SFORunner
AFX: Airbus To Build Additional Model Of A350
Mon Aug 28, 2006 4:35 pm
PARIS (AFX) - EADS unit Airbus, which said it would make three models of its A350 passenger jet when announcing a recent overhaul of its design, is planning an additional fourth model for long-haul flights, the daily La Tribune said, without citing sources.
The paper also said Airbus sources confirmed plans to build a cargo version of one of the models
http://www.hemscott.com/news/latest-news/item.do?newsId=35847944638916
ikramerica
RE: AFX: Airbus To Build Additional Model Of A350
Mon Aug 28, 2006 4:39 pm
Not news.
Proposed models are as follows according to many previous sources:
350-800
350-900
350-900LR
350-900F
350-1000
chiad
Mon Aug 28, 2006 4:48 pm
5 different models at lauch?!?
Is that possible?
zvezda
Mon Aug 28, 2006 5:11 pm
Quoting Chiad (Reply 2):
5 planned models at launch is possible. The planned chronological order is:
A350-900
A350-800
A350-1000
A350-900R
A350-900F
kc135topboom
Mon Aug 28, 2006 5:13 pm
Quoting Ikramerica (Reply 1):
Not news.
350-800
350-900
350-900LR
350-900F
350-1000
So, is the A-350-900F going to compete head to head with the B-777-200LRF? I thought the freighter version was going to be built off of the A-350-800 airframe, making it the A-350-800F? Any chance that Airbus actually make it the A-350-900LRF?
EI321
Mon Aug 28, 2006 5:46 pm
Quoting KC135TopBoom (Reply 4):
It would be wise for airbus to use the -900 length for the A350 freighter. Not only will this allow them to go after the 777F, but it also allows the A332F to have a larger share of the market and a longer production period, perhaps becoming the spiritual successor to the A300F
scbriml
I suspect it will be just plain -900F.
It will have the -900R's MTOW and engines, but range will be less (just like the 777F isn't a 777LRF because its range is a lot less than the 772LR).
astuteman
Mon Aug 28, 2006 5:59 pm
Not news.
Correct. Many threads on this already.
Probably worth linking this item from FI which covered most of the topic at the time. (25th July)
http://www.flightglobal.com/Articles...dth+-+A350+XWB+special+report.html
IIRC the 3 "base" PAX versions will be launched first. The A350-900R and A350F will come later (but planned from the start) and be based on the A350-1000 MTOW and engines (see article)
Not necessarily. It's a bit smaller (90t capacity vs 104t for thr LRF)
No, see article.
Quoting Scbriml (Reply 6):
Which will be based on the -1000's MTOW and engines  checkmark .
Users browsing this forum: 817Dreamliiner, alex0easy, Baidu [Spider], ChristopherS, cityairline, flyDTW1992, mat66, NZdsgnr, overcast, PJ01, PM, Qantas16, SyeaphanR and 198 guests
