kaitak744
The Production Method Of A Burst Line
Sat Aug 26, 2006 7:56 am
Now, this is just a made up theory, so don't get too far down and technical.
To both Airbus and Boeing:
Both the upcoming 787 and A350 will be made in huge numbers, and the current production facilities won't be able to keep up. Boeing is considering building another line, but they are worried that their suppliers can't keep up, and that the orders won't come in this volume for too long. Here is an idea. It is what I call the "Burst Line"...
At Boeing's Everett site, there are 6 halls. (2 for 747, 1 for 777, 1 for 767, 1 for 787, and 1 spare). <- last time I checked.
The plan is that they build another building (say big enough for 3 whole lines), and use it for 787 production. This would easily handle the immense influx of orders the new aircraft would be getting. Now, after about 5 years, orders would come in at a slower pace, and they would close that line, and use only the 1 line in the main building for the 787. The now empty facility can be used for the initial burst of orders for the 797.
Hence, it is called the Burst Line, because that one assembly building would handle only a given aircraft type for a short while, (while there is a burst of orders). When orders die down for a given type, they can easily reconfigure the line for the next new aircraft and its burst of orders.
Anyone think this is a logical idea?
ptharris
RE: The Production Method Of A Burst Line
Sun Aug 27, 2006 3:04 am
Makes complete sense. But don't they still own the Long Beach plant as well? That leaves a vacant line plant once they have rolled out (unless they already have) the last of the 717 airframes. Re-tool and man the line down there and they will pick up the slack. That's assuming the line down there can handle the airframe size. Not sure it will since I don't know much about it. I have heard rumors up here of expansion of the Everett plant.. but really.. where else are they going to expand? Not much left of Everett beyond that point.  Wink
If at first you don't succeed, skydiving isn't for you.
planemaker
Sun Aug 27, 2006 3:28 am
Quoting Kaitak744 (Thread starter):
On the surface it might seem logical but your idea is not required. Renton has tons of space (if Boeing is still using that facility whenever the "797" goes into service... perhaps in 10 years).
You are forgetting that there will be more than enough space in Everett for increased 787 production when the 747 goes down to 1 line and the 767 line stops.
BTW, Boeing is out of the "facilities" business. They have gotten rid of tons of real estate and buildings throughout the Puget Sound. Furthermore, if the 787 is a "3-day" join, the "797" could very well be a "1-day join."
[Edited 2006-08-26 20:44:40]
Nationalism is an infantile disease. It is the measles of mankind. - A. Einstein
