hmmmm...
What Is The Largest, Single-pilot Aircraft
Mon Aug 21, 2006 2:54 pm
What is the largest, in terms of mass, single-pilot certified aircraft today? Are any of the Lear 20 series classified as single-pilot, and does that category change according to the country of operation?
An optimist robs himself of the joy of being pleasantly surprised
Mir
RE: What Is The Largest, Single-pilot Aircraft
Mon Aug 21, 2006 3:02 pm
The Cessna CJ3 is, I believe, single-pilot certified.
Learjets are not, as far as I know.
-Mir
hmmmm...
Mon Aug 21, 2006 3:11 pm
Thanks Mir,
Do you know what the largest prop plane is that would be certified like that? I don't really mean new planes, I mean traditional planes in the past.
Pilot3033
Mon Aug 21, 2006 3:18 pm
I know that certain aircraft can be flown by a single pilot during ferry flights (no pax or cargo), and in states of emergancy.
-Matt
-Matt
Amazonphil
Mon Aug 21, 2006 3:28 pm
Quoting Hmmmm... (Reply 2):
Thanks Mir,
Could be the Cessna Caravan
If it ain't Boeing, I ain't goeing!
KELPkid
Mon Aug 21, 2006 3:37 pm
Anyone know what the max. takeoff weight for one of these puppies is?
Photo © Patrick De Coninck
I have seen a PZL Dromader on the ground, and they are absolutely massive! They look like they'd weigh over 12,000 lbs. empty...
I'm assuming that the AN-24 (Anushka) isn't certified for single-pilot ops?
Spruit
Mon Aug 21, 2006 4:29 pm
Quoting KELPkid (Reply 5):
General characteristics
Crew: one, pilot
Capacity: one passenger, and up to 2,200 l (581 US gallons) or 1,900 kg (4,180 lb) of chemicals
Length: 9.47 m (31 ft 1 in)
Wingspan: 17.70 m (58 ft 1 in)
Height: 3.70 m (12 ft 2 in)
Wing area: 40 m² (430 ft²)
Empty: 2,710 kg (5,975 lb)
Loaded: kg ( lb)
Maximum takeoff: 5,300 kg (11,700 lb)
Powerplant: 1x WSK "PZL-Kalisz"ASz-62IR-M18 piston radial, 745 kW (1,000 hp)
Performance
Maximum speed: 225 km/h (141 mph)
Range: 1,000 km (625 miles)
Service ceiling: 4,000 m (13,100 ft)
Rate of climb: 390 m/min (1,280 ft/min)
Wing loading: kg/m² ( lb/ft²)
Power/Mass: kW/kg ( hp/lb)
Have a look at http://en.wikipedia.org/wiki/PZL-Mielec_M-18_Dromader
Contains lots of interesting info!
Spru!
E=Mc2
HAL
Mon Aug 21, 2006 4:33 pm
You'd probably be looking at some of the light bombers from late WWII, such as the Douglas A-26 Invader (as seen in the Spielberg movie 'Always'). They were single pilot, although they did carry bombadiers and sometimes gunners too. I believe it was certified to a maximum takeoff weight around 35,000 pounds. There aren't many left, but some are still flown by warbird enthusiasts.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
hmmmm...
Mon Aug 21, 2006 9:04 pm
Hal, it's funny you should mention the A-26 invader, because I was just looking at one on the internet. It is owned by a forest fire fighting company in Alberta, and they have 18! of the old birds.
greg3322
Mon Aug 21, 2006 9:20 pm
How about a DHC-6 Twin Otter? I have seen them flown single pilot in skydiving operations.
Greg
okie73
Mon Aug 21, 2006 10:05 pm
F-15? I think the MTOW is upwards of 50,000lbs.
MH017
Mon Aug 21, 2006 10:26 pm
Polynesian is operating Islanders commercially with single-pilot...
Not sure about Cessna 208 Caravans, though (which one is bigger/smaller).
don't throw away tomorrow !
N757ST
Tue Aug 22, 2006 4:39 am
Maybe the Beech 1900... and before y'all get your panties in a wad.. yes it can be flow single pilot under part 91.
JohnJ
Tue Aug 22, 2006 4:45 am
The S-2 Turbo Tracker is single-pilot configured, at least the ones used by the California Division of Forestry for fire-fighting purposes.
sean1234
Tue Aug 22, 2006 4:52 am
The F-22 is at least 60,000lbs MTOW
c680
Tue Aug 22, 2006 4:56 am
Some quick data points:
(All Max Weights)
Cessna CJ3: 14,070
King Air 350: 15,100
Beech 1900D: 17,230 (If it can be flown single pilot under part 91 - I have no knowledge of that one...)
My happy place is FL470 - what's yours?
TUSflyer
Tue Aug 22, 2006 5:28 am
What about the B-47? Didn't it have a pilot, navigator, and a weapons officer?
JohnJ
Tue Aug 22, 2006 7:28 am
A web site I found lists the Navy S-2E as having a MGTOW of 29,150 pounds. I would assume the Turbo Tracker would have an even higher MGTOW, but I could be wrong. The pilot I spoke with said the performance of the turbos was markedly better than the old Wrights that they replaced. This doesn't approach the figures listed above for the F-22 and F-15, but could this be one of the heavier civilian-registered aircraft with a single pilot configuration?
[Edited 2006-08-22 00:35:04]
474218
Tue Aug 22, 2006 7:53 am
The SR-71 has a MTOW of 170,000 lbs, approximately the same as a fully loaded 737-900 or A320. The SR-71 has only one pilot as the Reconnaissance Systems Operator in the back seat has no controls.
flyf15
Tue Aug 22, 2006 8:07 am
Quoting 474218 (Reply 18):
Just barely beat me. The SR-71 has it as far as I know. Although, if you want seriously only one crewmember, it'd be the A-12 variant. That is one serious airplane to strap on all by yourself.
HaveBlue
Tue Aug 22, 2006 8:12 am
Agreed I was reading all the replies and the Blackbird had my vote, you both got to it first though.  Smile
Here Here for Severe Clear!
cbphoto
Tue Aug 22, 2006 8:34 am
Quoting C680 (Reply 15):
Well I can tell you the King Air 350 is not a single pilot aircraft, that I know for a fact. As far as the Beech 1900's. I am pretty sure the C models can be flown single pilot, but I am not too sure if the D models can be flown single pilot.
What about a Failchild Metroliner III, or Beach 99? I know for a fact Ameriflight operates them single pilot. I do agree that some of the old war birds and military planes would probably win in this category!!
ETOPS: Engines Turning or Passengers Swimming
caboclo
Tue Aug 22, 2006 9:11 am
Metro's are single pilot under part 91 or cargo only ops, biggest model is 16,500 lbs. Beech 99 is a little smaller, I think.
Freight dogs have more fun
c680
Tue Aug 22, 2006 9:39 am
Quoting CBPhoto (Reply 21):
Incorrect.
I have a type rating for a King Air 300/350 single pilot. (and over 800 hours in type - single pilot) I fly Part 91 - I have no idea if there is a separate Part 135 rule on the subject. The Type rating for King Air 300 and 350 is the same type rating.
See FAA Advisory Circular No: 61-89E for more information. (This advisory circular also contains a very good list of various type ratings)
MCOflyer
Tue Aug 22, 2006 9:55 am
What about E110 Bandit? I know for sure that airplane is single pilot under part 91 cargo. The B99 can most certainly be flown with a single pilot in cargo ops. I almost certain a 1900D model is single if hauling cargo. What about the E120?
MCOflyer
Tue Aug 22, 2006 10:31 am
In the civil world I would think the Virginflyer of more recent times, think it had a MTOW of around 23000 lb, heap of military fast jets that are way heavier, F111 110000lb, SR71 170000lb
YANQUI67
Tue Aug 22, 2006 10:51 am
The Raytheon Premier 1 390 is single pilot rated business jet.
RC135U
Tue Aug 22, 2006 12:25 pm
Quoting TUSflyer (Reply 16):
That would be the B-58, coming in at 163,000 pounds. The B-47 had a pilot,
copilot, and bombardier/navigator. BTW, the copilot's seat could swivel to face aft when the tail guns were used.
Bohlman
Tue Aug 22, 2006 12:49 pm
A graduate of my school flies around his GIV single pilot. As long as there are no pax or non essential cargo (aka ferry flights), quite a few "big" airplanes can legally be flown single pilot.
I'm not pro-Boeing or pro-Airbus, I'm pro-crew all the way.
cbphoto
Tue Aug 22, 2006 1:26 pm
Quoting C680 (Reply 23):
Huh...I guess you learn something new everyday!! I had heard from many people that King Air 350 was the only king air that required two crew in the king air fleet! Sorry for the mistake and incorrect info.
TripleDelta
Crew
Tue Aug 22, 2006 2:56 pm
Just to correct a little mistake: the Anushka is the An-2. The An-24 is twin-turboprop airliner:
Photo © Sven De Bevere
Photo © Tomas Sousek
The An-2 crew does indeed consist of a pilot and co-pilot/technicial, though in some cases (simple missions) it can be flown by a single pilot, though this is rather rare.
No plane, no gain.
hmmmm...
Tue Aug 22, 2006 11:07 pm
Quoting Bohlman (Reply 28):
Does this apply to a Learjet 24, a very small learjet?
okie73
Tue Aug 22, 2006 11:14 pm
Quoting RC135U (Reply 27):
B-58 MTOW 163,000. Max weight in flight (with air refueling) 176,890
[Edited 2006-08-22 16:19:25]
