pnqiad
Does This Happen Often? Directed Onto A Wrong Flt.
Tue Aug 22, 2006 10:38 am
A friend of my uncle is here in US for a conference and it is his first time in the US. He was to take flight out of ORD to CLE. He boarded a plane he was directed to. He was asleep before push back and on reaching the end of flight was surprised to find himself in HPN instead of CLE. UA shuttled him back to ORD and connected onwards to CLE.
Now was the gate agent who was directing passengers asleep at the wheel? I realized multiple planes probably leave from same general areas - esp. with express flights. I checked UA timetable and HPN and CLE flights do leave within 10 mins of each other in the morning. You would think with all the security issues, gate agents would be careful to see who is boarding which flights etc. no? Probably not a whole lot of security issue - but a royal screw up nonetheless...
wjcandee
RE: Does This Happen Often? Directed Onto A Wrong Flt.
Tue Aug 22, 2006 10:50 am
If you read that Plane Insanity book, there's a great anecdote along these lines in there.
Bottom line is that these days when they use autoscanners to take boarding passes, if they are using different jetways for different flights (i.e. not using one of those combined jetways or using a boarding door-to-bus-to-plane deal, or a walk-to-plane deal), the opportunity for this to happen is minimized. But it is one of those things that happens more often than you'd imagine. Which is one reason that sometimes you'll hear flight attendants announce very clearly where the plane is going before shutting the door.
FlyDeltaJets87
Tue Aug 22, 2006 10:59 am
There are several airports in the US with this type of setup. The Delta Connection terminal at CVG is like this. There are basically four gates (well, where you hand the gate agent the boarding pass anyway) at each corner of the terminal, which in turn serve about 20 gates each. They have electronic signs above each doorway, or "gate" at CVG with the flight # and destination, but if you weren't paying attention and were just following the crowd, you could get on the wrong plane. This isn't likely to be a security issue, but could very well turn into one, especially for the seperation from luggage deal. I mean, as far as the boarding computer knows, you boarded your plane, so the baggage handlers won't be pulling your luggage from the plane. Could provide the opporutunity to sneak a bomb on there. Who knows.
As for making sure passengers are on the right plane: the other day on my flight from CVG to GSO, the F/A made an annoucement saying "This is Comair flight 5072 from Cincinnati to Greensboro. Any passengers on board who are not traveling to Greensboro, please come forward at this time." In the times I've heard this annoucement, I've never seen anyone come forward.
"Let's Roll"- Todd Beamer, United Airlines Flight 93, Sept. 11, 2001
BreninTW
Tue Aug 22, 2006 11:09 am
A similar thing happened to me -- I was on my way to the south of Taiwan, and there were two flights (on the same airline) departing at more or less the same time to two different cities (KHH and TNN). My boarding pass said "Gate 9", so when they called the TNN flight, I got up and joined the queue boarding through gate 9.
I was seated and getting comfortable when an airline employee came up to me and asked me to identify myself ... turns out they'd changed the gate for the TNN flight to a bus (gate 9R), and I guess I didn't hear/understand the announcement. They took me off the plane and put me on the bus to the correct flight ... I guess they're used to dealing with foreigners who can't understand Chinese too well  Smile
Bren
litz
Tue Aug 22, 2006 11:53 am
AA used to (and might still) have RJ flights to Springfield, IL and Springfield, MO departing from the same gate and within 5 minutes of each other.
Being RJ flights @ STL, these are walk-down-the-stairs, across the tarmac to the plane in question (out of about 5 or so standing ready), type setups.
As you can imagine, this can cause quite a recipe for confusion !
On the way off my Springfield (Illinois version) flight a while back, I asked the FA how many people they sent back; she replied at least one a day.
And, mind you, this is despite the FA's repeatedly announcing WHICH state their particular flight is going to multiple times.
Maybe they just need big, huge signs tied to the boarding stairs for each plane's destination.
- litz
afay1
Tue Aug 22, 2006 12:44 pm
This has nearly happened to me several times, usually involving an apron with multiple identical turboprops and bad weather. We get down to the releasing area, several flights are boarding on the tarmac at once, and over the noise and the rain/sleet/snow, the directions to the plane get a bit jumbled. Has always sorted itself out though, but I can sure see how mistakes happen!
DYflyer
Wed Aug 23, 2006 3:44 am
A few years back i was returning from vacation on Rhodes. The gate-agents mixed up the busses to my flight going to OSL, and a flight going to either GOT or ARN (can't quite remember witch now). Obviously it was discovered before we had settled on the planes.
Life is like a book. If you don't travel, you only read one page.
usair320
Wed Aug 23, 2006 8:30 am
Quoting FlyDeltaJets87 (Reply 2):
Comair F/A's always do tis out of CVG for obviouse reasons.
sllevin
Wed Aug 23, 2006 8:40 am
I've only flown out of Comair's setup about 6 times, but three of those times I got to see someone staring and avoiding eye contact during the 'walk of shame' back to the front.
Steve
aircanada014
Wed Aug 23, 2006 9:29 am
I've been on so many flights alone and I can't understand how people managed to get on different flight. Its not that hard to figure out. When boarding they always mention the destination over PA system so how did the uncle couldn't hear the calling over the PA system?. Destination on boarding ticket is so visible I don't know how passenger agent didn't see that clearly.
FLYACYYZ
Wed Aug 23, 2006 9:34 am
There's the infamous story of the passenger travelling to Oakland, and would up on a flight to Auckland. Think LAX was the point of origin, assuming the folklore is true.
Above and Beyond
pnqiad
Wed Aug 23, 2006 9:36 am
Quoting AirCanada014 (Reply 9):
I am guessing this was the kind of area where multiple express flights leave without clearly designated gates like you would have for bigger jets with jetways. My uncle's friend actually went to an aircraft he was guided towards...
FLYACYYZ
Wed Aug 23, 2006 9:42 am
Quoting PNQIAD (Reply 11):
I agree with AC014. There has to be some major language barrier, or a mental comprehension problem. The destination is posted at the gate. The gate agent makes multiple references to the flight. While getting seated, I make at least two references to the flight number and destination, as well as a Captain's pre-departure announcement. Go figure.....
Above and Beyond
Boeing744
Wed Aug 23, 2006 10:29 am
I have never experienced something like this (luckily  Smile). However, I have been on a flight where the wrong destination was announced by the FO. We were holding for takeoff at YVR, on an AC Jazz flight YVR-YYJ. The FO came on and told us our flight time, altitude, and all that. At the end of her announcements, she said "Thank you for choosing AC Jazz, and enjoy the short flight to Vancouver". Pause... "Uh... that would be Victoria, sorry!". Needless to say, there were some startled looks throughout the cabin, even though we were already at YVR!  silly
N353SK
Wed Aug 23, 2006 10:55 am
It happens at MKE midwest connect pretty frequently. All of the flights board out of Gate D52 and there are at sometimes a dozen or more planes on the ground at once. Oftentimes somebody who isn't paying much attention will walk up to one of the BE1's when they're supposed to be going on an FRJ. Yeah genius, you're flying a beechcraft all the way to Hartford!
VHXLR8
Wed Aug 23, 2006 11:14 am
One would think that a very easy solution to this problem is to have the greeting F/A at the aircraft door check the boarding pass. We are required to do it at QF; yet i've never seen it done in the USA.
alphonze
Wed Aug 23, 2006 11:30 am
Quoting Boeing744 (Reply 13):
Hehe, that happened to me as well on the AA flight from LGW to RDU. The announcement (from an FA, not from the flightdeck) greeted us all onto "this flight to Dallas Fort-Worth", which caused a lot of muttering and uneasy shuffling around, until a correction was announced.
STT757
Wed Aug 23, 2006 12:37 pm
I was on board a PeoplExpress 737-100 from EWR to IAD, once airborne the Flight attendents started to collect the fares (they did this on board). The got to the gentleman across from me and when it came time for him to pay for his ticket is when it was discovered he wanted to go to Dallas but was on a flight to Dulles.
