thegregster
A380 V 744LCF
Thu Aug 24, 2006 5:34 am
I was thinking if you put seats in it and the technology of the 787/748
how would it compare/compete with the A380?
Could boeing learn from the problems Airbus have had?
With the Airframe and technology inplace could they be put together and how long would it take?
haggis79
RE: A380 V 744LCF
Thu Aug 24, 2006 5:56 am
well I guess you can answer that question by noting that Airbus developed the A380 from scratch instead of just putting seats in their Belugas....
300 310 319/20/21 332/3 343 AT4/7 143 B19 732/3/4/5/G/8/9 742/4 752/3 763/4 77E/W CR2/7/9 D95 E45/70 F50 F70 100 M11 M90
787engineer
RE: A380 V 744LCF
Thu Aug 24, 2006 6:10 am
This topic has already been discussed before, you can probably find it by doing a search. In short the 747LCF that ships the 787 fuselage sections is unpressurized. It would not be suitable for most cargo and definitely not for passengers. Considering it's shape it isn't the most aerodynamic (thus inefficient) and it would be very difficult to pressurize the LCF considering its shape. It's the only thing big enough to carry the 787 fuselage barrel sections so that is what Boeing will have to go with no matter how unaerodynamic it is (it's faster and probably cheaper overall than shipping by boat).
DfwRevolution
RE: A380 V 744LCF
Thu Aug 24, 2006 7:37 am
Quoting 787engineer (Reply 2):
Considering how expensive airplane components are, it is indeed more economical to ship by air.
The alternative involves an overhead of billions of dollars of equippment and people, continously in transit and essentially contributing nothing to overall productivity. For example, you want some sort of insurance when shipping fuselage barrels that cost several million dollars. Faster ship time means less insurance costs.
haggis79
RE: A380 V 744LCF
Thu Aug 24, 2006 7:59 am
I was always wondering if it is really a good idea to ship the sections of the A380 by ship and land from Hamburg to Toulouse as Airbus is doing at the moment... on the other hand, of course, there is no frighter large enough to put an A380 section in...
DL787932ER
RE: A380 V 744LCF
Thu Aug 24, 2006 9:08 am
Also keep in mind that the LCF modification added lots of space, but AFAIK didn't add to allowable MTOW. The 787 fuselage sections are big, but they are hollow tubes that are pretty low-density when you factor in all the air inside them. If you put two or three decks of seating inside an LCF, even assuming the structure itself could support the weight of passenger decks, you'd have a fuel capacity of about ten gallons before you were over MTOW.
Other posters also made valid points regarding the lack of pressurization and relative aerodynamic inefficiency (it was designed to be quick and cheap, not streamlined). The converted ships probably aren't certified in the transport category either. The biggest passenger Boeing will be the 747-8i at least until the Y3 days.
F L Y D E L T A J E T S
bohica
RE: A380 V 744LCF
Thu Aug 24, 2006 10:16 am
Quick question. Is the cockpit in the 747LCF pressurized? Thanks in advance.
brendows
RE: A380 V 744LCF
Thu Aug 24, 2006 10:21 am
Quoting Bohica (Reply 6):
Yes it is, they have built a new pressure bulkhead behind the cockpit.
bohica
RE: A380 V 744LCF
Thu Aug 24, 2006 10:48 am
Quoting Brendows (Reply 7):
Thanks.
Garri767
RE: A380 V 744LCF
Thu Aug 24, 2006 11:08 am
imho they look too much like each other
Photo © French Frogs AirSlides
Photo © Stephen Hsu
Garri767
Two wrongs may not make a right, but three lefts do!
