dank
AA RDU-LGW Back To 777 At The End Of October
Mon Sep 04, 2006 6:13 am
It looks like AA is going back to the 777 on the RDU-LGW route starting at the end of October (and keeping the second DFW-LGW flight on a 763). I assume they really route the 777s RDU-LGW-DFW and DFW-LGW-RDU?
cheers.
ikramerica
RE: AA RDU-LGW Back To 777 At The End Of October
Mon Sep 04, 2006 6:53 am
Could this be the SJC-NRT 777 availability being reassigned?
AirPacific747
Mon Sep 04, 2006 6:56 am
Quoting Ikramerica (Reply 1):
It does seem a bit excessive using a 777 on such a route to me.
chrisnh
Mon Sep 04, 2006 7:01 am
Quoting AirPacific747 (Reply 2):
especially coming after the typical 'high season' on such a route!
Chris in NH
MAH4546
Mon Sep 04, 2006 7:10 am
The reason is because AA was unable to find a way to upgrade DFW-LGW to 2x 777s without making RDU-LGW a 772. The original plan was taking the 777 from DFW-KIX and making the 2nd daily DFW-LGW flight a 772. However, this posed a problem, because it meant no way to get the 763 positioned for RDU-LGW. So AA then planned to have DFW-LGW operated with a 763 on Mondays only, which would then rotate exclusively between RDU and LGW for one week at a time. This prooved to be too complicated, especially with crew issues.
a.
dank
Mon Sep 04, 2006 7:13 am
I think that it is a reassignment of a 777 out of DFW. They drop the DFW-KIX flight on the 27th of October, which I believe is right when RDU-LGW switches back to a 777 (looking at the arrival/departure times in London, plus the longer stretch from Dallas, makes me assume that they share aircraft with the DFW flight, allowing them to rotate aircraft since RDU doesn't see any other 777s (or 767s when it is a 767, either, I believe).
Quoting ChrisNH (Reply 3):
Quoting AirPacific747 (Reply 2):It does seem a bit excessive using a 777 on such a route to me.
Chris in NH
I actually think that summer really is the low season on this route as O+D (and AA feels that the 777 could be used on a more in demand tourist route). There is a lot of triangle area-London business travel on this route, and I would assume late summer is lighter in that regard.
I know that a bunch of the pharmaceuticals (GSK in paritcular) guarantee business class seats on this flight. What about first? I only ask since this is one advantage of the AA 772s over the 763s...
Personally, I would rather have the 777 on this route, but that doesn'tnecessarilly make it good business sense  Wink.
This route is convenient for me. A nonstop flight, short check in and security. The whole customs and rechecking your bags even though you are ending up in Raleigh is a bit of a drag. Hopefully, the redone terminal will fix this.
cheers.
dank
Mon Sep 04, 2006 7:15 am
Quoting MAH4546 (Reply 4):
Thanks a bunch for your reply. Good to see that I was a bit on track with my guess. Works out better for me  Smile.
cheers.
Avion346
Mon Sep 04, 2006 8:33 am
Quoting Dank (Reply 5):
You hit the nail on the head...GlaxoSmithKline and others are the main reason for this route in general, let alone the business/first demand. They are definitely a premium customer for AA in RDU.
coerj
Mon Sep 04, 2006 11:09 am
How do the loads do on this flight? Beside the Business Class demand, how is first and coach doing. Is there alot of O/D? Any connecting flights, as RDU can be considered a small focus city for AA.
bond007
Mon Sep 04, 2006 11:20 am
Quoting Avion346 (Reply 7):
Correct, that's the only reason. There's no market reason other than those large pharma companies that obviously have a deal with AA on this route.
Jimbo
Sean-SAN-
Mon Sep 04, 2006 11:26 am
Don't forget AA also uses this as an AAdvantage relief valve... it's an easy way to get alot of people who want to use AA miles to London... which keeps ORD and DFW flights more open for revenue pax.
MAH4546
Mon Sep 04, 2006 11:37 am
Quoting Sean-SAN- (Reply 10):
Yes. During the winter, some days they get as many as 50-60 MIA-originating passengers on this flight.
a.
dank
Mon Sep 04, 2006 12:05 pm
Quoting COERJ (Reply 8):
When I've been on it, the loads weren't great in Y. And the great advantage of 2-5-2 seating has given me 2 1/2 seats to myself for coach fare  Smile.
 checkmark  I've been on flights from RDU to ORD on AA with connecting pax from LGW. They only get feed on the RDU end, I imagine, as this flight is not code shared by BA (but for some reason, I think it may have been at one time or was this route operated by BA before?).
cheers.
MAH4546
Mon Sep 04, 2006 12:17 pm
Quoting Dank (Reply 12):
BA and AA cannot codeshare on US-London flights.
On a side note, there is more connecting traffic at RDU on AA than most people think. One-third of American Eagle's RDU passengers are connecting. The majority between Miami and the Northeast, even though AA offers extensive Miami-Northeast non-stop service.
a.
dank
Mon Sep 04, 2006 12:23 pm
Quoting MAH4546 (Reply 13):
thanks.
cheers.
masseybrown
Mon Sep 04, 2006 1:13 pm
This doesn't give a class breakdown, but the British CAA gives the following pax counts:
2006
Month / Pax / Change from 2005
January 7,166 down 8%
February 5,576 down 6%
March 9,423 down 8%
April 10,353 up 3%
May 10,986 up 7%
June 12,132 up 3%
July 11,509 up 4%
If you assume a 245 pax 777, the load factor varies from 40.6% in Feb to 82.5% in June.
Humberside
Mon Sep 04, 2006 6:07 pm
Would AA ever consider doing a DFW-RDU-LGW (with DFW-RDU effectively to position an aircraft to RDU) or would that be more complicated than it sounds?
Visit the Air Humberside Website and Forum
commavia
Mon Sep 04, 2006 9:53 pm
Quoting Humberside (Reply 16):
Indeed, that schedule was used for several years in ~1998-2000 period, when RDU-LGW was being flown with 3-class 767-200s. The plane would fly LAX-DFW-RDU with a single flight number, and then it would fly RDU-LGW with a different flight number. It would then turn around the next day at LGW and do the reverse. However, once the route shifted to a 767-300 (then 3-class), and then ultimately the 777, they started routing the plane over LGW as part of the DFW-LGW schedule.
jfk777
Mon Sep 04, 2006 10:28 pm
AA use to fly RDU-CDG, this route must print money from the pharma companies if not AA would have killed it years ago.
ncflyer
Mon Sep 04, 2006 10:41 pm
An airline isn't in business to offer a flight as an AAdvantage relief valve. There is no constitutional requirement that AA or any airline offer free seats on any flight or to any destination (unfortunately). It may serve that purpose because RDU is too small to support such a large plane, but AA isn't flying such a large plane on the route unless there is a solid business reason.
bond007
Tue Sep 05, 2006 12:42 am
Quoting Ncflyer (Reply 19):
Yes, the fact that some pax are using the RDU flight for FF seats is not good news for AA ... the load factors for paying pax are obviously much lower than the MIA/DFW flights. Personally I'd like to see the real margins on this flight (but we never will of course), and understand how profitable (or not) this route really is. In my opinion the real figures might not be as bright as some might want to believe.
Jimbo
gman3
Tue Sep 05, 2006 12:46 am
I have always wanted to know where the FAs are based who do that trip. Does AA have a small base in RDU for that trip or is it assigned to other bases?
commavia
Tue Sep 05, 2006 1:22 am
Quoting Bond007 (Reply 20):
On the contrary, Raleigh/Durham-Gatwick serves its purpose perfectly. First off, the flight is profitable -- regardless of passenger sales or frequent flyer redemption, because large pharma companies based in the Research Triangle and/or the Greater London area (namely, GSK, etc.) basically subsidize the flight as a corporate shuttle and guarantee a level of front-end traffic to keep the plane flying every day. Secondly, by flying this flight, and using it for frequent flyer redemption, American is able to take pressure of other flights, namely Miami-Heathrow, and thus free up seats on that daily 777 flight for higher-yielding revenue traffic.
Quoting Gman3 (Reply 21):
Yes. AA has a small flight attendant base in Raleigh/Durham that handles only this single daily flight.
MAH4546
Tue Sep 05, 2006 1:36 am
Incorrect. Airlines often offer such flights as a relief valve and effective increases yield and profit on other routes. Offering a "loss leader" can sometimes increase profits on other routes to the same destination that the airline makes more money with the loss leader. A good example is AA's Dallas-Buenos Aires flight, whose primary purpose is to divert lower yielding traffic away from Miami and JFK. The flight makes a marginal profit, but it drives up JFK/MIA yields significantly.
a.
dank
Tue Sep 05, 2006 2:11 am
Quoting Commavia (Reply 22):
 checkmark  I would also assume that it encourages that GSK, etc. will continue to use AA for other flights since it won't open up competition for domestic service to other airlines that provide one stop service to the London area. And as you said, it helps increase yields on other London flights. It's important to note that it isn't just FF awards that get routed through RDU, but also cheaper airfare itineraries. For example, one couple I sat next to on an RDU-ORD flight were not traveling ORD-LON-ORD on an award but it was cheaper for them to fly through RDU. Does anybody know how the first/business fares differ for ORD-LHR from RDU-LGW?
I assume that the pilots are DFW based, though, right?
cheers.
gilesdavies
Tue Sep 05, 2006 2:22 am
Anyone know the load factors on the LGW-RDU route?
From what I have read in previous threads you can get a very comfy ride on this flight in Y and regularly you can get a whole row of seats to yourself?
Is this true?
MAH4546
Tue Sep 05, 2006 2:23 am
Quoting Dank (Reply 24):
The most expensive F fare, with zero restrictions, for AA's London flights are:
LAX-LHR: $14,054
MIA-LHR: $11,963
ORD-LHR: $11,663
BOS-LHR: $11,545
JFK-LHR: $11,324
RDU-LGW: $9,699
DFW-LGW:$7,896
a.
FlyPIJets
Tue Sep 05, 2006 2:49 am
I'm confused.
A quick check (date in Nov and Dec) of AA.com and the second (AA78/79) DFW-LGW shows as a 763. So if the point was to make DFW-LGW all T7, doesn't seem like that is happening. And if AA wanted the 763 on the RDU-LGW route couldn't they use the AA78/79 birds (or is that just one a/c and there isn't another 763 for the route DFW-LGW-RDU.....).
Rex Kramer: Get that finger out of your ear! You don't know where that finger's been!
MAH4546
Tue Sep 05, 2006 2:52 am
Quoting FlyPIJets (Reply 27):
They can't make DFW-LGW all-777 without making RDU-LGW a 777. However, if they make RDU-LGW a 777, then they can't make DFW-LGW all-777. They only have enough 777s to make two of their three Gatwick flights a 777. If RDU is that one flight made a 763, then there are complicated issues positioning the 763 to fly that route.
a.
dank
Tue Sep 05, 2006 3:01 am
I'm confused.
The way I see it is that DFW-LGW is 1 772 and 1 763. During the summer RDU-LGW was a 763 (but it was a 777 in the past). Because RDU sees neither a 763 or a 777 for any other regularly scheduled routes, the logical use (including timing is to share a 763 or a 772 with one of the DFW-LGW flights (these are the three flights that AA flies to LGW; and this allows them to rotate planes with the RDU flight without having to use a positioning flight between some other station and RDU).
AA freed up another 772 when they dropped DFW-KIX. They evidently wanted to add it to the second DFW-LGW flight, but that would have meant that there would be no 763 to rotate with the RDU-LGW flight (unless they tried 1x weekly using a 763 on the DFW-LGW flight, etc. and would entail more time on the ground at Gatwick for the RDU flight which gets in earlier, i believe than either DFW flight and leaves after the first return DFW flight). Essentially, this means that they have to have the RDU-LGW flight share planes with at least one of the DFW flights, so if both DFW flights were flown with a 772, then the RDU flight would have to as well and AA doesn't have enough 772s to spare to go with a 772 on all three, so it goes back to the same situation as last year, 1 772 and 1 763 running DFW-LGW and 1 772 running RDU-LGW.
Hope that helped.
Quoting MAH4546 (Reply 26):
thanks. i wonder if they are able to get more at the expensive end for first and business on the RDU flight (or better loads) which help offset lower yields in y?
Quoting Gilesdavies (Reply 25):
It is a good flight, in my experience, on the 777s in Y. PTVs and empty seats, particularly in the center sections (the 2s on the sides tended to be filled in my experience). Hopefully going to be flying this route more in the coming year, so I am happy to see it return to the 777s.
cheers.
MAH4546
Tue Sep 05, 2006 3:06 am
Quoting Dank (Reply 29):
No, they aren't.
a.
FlyPIJets
Tue Sep 05, 2006 3:12 am
Quoting MAH4546 (Reply 28):
Yeah, I step away from the computer a second and I get the problem. D-oh.
But, in some vague way, it does seem like AA could choose to send either a 763 or 777 on DFW-LGW-RDU-LGW-DFW and chooses the 777. Is that an indication of the route strength or just a function of fleet availability?
IOW - is the T7 on the RDU -LGW just there until AA finds a use for the DFW-KIX T7?
(I realize that would be a guess)
MAH4546
Tue Sep 05, 2006 3:20 am
Quoting FlyPIJets (Reply 31):
Combo of both. Fleet availability is the primary reason, as it best utilizes a 777. The fact that RDU-LGW promises premium and cargor revenue is another factor, of course.
a.
AJMIA
Tue Sep 05, 2006 4:21 am
Quoting MAH4546 (Reply 11):
Why don't they add a second daily MIA-LHR flight. We send sooo many people to LHR via RDU, JFK, BOS and ORD. I really think MIA could support the flight with no problems.
AJMIA
Lady it's a jet... not a kite.
commavia
Tue Sep 05, 2006 4:29 am
Quoting AJMIA (Reply 33):
They tried a double-daily MIA-LHR schedule. It eroded yields on the route. The schedule they have now, with a single daily flight and a second flight on Saturdays only, works perfectly. Besides, American would much rather dilute yielsd spread over many flights (and divert lower-yielding traffic onto a route like RDU-LGW) rather than dilute their very premium demand on MIA-LHR.
BigGSFO
Tue Sep 05, 2006 4:34 am
MIA-LHR operates non-stop twice on Saturdays - which I never really understood why only on Saturday. Perhaps an aircraft allocation or scheduling issue? In addition I wonder if AA has the available Heathrow slot to make a daily, second MIA-LHR successful.
MAH4546
Tue Sep 05, 2006 4:36 am
AA 56/57 is AA's second most profitable trans-Atlantic flight. They run a second frequency on Saturdays year-round and, during the winter, on Sundays as well. The second frequency was tried in winter 03/04, but it eroded yields.
Essentially, one daily flight is enough for the high-yielding traffic on AA (especially since BA is the favourite on MIA-LHR), and while a second flight is easy to fill, it steals connecting traffic that help fill other routes during the slow winter (RDU and BOS mainly).
[Edited 2006-09-04 21:36:42]
a.
BigGSFO
Tue Sep 05, 2006 4:57 am
Quoting Commavia (Reply 34):
Thanks.
Quoting MAH4546 (Reply 36):
What's #1?
MAH4546
Tue Sep 05, 2006 5:22 am
Quoting BigGSFO (Reply 37):
What's #1?
ORD-MAN, believe it or not.
a.
flflyguy
Tue Sep 05, 2006 6:39 am
My understanding is that the committments from GSK for business/first seats pay for the RDU-LGW flight. Anything we can book into Y is added gravy.
The views expressed are my own, and not necessarily those of my employer.
bnamaxx
Tue Sep 05, 2006 6:54 am
They're dropping this again? Is this seasonal or permanent? How many times does this make, twice at least.
dank
Tue Sep 05, 2006 7:31 am
Quoting Bnamaxx (Reply 40):
I believe that this is the second time, but it wasn't dropped the first time for seasonality. I think they started the route initially in the late 90s (maybe 1998?) and discontinued it after 9/11. It was started up again this year and was cancelled due to a lack of profitability. With JAL entering OneWorld over the new year, they can probably start feeding passengers through NRT on JAL.
cheers.
2travel2know
Tue Sep 05, 2006 7:46 am
If LGW-RDU is within a B757 range, Would AA ever consider flying that aircraft on that route?
I don't work for COPA Airlines!
gigneil
Tue Sep 05, 2006 8:07 am
A 757 wouldn't be able to offer the premium service the route demands without a subfleet.
N
dank
Tue Sep 05, 2006 8:37 am
Quoting Gigneil (Reply 43):
N
Correct. I believe that they use the domestic configured 757s for MAN and Ireland 757 services. Add in the cargo benefits to running a widebody on the route...
cheers.
MAH4546
Tue Sep 05, 2006 9:16 am
Quoting Dank (Reply 44):
Not for long. Both Europe 757 routes - BOS-SNN and BOS-MAN - are being discontinued.
a.
jfk777
Tue Sep 05, 2006 9:23 pm
The problem with some MIA-LHR-MIA was the time. MIA-LHR is fine. The second flight was earlier at 8:00am from LHR getting to MIA at 12:00 noon, too early for connections in LHR. The daily flights leaves at around 11:00 am getting to Miami at 2:30 pm.
bond007
Tue Sep 05, 2006 10:09 pm
Quoting FLFlyGuy (Reply 39):
I guess my question is...do we know this for a fact? How profitable is this route ... all things considered (crew positioning, maintenance, FA bases, etc.).
Do the pharma companies really pay enough up-front to subsidy the costs of the aircraft....even if Y is fairly empty (as many here say they have experienced?).
Hey, if it is...great for AA. I just assume the overall costs for this flight are more than the average AA 777 flight, so cannot be compared in the same light.
Jimbo
commavia
Tue Sep 05, 2006 10:22 pm
Quoting Bond007 (Reply 47):
Yes. As has been discussed at length many times here on A.net, AA doesn't stick around in any markets -- particularly international -- if they are not profitable. AA has no problems with yanking service from a route, even if they've served it for years, if they think the plane can be used more profitably somewhere else. RDU-LGW is still here, so obviously AA feels -- at least to date -- that the route is still sufficiently profitable to justify an entire 767 (or 777, apparently, come October).
"Crew positioning" and "FA bases" is not expensive at all, because the majority of the flight crew (all the FAs) fly Raleigh-Gatwick, overnight, and then fly back. Only one hotel stay on each round-trip, not two, as once they get back to Raleigh, their homes are their hotels. As for maintenance, this flight would not be any more costly than any other 777 flights, especially since the planes are rotated in each day from D/FW, which is American's largest line maintenance station.
Yes.
Maybe slightly more, but only slightly. There is some equipment cost that AA has in RDU for international flying that gets spread across only this single daily flight, whereas in other cities many flights can use it, but those costs are fairly minimal.
[Edited 2006-09-05 15:24:30]
fbm3rd
Tue Sep 05, 2006 10:40 pm
Why did AA stop MIA-LGW? I flew this back in summer 1998...
FM III
