nwafflyer
Travel Thru Atlanta
Tue Aug 15, 2006 7:39 pm
How is Atlanta as far as flight delays/long lines, etc. are concerned? How early do I need to get to the airport?
Have there been any major lines in the last few days? Naturally, i have to check luggage, and have a mid morning flight
LN-MOW
RE: Travel Thru Atlanta
Tue Aug 15, 2006 8:01 pm
Getting back to normal. Calculate 30 minutes to pass security, this is worst possible scenario right now. Time spent at the ticketcounter depends on your airline ..
- I am LN-MOW, and I approve this message.
nwafflyer
Tue Aug 15, 2006 8:03 pm
Thanks - so with an e-ticket and on line check in, 30 minutes for security, 20 minutes to return rental car, 20 minutes to check luggage, and 10 minutes to get to the gate - 2 hours in advance should be OK
LN-MOW
Tue Aug 15, 2006 9:05 pm
Quoting Nwafflyer (Reply 2):
That's usually when I leave home. And I live in Alpharetta.  silly
nwafflyer
Wed Aug 16, 2006 9:16 am
OK, I am staying at the Holiday Inn North, will take the shuttle bus - 9AM flight - when do I need to leave the hotel???
LN-MOW
Wed Aug 16, 2006 9:42 am
HI Airport North? (there are several HI North's in Atlanta). Being in morning rush/peak hour - if you take the 7am you're fine and should also have plenty of time for a Starbucks.
TinkerBelle
Wed Aug 16, 2006 10:14 am
One thing is for sure..... You'll probably be number 33 for takeoff at some point especially if you're flying out in the morning. Too much trafiic....reminds me of EWR.
If you are going through hell, keep going.
deltagator
Wed Aug 16, 2006 10:49 am
Quoting TinkerBelle (Reply 6):
Have you flown through ATL since the debanked the flights? The delays are nowhere near where they used to be...and they were horrid.
727LOVER
Wed Aug 16, 2006 11:15 am
I fly through on Thursday. Where's the "Chili's"?
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
TinkerBelle
Wed Aug 16, 2006 11:17 am
Quoting DeltaGator (Reply 7):
Yes I have but it was at night and I figured traffic was just low. I must be wrong then coz last day flight out of ATL I had was horrible (traffic).
deltagator
Wed Aug 16, 2006 11:25 am
Quoting 727LOVER (Reply 8):
Check out http://www.atlanta-airport.com since there is more than one. Try Paschal's instead if you can. You can eat Chili's anywhere.
Quoting TinkerBelle (Reply 9):
I'm not saying you won't get delays but I've noticed a lot less these days. I've been in those 30+ deep lines on the taxiway and I haven't seen one in over a year.
Zone1
Wed Aug 16, 2006 11:52 am
Quoting DeltaGator (Reply 10):
The new runway also has helped a lot.
/// U N I T E D
nwafflyer
Thu Aug 17, 2006 9:48 am
Well, hotel said I need to be on the 6:30 shuttle for a 9AM flight- seems a bit extreme, but I'll do it
EWRandMDW
Thu Aug 17, 2006 10:55 am
I flew thru ATL 3 times so far this year, once on FL and twice on DL. I have to say on one flight we were # 1 for takeoff. I couldn't believe it! But the other two times we were #20 something. That one time had to be a one-of-a-kind fluke!
nwafflyer
Fri Aug 18, 2006 7:48 am
Update - travel thru Atlanta is pretty easy - hotel recommended 6:30 AM shuttle bus for 9AM flight - check in on NWA is easy with e-kiosks - platinum line took 10 minutes max - no smoking area in terminal D, so went back to C, smoked, used the ladies room, went back to D, got breakfast at Quizno's, biggest problem - falling asleep while waiting to board my flight
Alitalia744
Fri Aug 18, 2006 8:00 am
Quoting Nwafflyer (Reply 14):
You shoulda headed to A for some Chic-Fil-A!
YUMMY!
Some see lines, others see between the lines.
nwafflyer
Fri Aug 18, 2006 8:04 am
chic filet for breakfast????? Quizno's with no coffee is bad enough - should have gone to Chili's - other way on D, and gotten a real breakfast with coffee
gocaps16
Fri Aug 18, 2006 8:10 am
I've been to ATL numerous times in the morning on redeye flights. Luckily I never had the option to start at ATL, otherwise the lines would be hectic in the AM. However, ATL is very busy from 6am til 9am, and god knows how long the lines are. I figure a good half an hour or so. I had to connect thru ATL at 7:30am and tranffered between two terminals and overheard a passenger said she waited in the sercurity line for nearly 2 hours and almost missed her flight.
Too be on the safe side, I'd leave the hotel at 6:30am or earlier.
Kevin
Evan767
Fri Aug 18, 2006 8:35 am
Quoting Nwafflyer (Reply 16):
sandwhich for breakfast?????? Chick-fil-A doesn't server chickfilas that early. The server something way better. Its like a mini chickfila but it is on a biscuit similar to one you would get at Popeyes or KFC.
Alitalia744
Fri Aug 18, 2006 9:00 am
oh yeah!!!!! see this:
Quoting Evan767 (Reply 18):
Now thats what I'm talkin' about
DAL767400ER
Fri Aug 18, 2006 5:14 pm
Sounds like another day when several severe t-storms have passed through. Flights get backed up pretty back because of that, but the employees usually manage to make up a good portion of that, e.g. through turning a CDG-bound 777 in just 60 minutes  Wink .
