keysman73
Thai Airways - LHR-HKG (via BKK)
Mon Aug 21, 2006 11:25 pm
Quick question for any of you guys that know about Thai's operation out of London.
I'm flying with them next month to HKG via BKK and have a very short (55-minute) transfer time in Bangkok.
Does anyone know if it is the same aircraft that carries onto HKG from BKK, or am I in for a mad dash through the airport??
Thanks in advance.
Alan.
vsflyer747400
RE: Thai Airways - LHR-HKG (via BKK)
Tue Aug 22, 2006 12:18 am
If this is the connection you are referring to.....
LHR BKK 01/2130#1505 TG 917 F2 A2 P2 C2 D2 J2 Z2 Y4 B4#747B
NO SMOKING FLIGHT
HKG 02/1600 1945 TG 606 F2 A2 P2 C2 D2 J2 Z4 Y4 B4#743B
NO SMOKING FLIGHT
Then you will be dashing as one flights on a 744 and the HKG flight a 743.
Good luck!  Wink
Being on: (in no order) VS BA AA EK CX MH DL EI BD KL HV NW RC LH AF DA TG QF US FR LX AC SK AZ PG SQ UA PA
Thai A330
Tue Aug 22, 2006 12:26 am
On Bangkok to Hong Kong sector, TG 606 normally operated by 743 but sometime they might switch to 744. There are only two 743 in TG fleet, HS-TGD and HS-TGE.
Hope this help. Have a nice trip..
keysman73
Tue Aug 22, 2006 12:36 am
Thanks...the connection you mentioned, VSFLYER, is the one I'm getting, so it looks like it might be tight!!
One further question - how do you go about getting access to flight information like that i.e. showing the times, equipment and seat availability?
Do you have to have access to a travel agents system, or is it something on the web?
Cheers.
Alan.
thaiaggie
Tue Aug 22, 2006 12:46 am
Next month? I heard that Thai will have some trial international flight from new Suvarnabhumi airport to HKG and SIN during beginning of September before the new airport officially opens on Sep 28.
50 minutes connection at old Don Meung should be fine. But check with TG and make sure you won't be flying in from LHR to Don Meung just to find out that your flight to HKG departs from Suvarnabhumi which is 2 hours away with bangkok traffic!
Barrow, Alaska in Feb. It was Cold!
Thai A330
Tue Aug 22, 2006 12:54 am
The trial international flight will be held on Sep 1 '06 departing Suvarnabhumi airport to HKG and SIN. This is only a '1 day' trial, I agreed with Thaiaggie, please check with TG just to make sure.
By the way driving from Don Muang to Suvarnabhumi will take around 1 hour or up 2 hours depends on traffic.
keysman73
Tue Aug 22, 2006 4:19 am
Thanks for all the info.
It's a big help.
Cheers.
Alan.
6thfreedom
Tue Aug 22, 2006 11:59 am
I wouldn't stress too much.
TG staff have been fantastic to me if there have been delays and tights connections.
last time made a connection to ICN with only 5 mins to spare.
was brought to door by TG cabin crew, met by ground staff, and rushed to awaiting plane for ICN. in the end, that aircraft was delayed 20 mins due to ATC.
not only did i make it, but due to the ICN delay, my bags made it as well!
N754PR
Tue Aug 22, 2006 2:12 pm
I thought the 744/743 is mostly on TG600/601 (along with the A346 on Tuesdays)
Bush, your a sad, sad man.
