Boeing7478i
Y3 Vs Airbus 380
Sun Sep 03, 2006 5:35 am
Will the Y3 ever compete with the A380? The A380 is an aircraft which can carry 550-850 pax and from what I've heard, the Y3 is most definitely not going to be a double decker like the 747 and 380. So how is boeing going to compete with airbus? Unless boeing makes a B797-8XXXXXWB, or an extra long B797-10000000 (which I very much doubt would happen), how will it have that kind of capacity? I think there would be more 747 variants after the -8intercontinental because I doubt boeing leave the whole VLA market for Airbus.
DLKAPA
RE: Y3 Vs Airbus 380
Sun Sep 03, 2006 5:37 am
How do you know how long any proposed 797 will be? How do you know they'll need that much stretch and not the original design? Your post gives more questions than answers.
In short, what are you talking about?
Boeing7478i
Sun Sep 03, 2006 5:42 am
Quoting DLKAPA (Reply 1):
1.It was meant to give more questions than answers.
2. I'm talking about Y3. Don't you know about The yellowstone project? Since the Y1 is being called 737RS, I thought the Y3 would be called 797.
zvezda
Sun Sep 03, 2006 5:44 am
Quoting Boeing7478i (Thread starter):
Simple, better dispatch reliability (twin vs quad), lower CASM, better range, lower trip costs, lower manufacturing costs, better cabin pressure, etc. It's not that difficult to produce a better airliner ten years later than the competition.  Yeah sure
ebj1248650
Sun Sep 03, 2006 5:45 am
Boeing doesn't appear to intend the Y3 to compete with the A380. It's intended to be a replacement for the 747 and the 777 so it's going to be a distinctive airplane that will effectively handle the types of flights made by the two aforementioned airplanes. Whether it will be a twin engine or four engine airplane remains to be seen and I suspect its size will depend on just what the user airlines want. I rather doubt it will be bigger than the 747-800 but believe it's apt to be somewhere between the 777 and 747. Then again it might have the 747-800's passenger capacity but would have a twin engine layout. Really remains to be seen at this stage.
Dare to dream; dream big!
AvObserver
Sun Sep 03, 2006 6:34 am
I think you're wrong about this. The -8 pretty much maxes out the 747's potential and will likely be the LAST 747 variant ever. Boeing would be better served by going to a new design after another 15-20 years, tops, assuming a higher capacity Y3 variant doesn't step in to fill the role. The 747-8 looks on paper to compete surprisingly well with the A388 but doesn't address the larger size niche Airbus will fill with the A380-900. Boeing will have to eventually design something all-new for this segment, which will grow in time. There's no way to further grow the 747 to handle 650-700+ seats.
Boeing7478i
Sun Sep 03, 2006 6:42 am
Quoting AvObserver (Reply 5):
But boeing never said anything about a Y4.
Gr8Circle
Sun Sep 03, 2006 6:59 am
Quoting Boeing7478i (Reply 6):
Does Beoing tell you all its secrets in advance....? Do share them with us .... Big grin
Gr8Circle
Sun Sep 03, 2006 7:02 am
Why do Boeing have to compete with everything that airbus spins out...? I thought that was Airbus' obsession Big grin
We don't even know if the 380 is going to be a success....I'm sure B will wait and watch the success (or f_ _ _ _ ) of 380 before doing anything....
Boeing7478i
Sun Sep 03, 2006 7:06 am
Quoting Gr8Circle (Reply 8):
Yeah, they did copy the 787 with their A350NSWB.
zvezda
Sun Sep 03, 2006 7:10 am
Quoting Boeing7478i (Reply 9):
I would say the A350 is more an (improved) copy of the B777 than of the B787. Regardless, to compete with the WhaleJet, Boeing need not produce an airliner the same size. Rather, Boeing need to produce an airliner with equal or better range, equal or smaller size, and lower CASM (including slot costs). That could be the B787-10.
hotelbravo
Sun Sep 03, 2006 7:17 am
Quoting Zvezda (Reply 10):
Agreed, but the fact is that, with a given set of technologies, the larger the aircraft the lower the CASM (assuming the plane is properly designed). So the 787-10 will always be vulnerable to being dethroned as CASM king by a larger aircraft.
zvezda
Sun Sep 03, 2006 7:39 am
Quoting Hotelbravo (Reply 11):
That's why it might be attractive to Boeing to build Y3. Anyway, every CASM leader is eventually dethroned. Interestingly, the A350, B787, B747-8, and WhaleJet will all have roughly similar CASM.
Adria
Sun Sep 03, 2006 7:59 am
Quoting Zvezda (Reply 12):
And your comment is based on what?
Exactly and the same goes for the 787 and 748 (although this one probably won't sell that good). Why this obsession whit "Y3"? let the 787 fly and in about 10-15 years who knows what the Y3 will look like.
lehpron
Sun Sep 03, 2006 8:12 am
Whenever whatever Y3 will be called comes out, it may more fill the gap between 777 and A380 than compete directly with A380 though the upper max of seating states as 600 pax:
http://content.answers.com/main/content/wp/en/1/13/BCA_Pax_Capacity.png
Quoting Boeing7478i (Reply 2):
Uh, no. Y1 and 737RS are two separate projects than share a common goal, i.e. they are not production names, not even like 7E7 was, RS meaning Replacement Study. There are many stages to decide to design an airplane. Having said that Y3 can be anything, and since 797 isn't officially assigned, no one knows for sure. But there are a lot of people who want a particular plane to be 797.
Quoting Gr8Circle (Reply 7):
Never and always are dangerous words; is it possible that Boeing/Airbus are not telling us everything, why should they? Companies have secrets to maintain an advantage from their competitors. Is it possible that there is always more to the story than what some of us here expect?
This is business, there are only two major players in the commercial aviation market. This isn't about spin or who's better at making airplanes.
Speaking of 737RS, what if Boeing determines that with available technology, it is not yet feasible to replace the 737?
[Edited 2006-09-03 01:13:07]
[Edited 2006-09-03 01:15:17]
baron95
Sun Sep 03, 2006 2:15 pm
I think Y3 can be a family a la A330/340 - a twin and a quad. I'd like to see a single deck, composite fuselage, bleedless engine, 3-isle 12 abreast 2-4-4-2, 300-400 passanger twin and 400-550 passanger quad in real world configs. The twin would use the largest GE-90NG engines, the quad the smallest. Length wise it will not have a problem fitting in an 80m box, but wing span will be a bitch - some form foldable wing tip or variable geometry or some mighty good winglet design plus very smart high lift design will be needed to keep wingspan in check. Will be quite a design though.
[Edited 2006-09-03 07:20:45]
[Edited 2006-09-03 07:22:19]
Killer Fleet: E190, 737-900ER, 777-300ER
columba
Sun Sep 03, 2006 2:22 pm
How can you compare an existing aircraft with one we don´t even know how it will look like ??
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
art
Sun Sep 03, 2006 2:36 pm
Quoting Adria (Reply 13):
Apart from some major, major manufacturing problem arising, I do not understand how the 787 could not be seen as a success. IMO it is already outstandingly successful well before EIS.
SpruceMoose
Sun Sep 03, 2006 3:00 pm
Quoting Baron95 (Reply 15):
If they can keep MTOW less than that of the A380, then presumably they can keep inside the A380's wingspan.
-SpruceMoose
It flew at an altitude of six feet for a distance of four and a half feet. Then we discovered rain makes it catch fire.
MCIGuy
Sun Sep 03, 2006 3:33 pm
I think Boeing will top themselves and the 777. I expect Y3 to be a "super-duper" twin.
BTW, I also expect it to come after the 737 replacement so it'd be more like an "808". Big grin
Airliners.net Moderator Team
baron95
Sun Sep 03, 2006 4:05 pm
Quoting SpruceMoose (Reply 18):
I was just taking into account that as a single decker/12-abreast it would have a much wider fuselage (by about 4 feet) with correspondently less wingspan to fit in the same box. I was also assuming that Boeing would like to keep wingspan to 744 dimentions for airport and hangar compatibility. Put those two together and we have challenging wing to design. I do expect the MTOW to be somewhat lower then the A380 for sure. The key question is, can all the versions be a twin? That would be awesome. A 500 passanger twin. Ouch.
zvezda
Sun Sep 03, 2006 4:10 pm
I'd say there's about a 0% chance of that. Y3, if built, will almost certainly be a twin.
That would require an interior cabin width of more than 300 inches. Even with an 84 inch cargo hold ceiling height (to accommodate full-height pallets), a circular fuselage of that size would provide at least a B767 worth of space in the crown. It would certainly be possible to put passenger seating only on the maindeck, but the crown would have ample space for the cockpit, crew rest, galleys, most lavs, passenger sleeping bunks, gate checked baggage, etc. Not having passenger seating upstairs means not needing emergency exits upstairs.
An 11 abreast Y3 should have a MTOW similar to that of the JumboJet. Wingspan would probably be in or close to the 70 to 75 meter range. Even the 2-4-4-2 design you suggest would have a MTOW similar to that of the WhaleJet and would not be terribly constrained by an 80 meter wing.
baron95
Sun Sep 03, 2006 4:32 pm
Quoting Zvezda (Reply 21):
Just like the 787 fuselage is not circular, I don't expect Y3 to be either. I think with very upright side walls, thinner wall structure, 17.5"seats and isles (remember with 3 isles they don't need to be that wide), even leaving out staggered seating, I'd say 280 inches external width is do-able. A horizontal oval (like Cessna's 400 series twins) with a vertical side wall would be very efficient. If you are going to use third-generation composites, you have to take advantage of complex fuselage shapes. A 75x75m design even if twin-engined with 125Klbs thrust should be good for some 450 passangers at 8000 nm.
zvezda
Sun Sep 03, 2006 5:04 pm
Quoting Baron95 (Reply 22):
That's 210 inches for seat bottoms, plus 32 inches for armrests, plus 54 inches for aisles, plus 4 inches for fuselage clearance is 300 inches of minimum interior cabin width -- with very narrow 18 inch aisles. How to put a 300 inch interior cabin width in a 280 inch exterior fuselage width is a trick I haven't learned yet.  Wink
Depends on what it weighs.
lehpron
Sun Sep 03, 2006 5:12 pm
The box is arbitrary, besides, can we go for the 113m diagonals? Such a plane should force new procedures for boarding.
Quoting Art (Reply 17):
Ah, "seen" as a success? How you and others see it doesn't matter until it is built and is stress tests like every other airplane before they actually go into service. Mind you, I'm not making a decision on the thing either way, however you and many others seem to be judging by orders alone.
Keep in mind though, 787 is a "product for an existing and well established market", it is a no brainer what kind of success awaits it. Note the latter; and BTW, 'not proven' does not equal 'will not work'
Rheinbote
Sun Sep 03, 2006 5:36 pm
Second that.  checkmark
baron95
Sun Sep 03, 2006 6:09 pm
Quoting Zvezda (Reply 23):
What armrests?  Smile We are talking the "friendly skies" here. Point well taken, though. I forgot the extra isle in the calculation.
zvezda
Sun Sep 03, 2006 7:20 pm
Quoting Baron95 (Reply 26):
Trust me, there is absolutely no way that a 2-4-4-2 configuration will have less than about 300 inches of interior cabin width. If Y3 were to have such a configuration (rather than 3-5-3) then Boeing would need to produce a B787-11X just to fill the gap between the B787-10 and the smallest Y3.
Molykote
Sun Sep 03, 2006 9:30 pm
A perfect index of a.net buzzwords!
(composite, bleedless, 3 aisle, GE-90, etc )
Speedtape - The aspirin of aviation!
Thorben
Sun Sep 03, 2006 9:57 pm
Quoting Lehpron (Reply 14):
This chart seems very ominous to me. 300-600 pax with one aircraft family? Doesn't seem very realistic, what kind of fuselage is that supposed to be? Airbus tried it with one fuselage for single isle and one for widebodies, but in both cases those at the ends of the length (A318/321 and A310/346) were the ones of which they sold the least.
France 1789; Eastern Germany 1989; Tunisia 2011; Egypt 2011
zvezda
Sun Sep 03, 2006 11:56 pm
Quoting Thorben (Reply 29):
I thought the same thing. The chart is not dated. I suspect it predates the B787-10.
jacobin777
Mon Sep 04, 2006 12:05 am
who says it will be the standard fuselage shape....the BWB concept has a lot of merit..as well as different thrust specifications...
"Up the Irons!"
AirbusA6
Mon Sep 04, 2006 1:25 am
By the same logic, the 777 is an improved copy of the A330!!!
I would imagine Y3 will replace the larger 777 derivatives and 747, leaving the 772 replacement market to 787-10 etc
One thought, at the moment most 747 sales now are for the freighter version, with it's unique opening nose and high cockpit giving benefits over competing aircraft. Would Y3 lose this advantage?
it's the bus to stansted (now renamed National Express a6 to ruin my username)
dw747400
Mon Sep 04, 2006 4:44 am
Quoting AirbusA6 (Reply 32):
I doubt the Y3 will retain a nose door, but I bet Boeing goes the extra mile to ensure it is still a very good freighter. I think freight operations will be a bigger part of their planning than it was with the A380--or even other Boeing models like the 777. Boeing has a commanding lead in the cargo market, and I think they'll try and keep it--even if it means sacrificing a small number of passenger orders.
CFI--Certfied Freakin Idiot
Thorben
Mon Sep 04, 2006 4:26 pm
I wonder whether this Y3 is really going to be built, Boeing will have the 787-10, the 77W, and the 747-8. I can't imagine they'll build something bigger than the 747-8 and I don't think they'll build a plane that replaces these planes that (except for the 77W) don't even exist.
zvezda
Mon Sep 04, 2006 5:05 pm
Quoting Thorben (Reply 34):
If Boeing can produce a Y3 with 20% lower CASM than the B787-10, A350-1000, B747-8 SuperJumbo, and the WhaleJet (and 30% lower than the B777-300ER), then it will make sense to build it.
