
galapagapop
Sat Aug 05, 2006 11:19 am
Maybe some carriers in smaller FX cities would by interested? Wiggum A/C in MHT? They operate a handful of Cessna's on regional routes to feed the bigger jets that eventually come into MHT. Maybe they could use them to expand more longer thinner routes to help distribution of BOS area packages?
2H4
Sat Aug 05, 2006 11:45 am
If Airnet (and similar companies) needed the capacity of a CRJ-PF, they would have already purchased larger aircraft. The Learjets are very good at their missions, which very often involve the delivery of a single, small, critically-important package.
It's not uncommon for an automobile assembly line in Mexico (for example) to grind to a complete halt due to a single broken component. In cases like this, an auto manufacturer will gladly pay several thousand dollars to get that replacement part to the plant NOW, as each hour of downtime costs hundreds of thousands of dollars (or more).
This sort of mission is where the Learjets shine....and the added capacity of a CRJ isn't going to serve any benefit....especially considering the substantially greater acquisition costs.
2H4
Intentionally Left Blank
tinpusher007
Sat Aug 05, 2006 1:58 pm
Quoting Bahadir (Reply 15):
I believe I was the only one who suggested it. And I don't believe I have ever checked Airnet's finances, they are not exactly front page news like the airlines.
Quoting 2H4 (Reply 17):
Im not very knowledgeable about their business, but I stand corrected.
captainstorck
Sat Aug 05, 2006 3:38 pm
AirNet does need to replace their lears (quite badly in some cases) when they do replace them, it likely won't be with CRJs (or anything new, Bahadir is correct - they have been just barely clinging to life for a while now) As much as I would love to load or unload a cargo CRJ, I don't see it. Though the higher capacity would suit where the trend of the company is headed and they would still maintain their time efficency, the profit to pay leases on new airplanes just isn't there.
[Edited 2006-08-05 08:39:18]
We're Nuts
Sat Aug 05, 2006 6:11 pm
I thought the CRJ-200 already was a "package freighter".  Confused
Dear moderators: No.
malmoaviation
Sat Aug 05, 2006 9:20 pm
Great for Westair! Looking forward to see a CRJ200Freighter in their colors. I've only seen some turboprops from Westair at the remote aprons at Arlanda, but time has changed now  Smile
