ZRH
LH Question - Aircraft Types
Tue Aug 08, 2006 4:03 am
As I am soon flying ZRH-MUC-SVO with LH, I would like to know the aircraft types they use on these routes. Where can I get them? There aren't any on the LH online time-table.
BTW I will fly back on Swiss from DEM to ZRH so I will see two different Moscow airports Big grin (or did LH also change to DEM?).
ACDC8
RE: LH Question - Aircraft Types
Tue Aug 08, 2006 4:05 am
If you use the booking engine on the LH website, it should state which type of aircraft is flying the route.
A Grumpy German Is A Sauerkraut
MCOflyer
Tue Aug 08, 2006 4:10 am
LH uses airbus a/c into SVO. So it will ikely be A 320 or a 321. LX uses A320's into DEM if im not mistaken. Hope this helps.
MCOflyer
ZRH
Tue Aug 08, 2006 4:16 am
Quoting ACDC8 (Reply 1):
Thanks. This worked. It is a A319 from MUC to Moscow. They still fly to Sheremetyevo. I thought they also wanted to change to Domodedovo, like Swiss, because this is the better airport. As an aviation fan I of course like to see both airports.
ACDC8
Tue Aug 08, 2006 4:21 am
Quoting ZRH (Reply 3):
Kein problem. Gute reise!
I'm the same way
Motorhussy
Tue Aug 08, 2006 5:18 am
Quoting MCOflyer (Reply 2):
Moscow Domodedovo = DME I think.
MH
come visit the south pacific
ZRH
Tue Aug 08, 2006 5:48 am
Quoting MotorHussy (Reply 5):
Yes it is DME. And is also correct that Swiss uses A 320 between ZRH and DME.
dazeflight
Tue Aug 08, 2006 10:53 pm
You'll see, qualitywise there's no comparison between the two. SVO is a dump, DME is great. No Comparison to what kind of dump DME was only 10 years ago.
ciao
Daniel
