lincoln
Door Operation
Mon Aug 14, 2006 12:10 am
Hi All,
Recent NW flights prompt this question -- who is responsible for opening/closing the aircraft doors? Is there a reason why?
Since it seems like it varries by airline, does anyone have a list?
I had always assumed that the FAs would open and close the aircraft doors, but I noticed after boarding for one of my NW flights the gate agent came onboard, interrupted a conversation the FAs were having and asked "Is it OK if I close the door now?"
Then upon pulling up to the gate at the end of the flight there was a loud banging/knocking at the 1L door until one of the FAs walked over and made some kind of gesture (from my angle I couldn't see what it was) before the gate agent opened it.
Lincoln
captaink
RE: Door Operation
Mon Aug 14, 2006 12:16 am
Depends on the airline and sometimes aircraft type. Usually A320 series aircraft are opened by ground agents as the emergency slide is automatically deactivated when the handle on the door is pulled up.
-US Airways, we just made sure it was clear and opened up the door.
-Air Jamaica, we knocked the window, waited for the thumbs up and opened. There is a little light that would illuminate if the aircraft is still pressurized for some reason, at that point you just stop and wait a little while, before trying again.
When I worked at the airport, we opened and closed, A320 series, B744 and B752.
THe 737s were opened on the inside, the 767s that came the door went up in the roof, and the 777 and A330 were opened from the inside, we would assist but the actual operation would be done by a FA. Boils down to the airlines procedures.
Picture of me playing with expensive equipment.
http://i78.photobucket.com/albums/j114/dc9super80/DSC00547_JPG.jpg
[Edited 2006-08-13 17:17:48]
[Edited 2006-08-13 17:23:23]
[Edited 2006-08-13 17:24:41]
There is something special about planes....
AC_B777
RE: Door Operation
Mon Aug 14, 2006 12:19 am
It all depends on the airlines.
At AC, the ramp workers open and close the doors on all AC and QK (Jazz) planes.
There are some airlines like WN where the gate agents open and close the doors and other airlines where the flight attendants do it.
In life, some days you are the bug..... some days you are the windshield!
kaddyuk
RE: Door Operation
Mon Aug 14, 2006 12:24 am
Quoting Captaink (Reply 1):
Dont ever assume that...
I've seen girt bars frozen into place and even though the door is supposed to dis-arm when you butterfly the handle, never open a door from the outside that is in automatic mode... Always get the person on the inside to dis-arm and then open it.
Same when opening the door on the inside... even though you may have selected the handle into Manual. Always crack the door open just enough to get a visual on the girt bar before you push the door fully open.
captaink
RE: Door Operation
Mon Aug 14, 2006 12:30 am
Quoting Kaddyuk (Reply 3):
I was making specific reference to the A320 series aircraft. At least I was taught that opening the A320 from the outside will always disarm the door. But if the FA does not disarm it from the inside and you try to pull up the handle on the outside would it open? And if so would the slide deploy or would it disarm?
With the Boeings and the butterfly mechanism, I know that it will deploy if it is in automatic mode or the girt bar is stuck. When opening the B744 we are to look down at the bottom of the door where the bar is just to make sure, and at the corner by the hinge where the red pressure 'thingy' is before fully opening the door. I watched the videos during the door opening training for VS and yeah it is scary what can happen if that door is not disarmed and the slide deploys.
kaddyuk
RE: Door Operation
Mon Aug 14, 2006 12:42 am
Quoting Captaink (Reply 4):
I treat all doors the same, that way i never get one procedure confused with another...
dc10s4ever
RE: Door Operation
On AA the doors on the 737 and S80 are "cracked" open be the FA, but closed by the agent dispatching the trip.
On all other aircraft with automatic doors (757,767,777,A300) the door is opened and closed by the agent.
twal1011727
RE: Door Operation
Mon Aug 14, 2006 12:48 am
Usually.....the gate agent will open the door after the flt attndt cracks the door......on most narrowbody A/C (especially Boeings) the L1 door can be a struggle to open from a flt attndt point of view. Conversely...the gate agents move the door to a semi closed position and the flt attndt finishes closing the door. Its usually company policy that dictates who opens the door.
KD
captaink
RE: Door Operation
Mon Aug 14, 2006 2:09 am
Quoting TWAL1011727 (Reply 7):
Usually Boeings is correct, as this is not usually the case with Airbus narrowbodies.
Airplanepics
RE: Door Operation
Mon Aug 14, 2006 2:21 am
Usually, if the aircraft is coming in with Passengers, the crew will undo the door. If the aircraft is coming in as a positioning flight and we need it moved quickly, we sometimes open the door. We don't have to worry about emergency slides on the aircraft we work on.
Although, i'm always cautious of the Hawker door, those thing's can kill!
Simon - London-Aviation.com
TopJet001
RE: Door Operation
Mon Aug 14, 2006 3:02 am
I know this sounds like a stupid question, but I really don't know....what does it mean when you hear "doors to automatic".......and what is an automatic door...?
Andy  Smile
FlyingColours
RE: Door Operation
757 doors are a bitch regardless of which ones you are working with, they are way too heavy to operate in manual mode and you would need help of about 4 people if god forbid the power assist failed during an evac.
With us the doors are always opened by the FAs and never ground agents, they can help us open and close the door by holding onto it (thereofre taking some weight off us). Caterers are supposed to have special training and can open/close 1R and 4L (on the 757) and 1R & 2R on the A320, of course they can only do that once they have been told all passengers are off.
Doors can not be operated by anyone other than crew downroute.
And on the 737 with the manual girt bars they always had to be opened by the crew.
A crewmember is assigned a door/seat position - for instance today I was the L2 crewmember, that meant I had a double jumpseat at doors 2 (757), although today the jumpseat was actually on A/C right. I was responsible for arming and disarming, opening & closing door 2 Left (the boarding door). In theory I and only I should operate the door but usually another crewmember could close it if they are instructed.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
captaink
RE: Door Operation
Mon Aug 14, 2006 6:06 am
Quoting FlyingColours (Reply 11):
Can I have your job?
Thanks for the info though.
I do find that many of the charter companies tend to have their doors only opened and closed by crew members. I assume this is becuase they at times fly to airport out of their usual route network, hence don't have staff trained in their policies and procedures. Airlines that I have dealt with, Monarch, Excel, Air Transat, Skyservice regardless of the equipment flown, the FA's opened the doors themselves.
Lowsonboy
RE: Door Operation
Mon Aug 14, 2006 7:55 am
As dispatchers we are not allowed to open any doors on the airlines we handle, though most of us would help pull heavy (eg 757, 747) doors open if the crew were struggling a bit. Apart from CO, whose doors we open and close from the outside, once we're given an OK signal from the crew.
iahcsr
RE: Door Operation
Mon Aug 14, 2006 8:16 am
At CO... 737s are cracked by the FA's then opened by the agents. 75/76/77's are opened by the agents after getting a  thumbsup  from the FA though the window.
zippyjet
RE: Door Operation
Mon Aug 14, 2006 8:55 am
Here's the deal with us at FL.
  • Arrival: A/C stops, marsheler gives me (gate agent) signal.
  • I put the jet way in motion-at "BEEWEE" our jet ways trundle, shake rattle and rock and roll up to the bird.
  • Wait for APU cable to be hooked up correctly. Captain cuts the engines
  • I (gate agent) rap tap taps on the forward door.
  • Lead F/A finishes their spiel, removes the red cloth across little porthole door window which means the emergency slide is disarmed. Open the door with the slide armed and you get whacked quicker and harder than Tony Soprano could do the job.
  • Zippyjet opens the cabin door and tells lead F/A where pax can claim bags and connection information if applicable. Also if applicable if the lead F/A is female and hot looking some "Zippyjet" patented flirting.
  • I then ask if there are any specials usually wheel chairs and "UMINNERS" Unaccompanied minors. Sometimes there is heavy stuff like summon the law for a special passenger or sadly sometimes a meat wagon usually on inbound RSW, FLL and SRQ flights.
    Departure
  • everybody must be behaving in their seats, I review load plan with Capt. and first officer. Make sure all doors are closed with the exception of course of the main cabin door.
  • "Doors Closed All Set!" which means it's kosher to exit my butt off the bird, I then release the door and on the 717's close it until it rests on the latch. Then our lead F/A secures and locks the door.
  • I have all my paperwork, and then put the jet way in motion and shake, rattle, roll and trundle back.
  • Hang out at end of jet way while ramp does push back/tow the bird out.
  • As this happens, I wave/salute the captain who does the same.
  • On the 737-700 everything is the same but, I release the door and let it fall naturally toward closing. Gravity does the work. Then lead F/A secures door.
  • During our Southern sweltering summers, I feel like a steamed side of beef and make my way back into the terminal.
  • Ready for my next great airline gate adventure!
Photo © Michael Carter
Photo © Peter Unmuth-VAP
I'm Zippyjet & I approve of this message!
kaddyuk
RE: Door Operation
Mon Aug 14, 2006 9:38 am
Quoting TopJet001 (Reply 10):
Doors have two modes... Manual and Automatic.
In manual mode, you can open the door and the safety features will not be activated.
In automatic mode, all the safety features of the door are armed and opening the door will action several different functions.
I cant speak of other types other than the B744 and A340 however many aircraft have the same or similar types of operation.
A Pressurised Door Assist bottle (Charged with nitrogen to about 1800psi) will force the door open with force and at speed incase the aircraft lands in such a way that the force of a human cant lift the weight of the door.
The Escape Slide/Raft should also inflate.
Attached to the slide is a fabric girt and telescopic girt bar. The telescopic girt bar enables the slide pack to be removed from one floor-level exit’s floor fittings and deployed outside the airplane from another door, if necessary, in the event of a ditching and emergency evacuation in the water. When the door is “armed,” the girt bar is attached to the floor fittings on the doorsill so that when the door is opened, the girt bar will pull on the slide/raft and initiate its deployment. When the door is “disarmed” and opened, the girt bar remains attached to and moves with the door, thereby preventing the slide/raft from deploying.
Which explains how the Girt Mechanism works... When an engineer installs an emergency slide, a duplicate inspection of the installation should be carried out by an engineer which was not involved in the task of installation.
AC320tech
RE: Door Operation
Mon Aug 14, 2006 9:56 am
Never assume that. Someone thought thats how the 767 works, opened the door and got a face full of slide.
No, No Airbus aircraft disarm the doors by themselves if someone opens it from the outside. The door has to be disarmed by moving a handle next to the handle that opens the door. No airplane does this because what if emergency crews have to open the door from the outside?
Quoting Kaddyuk (Reply 16):
Whatever it is on the A340 is the same on the rest of the Airbus's (probably a bit different on the A300 and A310, but those doors operate the same as the rest).
One of these bottles wasnt fully charged on the TS236 accident, the R3 door, only open a third of the way and then jammed.
Markhkg
RE: Door Operation
Mon Aug 14, 2006 10:16 am
Quoting AC320tech (Reply 17):
Well, actually, the 767 service doors WILL disarm if they are opened from the outside. It's the 767 emergency doors at R3 and L3 that will deploy automatically from the outside, as they are always armed.
The A320 is a user-friendly system. It will disarm if opened from the outside. The emergency crews need to this function to prevent getting a face-full of slide if they open the doors from the outside.
kaddyuk
RE: Door Operation
Mon Aug 14, 2006 11:10 am
Yeah, but you know what the flame squad is like on this forum... I was covering my ass...  Wink
AC320tech
RE: Door Operation
Mon Aug 14, 2006 12:25 pm
Quoting MarkHKG (Reply 18):
Im sorry but you are incorrect. Ever hear of the "red-tape" that gets put across the windows on aircraft (Boeing and McDonnell Douglas) to tell the ground crew the door is still armed? Doors on any commercial airliner will not dissarm if the door is opend from the outside.
On Airbus aircraft, there is a light indicator that will illuminate and stay illuminated when the door is armed and the aircraft is on the ground. If it blinks its because the cabin is still pressurized.
In this picture we can see the A320 door, see the "REMOVE BEOFRE FLIGHT" strip, or the red strip? It is clipped to a yellow handle. This yellow hand arms and disarms the door.
I also clarified with my Father, who used to work as a rampie in YHZ for AC. He said the doors do not disarm on the 767 or A320 when you move the handle.
[Edited 2006-08-14 05:26:42]
[Edited 2006-08-14 05:27:41]
[Edited 2006-08-14 05:28:54]
EWRCabincrew
RE: Door Operation
Mon Aug 14, 2006 1:38 pm
Three modes. Add electric. DC-10s and L-10s have electric. 767s have them as well.
You can't cure stupid
FlyDeltaJets
RE: Door Operation
Mon Aug 14, 2006 3:16 pm
DL policy is that the grould crew is to always open or close the doors. on all aircraft operated by DELTA. The regional carriers each have thier own rules that I am not fully familiar with.
[Edited 2006-08-14 08:17:19]
The only valid opinions are those based in facts
iahcsr
RE: Door Operation
Mon Aug 14, 2006 3:56 pm
Quoting AC320tech (Reply 20):
Doors on any commercial airliner will not dissarm if the door is upend from the outside.
Speaking from 18 years of experience opening doors on the A300/DC10/747/757/767 and 777, I can say with absolute certainly they are designed to disengage/disarm when operated externally. This is the very reason why .. at CO anyway.. FA's are to disarm, but NOT open them from inside.  stirthepot
I had a distracted FA open an armed 747 door on me once .... Lucky for me the slide has to drop  down  from door level before in inflates ......  relieved
Markhkg
RE: Door Operation
Mon Aug 14, 2006 6:36 pm
No, read the ARFF (Aircraft Rescue and Fire Fighting) information. Doors opened, for the doors I mentioned, from the outside get disarmed.
Boeing 767 series
www.boeing.com/commercial/airports/arff/arff767.pdf
Airbus A320 series
http://www.aaae.org/government/200_R...craft_Familiarization/a319-320.pdf
Boeing 737 aircraft get the "Red tape" treatment because their doors DO NOT disarm from the outside, as you mention. But newer designed planes from the 757 onwards and A300 onwards all are "user friendly" systems EXCEPT for the emergency doors and thus disarm when the doors is opened from the outside. Also remember that the 737 series doors hasn't had an extensive redesign since it first rolled out until the 737 NG series where a new type of overwing exit was added, so there is no power assist system or exterior disconnect.
But the door disarms when the handle is released from the OUTSIDE.
Bobski
RE: Door Operation
Mon Aug 14, 2006 6:52 pm
When I fly on Aer Lingus in their A320s/A321s, it always seems to be the FA that closes the door. When we arrive, there is usually a knock by the ground staff, the FA unlocks the door and then opens it.
This is my interpretation of it anyway, on the Dublin-BHX flights that I frequently take.
Who is Benjamin Breeg?
OttoPylit
RE: Door Operation
Mon Aug 14, 2006 7:19 pm
Quoting Lincoln (Thread starter):
At DL, it is the ground crews responsibility for opening aircraft doors.
On widebody equipment, as soon as the jetway connects to the aircraft, the gate agent will knock on the door and peer in. The flight attendant will give the agent a thumbs up, which means the door is dis-armed and ok to open. The agent then pulls up on the level, reaches in, and thumbs a little toggle swtich, that pulls the door up. If, sometimes, the actuator to lift the door burns out or breaks, you can reach under and simply lift the door into the door recess.
On narrowbody equipment, it is sometimes more difficult for a ground crewman to open the door, as the handles are more designed for pushing instead of pulling. On MD88/90 equipment, the agent will knock on the door and and the flight attendant will push it open, to which the agent will grab it from the outside and help open it completely. On 737 and 757 equipment, the butterfly handles spin around to open. After recieving the "thumbs up", the gate agent will open the handle, spin it around, and pull the door open, usually assisted by the FA.
On closing the door, it is always the gate agent's responsibility, after recieving notice that the cabin and flight deck is secure from the pilot and FA. The 757 door is trickly for newbies, as you have to learn to swing the door and your arms around quickly, but if you choke at any point, the door handles will snap back and bite you. When I first started with DL as a gate agent, many a times I would leave work with the tips of my fingers sore from getting smashed by 757 handles. But it eventually comes to you, and allows you to enjoy watching other newbies suffer the same fate.
OttoPylit
I don't have a microwave, but I do have a clock that occasionally cooks shit.
kaddyuk
RE: Door Operation
Tue Aug 15, 2006 2:03 am
Nope, doors on most modern aircraft types will move from the automatic mode to manual mode when opened from the outside...
EWRCabincrew
RE: Door Operation
Tue Aug 15, 2006 2:09 am
Quoting Kaddyuk (Reply 27):
Except the modern 737NGs (and any version 737 for that matter), the DC-9 family (MD-80/90s too), and probably the 717.
Quoting MarkHKG (Reply 24):
AC320tech
RE: Door Operation
Tue Aug 15, 2006 3:47 am
Sorry guys I was wrong. Thanks for the files, some of the information is really useful.
bwaflyer
RE: Door Operation
Tue Aug 15, 2006 5:08 am
It seems to be a transatlantic difference. From the replies above, North American carriers have the ground crew open the door (either totally, or after they are cracked). This side of the Atlantic, it seems to be normally the cabin crew. Certainly at the airlines I've worked for, the ground crew would be in deep trouble if the operated the doors from the outside (unless obviously the aircraft was empty and the catering / cleaning staff needed access).
MCOflyer
RE: Door Operation
Tue Aug 15, 2006 5:25 am
When I sit on by the l2 door on US flts, the gate agent will close the door part way and the fa actually shuts the door and armes it.
MCOflyer
lincoln
RE: Door Operation
Tue Aug 15, 2006 11:14 am
Wow! Thanks for all of the replies -- this is certainly turned into a much larger and more informative/thorough thread than I had expected.
It's made for some interesting reading, and is probably the best thread I've started to date
Quoting IAHcsr (Reply 23):
I had a distracted FA open an armed 747 door on me once .... Lucky for me the slide has to drop from door level before in inflates ......
This makes alot of sense to me... From what I've read before, accidental slide inflation is a huge PITA in terms of both cost and pax inconvenience. If opening the door from the outside disarms the slide, having ground staff open the doors is, essentally, cheep insurance.
While I'd like to keep the original discussion going, one more question to throw in here. The wallpaper I use on my (personal) laptop is a great shot of a CO 737 tail from the A.net photo database. It also includes the R2 door, and the text
PULL OUT TO ENGAGE HANDLE
ROTATE AS SHOWN ABOVE
PULL DOOR OUTWARD
CAUTION
xxxxxxxxxxxxxxx
xxxxxxxxxxxxxxx
AUTOMATIC
ESCAPE SLIDE
IS ARMED
xxxxxxxxxxxxxxx
xxxxxxxxxxxxxxx
The text that I have as "x" above is too small to read...anyone know what it actually says? (For the record- it's ship 322, but I can't find the photo in the database right now)
Edit: Here's the photo I'm asking about specifically:
Photo © Shane Walker
Lincoln
(Who will be paying even more attention than usual on my flights this weekend   )
[Edited 2006-08-15 04:24:45]
iahcsr
RE: Door Operation
Tue Aug 15, 2006 2:52 pm
Quoting Lincoln (Reply 32):
CAUTION
xxxxxxxxxxxxxxx
xxxxxxxxxxxxxxx
Paraphrasing here.. "If Red strip shows in window"
(I see it every day .. You'd think I would know the exact wording}  ashamed
BH
RE: Door Operation
Tue Aug 15, 2006 3:18 pm
Here's another one for you, Like IAHcsr said the xxxxx "is something along the line of red stripe must not be showing or your getting a slide in your chest".
Big version: Width: 1024 Height: 768 File size: 177kb
starguy
RE: Door Operation
Tue Aug 15, 2006 6:51 pm
Quoting Bwaflyer (Reply 30):
At Virgin Atlantic, it is standard practise for ground to open the door from the outside in all normal circumstances. Cabin crew only open the doors in an emergency.
FlyingColours
RE: Door Operation
Tue Aug 15, 2006 7:54 pm
Quoting IAHcsr (Reply 33):
Yup, when I worked on the 737 (400 & 800) the way we would arm the doors would be to place the red strip (or flag) across the viewing window (so the ground crew can see that the door is armed) then manually attatch the girt bar to the floor. To disarm we would remove the girt bar from the aircraft floor, attatch it back to the door hooks then finally remove the flag.
The bad thing about those flags was there was never any way to see outside with the flag in place, at least on the 737-400.
Quoting Captaink (Reply 12):
Hehehe, nope  Wink
Quoting OttoPylit (Reply 26):
I've never operated the 757 door from the outside, perhaps I should be less eager to try  Smile
Phil
FlyingColours
