TopJet001
Why No More Large Twin-jets?
Thu Aug 10, 2006 6:24 pm
Why are manufacturers moving away from the DC9, MD80/90 and B717 design. As we all know Boeing ended production of the 717 in May, and as far as I can tell the only manufacturer to continue production is Embraer with their ERJ family.
It seems that manufacturers (including Embraer with their newer 170/175/190/195 models) want to stay with the traditional - engine-under-wing design. Why is this? More efficient, better aerodynamics...?
I'm sorry if a similar topic has been posted before - I'm fairly new to Airliners Net.
Photo © Michael Carter
Photo © Steve Brimley
Photo © Ondrej Smrtka
Photo © Mark Kopczak
Andy  Smile
BA380
RE: Why No More Large Twin-jets?
Thu Aug 10, 2006 6:30 pm
the title is a little confusing... I thought the A350XWB, 777 and 787 were all twin jets  Wink
cabin crew: doors to automatic and cross-check...
viv
Thu Aug 10, 2006 6:31 pm
Quoting TopJet001 (Thread starter):
The weight of the engines offsets lift-induced stress on the wing.
Rear-mounted engines generally necessitate a T-tail, which brings its own problems of structural integrity, masking of the tail surfaces with risk of deep stall at high angles of attack - in turn necessitating the installation of a stick-pusher, etc.
Large-diameter fan engines do not make for easy rear-fuselage mounting.
CRJ900
Thu Aug 10, 2006 7:00 pm
Quoting Viv (Reply 2):
The MD90 had to be extended 1,5 meters ahead of the wing to avoid the aircraft tipping on its butt due to the new and heavy IAE V2500 engines.
Could this be one of the reasons why the stretched CRJ900X is still not launched? The engines will be the same (with same weight?) as on the CRJ900, though...
Come, fly the prevailing winds with me
Glareskin
Thu Aug 10, 2006 7:16 pm
Fuse mounting saves on the landing gear. The 737 is an intermediate solution: engines with flat-bottom nacelles. The 757 shares the 737 fuselage but due to the bigger engines it needed a higher landing gear.
There's still a long way to go before all the alliances deserve a star...
