leelaw
Next-Generation 737-900ER Takes Maiden Flight
Wed Sep 06, 2006 3:26 am
SEATTLE, Sept. 05, 2006 -- The newest member of the Boeing Next-Generation 737 airplane family took to the skies over Washington state Friday on its maiden flight. Painted in the Boeing blue-and-white livery, the 737-900ER (Extended Range) took off at 9:21 a.m. PDT from the Renton Municipal Airport in Renton, Wash. The first flight marks the beginning of a five-month flight test program to obtain certification of the airplane from the U.S. Federal Aviation Administration and the European Aviation Safety Agency by early 2007.
http://www.boeing.com/news/releases/2006/q3/060905b_pr.html
...During the flight, tests were carried out on the aircraft’s airworthiness, aerodynamic performance, stability and cruise performance. Flight controls, the autopilot, pressurisation, avionics, air conditioning systems and the flight management computer were also tested.
Two aircraft will be used for the flight test programme, accruing a combined total of 235h of flight testing and 210h of static ground testing.
Both test aircraft will be delivered next year to Lion Air, launch customer for the 737-900ER.
http://www.flightglobal.com/Articles...f+737-900ER%2c+extended+range.html
[Edited 2006-09-05 20:30:06]
Lex Ancilla Justitiae
Oykie
RE: Next-Generation 737-900ER Takes Maiden Flight
Wed Sep 06, 2006 3:32 am
Thank you for the update. I really hope the 737-900ER will do well!! It should be able to be produced in more than dear I say 250 examples. Boeing's own estimate is 200 over the next 20 years if IIRC
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
United787
Wed Sep 06, 2006 4:03 am
When Boeing says early 2007, does anyone know exactly when? Is that January or March?
solnabo
Wed Sep 06, 2006 4:25 am
The -900ER have the same fuselage as the rest of 737NG, exept for the extra fueltank?
Micke  wave
Airbus SAS - Love them both
Wed Sep 06, 2006 4:33 am
Quoting Solnabo (Reply 3):
Not just the fueltank - additional features are an additional pair of exit doors, a flat rear pressure bulkhead, a two-position tailskid, wing strengthening changes and enhancements to the leading and trailing edge flap systems.
jrosa
Wed Sep 06, 2006 7:37 am
What is this feature? What is it for? How does it work?
Do you know where I can see a photo of this two-position tailskid?
Vasu
Wed Sep 06, 2006 7:54 am
What's a flat rear pressure bulkhead?
Also, does anyone have a diagram showing the difference between the regular -900 and the -900ER?
PPVRA
Wed Sep 06, 2006 8:17 am
Quoting Vasu (Reply 6):
Go to page 7:
http://www.boeing.com/commercial/737...ily/737-900ER/pdf/presentation.pdf
Quoting Jrosa (Reply 5):
It's a feature to help protect the aircraft in case the pilot pulls up too much on take-off and the tail section strikes the runway. You can see it in the first picture the thread starter posted. I am not sure, however, what they mean by 2-point...?
Here is a picture of one on a B-29:
http://www.cybermodeler.net/aircraft/b-29/images/caf_b-29-02.jpg
"If goods do not cross borders, soldiers will" - Frederic Bastiat
socal
Wed Sep 06, 2006 11:47 am
Tight......I wish I was there.......
I Love HNL.............
aerobalance
Wed Sep 06, 2006 12:36 pm
Phat.....Wish I could have seen it.....
"Sing a song, play guitar, make it snappy..."
aerobalance
Wed Sep 06, 2006 12:42 pm
Phat....I wish I could have seen it!....
FL370
Thu Sep 07, 2006 12:02 am
looks pretty good, btw what does IIRC stand for?
N774UA
Thu Sep 07, 2006 12:06 am
If I Remember Correct(ly)
N774UA
...follow his instructions, switch off at the stand.
BCAInfoSys
Thu Sep 07, 2006 12:09 am
Quoting FL370 (Reply 11):
IIRC
If I Remember Correctly
Militant Agnostic - I don't know and you don't either.
Gr8Circle
Thu Sep 07, 2006 2:39 am
Quoting PPVRA (Reply 7):
The old B707-400 series used to have a similar thing under the tail end of the aircraft....I always wondered what it was......was this a 'tail skid'?
Photo © Peter Tancred
But the 707-300 series did not have it.....why was it dropped..?
Photo © Yrjö Mäkelä
b737700doctor
Thu Sep 07, 2006 3:11 am
Aft pressure bulkheads are generally round or domed shaped. But the B727 and DC-9 MD80 717 A/C all had flat aft pressure bulkheads but they also had pressure doors on the bulkhead the 737ER does not. I would imagine that the balkhead is flat to accommodate more seating. http://www.airliners.net/open.file/0703529/M/ http://www.airliners.net/open.file/1092758/M/
[Edited 2006-09-06 20:15:10]
Boeings are the best built planes
