eastern023
Is LH Returning To SCL?
Wed Aug 09, 2006 7:00 am
I understand now the GRU-SCL is operated by LX. I wonder if LH plans to return to SCL.
AA will Rise Again!
LTU932
RE: Is LH Returning To SCL?
Wed Aug 09, 2006 7:35 am
I believe not because they started MUC-GRU recently (or will).
LipeGIG
Wed Aug 09, 2006 10:48 am
Quoting Eastern023 (Thread starter):
It could be, as they will run MUC-GRU with the same plane used by LX nowadays (A340-300), and LH flight will be daily (LX IIRC is a 6x weekly flight). But at the same time, LH keep code share on LX flight so, it's a little change, and with LH, LX drops SCL-GRU leg for sure.
Felipe
New York + Rio de Janeiro = One of the best combinations !
eastern023
Fri Aug 11, 2006 11:47 pm
Quoting LipeGIG (Reply 2):
Can you repeat this?
AA will Rise Again!
