YULYMX
B747-400 VS B747-300
Mon Aug 07, 2006 10:27 am
Was spotting at YUL tonight and saw a Corair B747-300 and a AF 747-400 takeoff... on runaway 24L what is the difference between the 2 airplanes?
1- Lenght?
2- Engines?
3- range?
They both look similar but may be it was the color but the Corsair seems or look bigger...(longer) i don't think so...
I think that the 743 got a little bit more range than the regular 744 by about 700 nauticals miles???
i know Corsair fly with 2 class and 497 pax and AF with probably 3 class so less pax
Thanks for your help
flydreamliner
RE: B747-400 VS B747-300
Mon Aug 07, 2006 10:32 am
They are the same exact length. The 744 has the winglets and also has an EFIS 2 man cockpit, vs 3 man in the 743. The 744's had new engines, though they were available for the 743 for part of its production, the 744 also further reduced fuel burn with better aerodynamics and increased use of weight saving materials. The 744 actually has a longer range than the 743.
"Let the world change you, and you can change the world"
YULYMX
Mon Aug 07, 2006 10:36 am
Boeing site says: 7,700 statute miles for the 743 and 7,260 nautical miles
MCOflyer
Mon Aug 07, 2006 10:41 am
Quoting YULYMX (Thread starter):
1- Lenght?
2- Engines?
3- range?
1.The 744 has a bigger upper deck. Both have the straight stair entry to upper deck.
2. The engines are diffrent at least for the early 300's. I know RG had the 400 series engines put on theirs. TG also has 400 series engines. CX, and Qantas had/have RR RB211 524D4 engines on their planes. JL, SQ had JT9D pratts on theirs. AI also has updated GE engines. LX had Pratts to. Its intresting to note that KLM had several 200 converted to SUD standard whcih made them 300's. They had the 200 series GE engines. I believe it was the CF650E2 that powered theirs.
3. Range: the 747-400 has the most range. The 300 ranges from 6100miles (CF6-50's) to 6700 (CF6-80's) miles. The RR and P&W fill the gap.
Hope this helps. Go to airliner data section of airliners.net
MCOflyer
ZK-NBT
Mon Aug 07, 2006 10:49 am
Quoting YULYMX (Reply 2):
I'm not sure of the exact range but that is incorrect.
N1120A
Mon Aug 07, 2006 10:58 am
Quoting FlyDreamliner (Reply 1):
Significantly. The 743's range is just under that of the 742B, which is lower than either the 744 or 747SP
AC320tech
Mon Aug 07, 2006 11:13 am
Not to mention the 744 has winglets.
da man
Mon Aug 07, 2006 11:29 am
Quoting N1120A (Reply 5):
Thats because the 743 just added the longer upper deck and sometimes different engines. Because no extra fuel could be carried than the 742B and the SUD added extra structural weight, the 743's range suffered at the expense of carrying more pax.
War Eagle!
CanadianNorth
Mon Aug 07, 2006 11:35 am
A -400 is basically a -300 with:
-More modern and efficient engines (more power less gas)
-A new, modern, 2-person flt deck (overall better, and 1 less crew member to pay)
-More fuel capacity (more range)
-Winglets (adds to both range and efficiency)
-Some aerodynamic improvements (again to make it more efficient)
-Structural improvements (to save weight)
-A few other minor improvements
CanadianNorth
HS-748, just like a 747 but better!
Pulkovokiwi
Mon Aug 07, 2006 11:38 am
Cabin wall panelling is a wee bit different as well.
I thought I was wrong but I was only joking!
YULYMX
Mon Aug 07, 2006 11:39 am
anyone know the engine on the classic 747-300 of corsair?
Pulkovokiwi
Mon Aug 07, 2006 11:41 am
If its ex SQ it'll be a Pratt & Whitney.
YULYMX
Mon Aug 07, 2006 11:46 am
Prtty sure it was F-GSKY
AeroWesty
Quoting MCOflyer (Reply 3):
I don't believe they could simply stretch the upper deck and call it a -300, there were other differences between the classics and the later models.
KLM's were -200SUDs after modification, and even JAL had some -100SUDs delivered fresh from the factory with the longer upper deck already built into the frame.
International Homo of Mystery
captaink
Mon Aug 07, 2006 11:50 am
What exactly are these aerodynamic changes? I thought it was just a matter of winglets, newer engines, upgraded avionics and lighter materials..
There is something special about planes....
PhilSquares
Mon Aug 07, 2006 12:03 pm
Quoting AeroWesty (Reply 13):
The first 300s were in essence nothing more than a 200B with a stretched upper deck. There were some internal additions for the upper deck gally, but systems wise, it was identical. The MTOW was the same as a 200B, 830000lbs but the empty weight was higher as a result of the additional upper deck structure. Thus the payload was actually lower on the 300 than the 200B. Some of the later 300s produced took advantage of the introduction 400. There were aerodynamic refinements to the fuselage/wing area to reduce drag.
Quoting YULYMX (Reply 10):
JT9-7R4G2
Quoting Captaink (Reply 14):
The 400 had a different wing/fuselage fairing that reduced drag and provided increased fuel efficiency. The LE devices were different than the classic. New engines offered PW 4000. In addition, the option of fuel in the horizontal stabilizer was an option. Increase in MTOW from 830,000lbs to 872,000lbs. Elimination of FE position and introduction of "glass cockpit". Several improvements in the cabin also.
Fly fast, live slow
AeroWesty
Mon Aug 07, 2006 12:31 pm
Quoting PhilSquares (Reply 15):
Ah, thanks for the correction. Perhaps you'd know the answer to this. I thought one of the things that made a -300 a true -300 vs. a -200SUD was that the longer upper deck contributed to a more aerodynamic shape, and thus a slightly higher cruise speed. Were the -200SUDs rerated for the higher cruise speed too, or is this a bit of muck I need to sweep out of my brain?
PhilSquares
Mon Aug 07, 2006 12:48 pm
Both aircraft had the same VMO/MMO. So there was nothing to really do since the normal cruise MN was below the MMO.
The 300 cruised at .85, the 200B was about .843 and the 400 is just about .855-.86 depending on if you're going LRC or ECON Cruise.
The only difference between a 200SUD and the 300 was the 300 was certificated and built as a 300, while the 200SUD was built as a 200 and then re-worked to a SUD using a STC (supplemental type certificate).
Fly fast, live slow
AeroWesty
Mon Aug 07, 2006 12:59 pm
Quoting PhilSquares (Reply 17):
Great way to explain this, I'll remember it for the future. Much obliged.  thumbsup
texdravid
Mon Aug 07, 2006 1:12 pm
The 300 was the big top. The 400 was and is the megatop. Hey, we just live in SQ's world!!
Otherwise, the 300 was not as successful, as the 200 and 400 were way more popular and sold more types, for the reasons as stated by other posters.
I only flew one trip on the 300, SQ's LAX-NRT-SIN and back in 1987. It was basically just a 200 with a longer top, but same engines, hence the lower range.
Tort reform now. Throw lawyers in jail later.
kaitak744
Mon Aug 07, 2006 1:34 pm
The late production 747-300s had the new 747-400 wing to body fairing, and had the new engines. RG and AI took delivery of these, and TG just has the 743 will only the new engines.
Tod
Mon Aug 07, 2006 10:12 pm
Corsair 747 seating is actually closer to 586.
Another 743 v. 744 difference:
743 = Old style "blue juice" lavs.
744 = vacuum waste system.
Tod
cloudyapple
Mon Aug 07, 2006 10:25 pm
I can't believe no one has mentioned the B744 has a completely new wing complete with winglets. Meanwhile the B743 has exactly the same wing as the B742. Where do you think the additional aerodynamic efficiency has come from?
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
PhilSquares
Mon Aug 07, 2006 10:51 pm
Quoting Cloudyapple (Reply 22):
No, the 400 doesn't have a completely new wing! Due to the increase in MTOW the wing had to be lengthened. The airlines involved in the initial orders (NW & SQ) had a requirement that the footprint be the same as the 200. That's where the winglets came from.
The 400 has a much more efficient fuselage/wing fairing, that's where the wing joins the fuselage, that results in aerodynamic efficiencies. In addition, the leading edge was redesigned slightly.
One of the biggest drivers of the efficiency was the new engines. On the PW 744, compared to a PW 200B (7Q or 7R) there's about 2tonnes decrease in fuel burn for comparable weights. In fact, the 400 at MTOW (872,000lbs) will burn less than a 200B at MTOW (830,000lbs).
Fly fast, live slow
LTU932
Mon Aug 07, 2006 11:23 pm
Quoting PhilSquares (Reply 23):
Which I believe was also introduced on later built 743s, while older 743s had the same wing to body fairing as the -200B and -100. I don't recall from which line number on the 743 had this new wing to body fairing though.
PhilSquares
Tue Aug 08, 2006 12:12 am
Quoting LTU932 (Reply 24):
As I already pointed out, the 300 and 400 lines were ongoing for a short period of time. During that time, the aerodynamic refinements were migrated to the 300.
Fly fast, live slow
LTU932
Tue Aug 08, 2006 1:15 am
Quoting PhilSquares (Reply 25):
I didn't notice you already pointed that out. My apologies.
Geo772
Tue Aug 08, 2006 1:26 am
One of the changes to the wing was a whole new wing tip. This allowed for an additional leading edge flap on each wing. This wing tip could either have a winglet or not in the case of the 400D series.
Of the systems that were new - there was a huge revamp of the entire avionics suite including a Central maintenance computing system - which improves maintenance costs by making troubleshooting simpler.
Also more advanced flight computers, autopilots and navigational equipment was used, reducing system complexity and wiring.
The HF radio antennas on the 300 were changed from rod type on the wing tip to a slot type antenna on the leading edge of the fin. This reduced drag and weight.
The Air conditioning packs were changed and made more efficient. A new APU with self monitoring was used, with associated fuel burn improvements. It also has the ability to run all 3 packs on the ground in a high flow state or start 2 engines simultaneously.
The list could go on, but together the various improvements are some of the reasons why the 744 is such a successful aircraft and the 743 only a modest success.
Let us hope that the 748 shows the same quantum improvement again.
Flown on A300B4/600,A319/20/21,A332/3,A343,B727,B732/3/4/5/6/7/8,B741/2/4,B752/3,B762/3,B772/3,DC10,L1011-200,VC10,MD80,
Airimages
Tue Aug 08, 2006 3:46 am
Just a comment: there are also 747-400s without winglets.
Photo © David James Clelford
Jerome
[Edited 2006-08-07 20:51:39]
MCOflyer
Tue Aug 08, 2006 4:04 am
Quoting Airimages (Reply 28):
744D models specifly built for ANA and Japan Airlines. for short haul high desity route configs.
ANA configured two of its D aircraft back to long range standards.
MCOflyer
bh4007
Tue Aug 08, 2006 4:29 am
Compared to the 744&741 the -300 can be underpowered when fitted with the older powerplants - very slow climber when heavily loaded.
Photo © Stuart Prince
Tue Aug 08, 2006 5:51 am
The 744 and the 743 have the same upper deck. The upper deck stretch was introduced with the 742 SUD conversions.
Quoting Texdravid (Reply 19):
The 300 did not sell as much because it was around for only a short time between the end of the 200 and the introduction of the much improved 400.
As has been mentioned, the wing is certainly not new. Tweaked would be the word I use.
The D variant has no winglets because the weight penalty outweighs the savings on shorter flights.
The is also a 744 variant with the original 741/742 short upper deck: the freighter. This does not include conversions of course.
lufthansi
Tue Aug 08, 2006 6:35 am
A very smart colleague of mine told me that some 743 have been converted and now have 2 man cockpits. He told me so while both of us where watching an Air Angola 743 passing bye.
Life starts at take-off!
PhilSquares
Tue Aug 08, 2006 7:43 am
Quoting Lufthansi (Reply 32):
Not so. No "classics" have been converted to 2 man cockpits. There is no such conversion available.
Fly fast, live slow
