modesto2
LAX Rwy 25L Closed?
Sun Aug 06, 2006 10:44 am
Why are they relocating LAX's 25L just a few feet south of its current position? Thanks.
LAXintl
RE: LAX Rwy 25L Closed?
Sun Aug 06, 2006 10:52 am
Part of the LAX Masterplan.
http://www.laxmasterplan.org/
A parallel taxiway will be built between the new 25L and current 25R to help reduce the number of runway incursions and while also helping to boost airport hourly capacity slightly. The 25L will also be slight longer than current one.
Work started last week with the entire runway & taxiway project is expected to run thru July 2008.
Big version: Width: 580 Height: 372 File size: 50kb
Construction Map
kaitak744
Sun Aug 06, 2006 11:37 am
Well, the press says the runway itself will open in 2007. Also, included in the construction plan are the two A380 gates at each end of TBIT.
Thanks for posting the picture though, I haven't this one yet
OPNLguy
Sun Aug 06, 2006 11:46 am
Memo I have said it'll be closed through March 26, 2007, FWIW...
AirWillie6475
Sun Aug 06, 2006 11:57 am
I have no idea how they're going to do it but here's what they are planning on doing:
http://www.laxmasterplan.org/video/LAXMPclipVideo.html
LAXintl
Sun Aug 06, 2006 1:28 pm
Runway work should be complete by March 2007, however taxiway construction will take the project thru July 2008.
Big version: Width: 580 Height: 152 File size: 7kb
Timeline
Kohflot
Sun Aug 06, 2006 2:20 pm
And if the frequency of ground delay programs since the closure is any sign, it's going to be a *bad* winter for delays at LAX....
Ask why..
mtnwest1979
Sun Aug 06, 2006 2:44 pm
Fal, Spring and next Summer.
"If it ain't broke, don't fix it!"
ramprat74
Sun Aug 06, 2006 2:51 pm
The 5:39pm PDX-LAX flight I work everyday has been on flows all week long. I guess the 8:00pm time frame at LAX is pretty busy. I take it they are doing most of the construction at night?
KarlB737
Sun Aug 06, 2006 10:45 pm
cxb744
Mon Aug 07, 2006 4:47 am
They have already demolished 1/4 of 25L.
What is it? It's A 747-400, but that's not important right now.
