B742
AA 757's With P&W's (ex TWA)
Wed Sep 06, 2006 7:46 am
As many of you already know, AA has a few 757-200's which are equiped with P&W engines rather than their majority of RR powered 757's.
The airline took these 757's when TWA was taken over by AA.
Are the aircraft based in any certain cities, or are they just randomly dotted around the AA network? I've seen a few at SAN and BWI in the past  Smile
I am due to fly BOS-MIA on an AA 752 in December, what are the chances I will receive a P&W 757?
Also are the cabins the same as the RR powered a/c?
I've read somewhere that the ex TWA 757's will be heading to DL (except one which is heading for Blue Panorama), is this true?
Photo © Carlos Borda
Photo © Jason Whitebird
Thanks in advance,
Rob!  wave
As smooth as silk
commavia
RE: AA 757's With P&W's (ex TWA)
Wed Sep 06, 2006 7:53 am
Quoting B742 (Thread starter):
They rotate through the system just like all other 757s without being distinguished, with a few exceptions because of operational considerations. Generally, though, when flying within the U.S., you could be on either a nAAtive or ex-TWA plane.
It's totally up to chance. Whatever plane happens to be flying into BOS that day or the day before. It could be either, but the odds are definitely in favor of it being a nAAtive plane, simply because AA has much, much more of them.
No. The seats are the TWA standard, although by now they may be recovered with the AA seat covers. Also, the TWA 757s have a mid-cabin lavatory, whereas the nAAtive 757s only have a lav at the front of First, one between First and Coach, and then a few at the back of Coach.
It is. As the these ex-TWA 757s come off their leases with AA in the next two years, they will be refurbished and sent to Delta. AA doesn't want to keep operating a tiny subfleet with non-standard equipment.
B742
Wed Sep 06, 2006 7:56 am
Commavia, thanks so much for the fast reply  Smile
Thanks for answering my questions so great also  Smile
Do the ex TWA birds have power ports also?
Quoting Commavia (Reply 1):
Wouldn't AA miss these 757's, or are multiple 738's enough to cover?
Rob!  wave
As smooth as silk
elmothehobo
Wed Sep 06, 2006 8:06 am
I've flown on three different ex-TWA 757s in Y, and none of the three had the AA seat covers. Might have been the luck of the draw.
Two out of three times on the ex-TWA 757s I was flying DFW-BWI, the other flight being LAX-DFW.
American doesn't rotate its ex-TWA 757s as freely as the "nAAtive" aircraft. These aircraft rarely appear out of MIA, JFK or BOS (on STL-MIA and the occasional DFW-MIA), nor do they appear on any of the transatlantic or flights to Hawaii. These aircraft mostly operate to and from Dallas and St. Louis.
There isn't that great a chance you'll end up on an ex-TWA aircraft on BOS-MIA. You can check on AA.com by going to the seat map of the aircraft and seeing whether or not there is an overwing exit (nAAtive aircraft) or rear cabin door (TWA aircraft).
boeing767mech
Wed Sep 06, 2006 8:21 am
There is about 99.99 percent chance it will not be a TWA 757, We haven't had a ex TWA 757 for at least 3 years in BOS.
David
BOS
Never under-estimate the predictably of stupidty
dartland
Wed Sep 06, 2006 8:36 am
Quoting ElmoTheHobo (Reply 3):
I believe that is because of crew requirements. From what I was told, the different exit door and cabin arrangement actually demands differently trained cabin crew. Not sure about cockpit crew (nor how much overlap there is in FAs trained for both).
B742
Thanks Guys  Smile
I will check the config, IIRC it was the overwing exit 752!
David, I am also travelling on the AA T7 from LHR, are these also rotated freely or does BOS tend to have the same range of 772's?
Rob!  wave
As smooth as silk
SLCUT2777
Wed Sep 06, 2006 10:13 am
DL uses the P&W engines on all of their 752s. I'm not sure about the exact numbers DL will be getting. I know at least 10 for now and possibly 5-7 more in year two I'm told. All of these were previously ETOPs certified while serving TWA, and AA mostly used them on domestic routes as pointed out in posts above. They will be refurbished for DL's use and DL will re-certify these for ETOPs since it can be done cheaply compared to their present fleet of 121 P&W powered 752s. They will then use these to "right-size" some of their Europe flights from JFK as TWA previously did, as well as bring back their SLC-KOA flight with a right-size in the equipment needed for such service.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
jacobin777
Wed Sep 06, 2006 10:35 am
I've flown on a bunch of ex-TWA 757's...I happen to like them more than AA's 757 for some reason...the exit row seatings are more spacious..and the tray tables are in the the front, rather than in the side..
my routes where I've gotten the ex-TWA 757's on ORD-SNA and some other routes..
I think this might be an ex-TWA 757...flew on it from DFW-JFK..but I'm not 100% sure..
"Up the Irons!"
elmothehobo
Wed Sep 06, 2006 11:55 am
Nope no power ports, which is why I learned to avoid them!
American is point to point routes (mostly out of Boston) to make up for the capacity lost at DFW because of the impending withdrawal of the ex-TWA 757s. American Airlines and American Eagle don't have any new aircraft scheduled to arrive in 2006, 2007 or 2008, so through then, we'll see a dip in capacity.
atrude777
Wed Sep 06, 2006 12:10 pm
No chance, all 757 BOS-MIA are scheduled as AA 757 and not ex TWA, sorry.
Nope, as others mentioned, gallery setting is different, the TWA 757's have more padding in their seats then the AA 757 do, and TWA seats in the 757 have 32 inches of pitch while AA's 757 have 31 inches of pitch.
Quoting B742 (Reply 2):
As said TWA did not have Power ports.
Quoting Jacobin777 (Reply 8):
That is an AA Bird, thats an RR Engine.
Alex
GQfluffy
Wed Sep 06, 2006 1:06 pm
Quoting B742 (Reply 6):
That means no ex-TWA 757....
This isn't where I parked my car...
777STL
Wed Sep 06, 2006 1:20 pm
They do seem to favor STL though. I've flown DFW-STL-DFW a number of times and when on a 757, it's always been an ex-TW 757. Could just be a coincidence, but they do circulate all over the domestic system.
Every ex-TW 757 I've had the pleasure of flying on lately has had the standard issue TW seat covers, Y and F. I'd venture to guess it isn't possible to re-cover TW seats with nAAtive covers due to the differences in the seat design.
That's true to an extent, DL has only taken 10 so far. A handful of ex-TW '57s have already left the fleet, gone to other airlines.
PHX based
jman40
Wed Sep 06, 2006 1:48 pm
I have a question about the difference in the ex-TWA 757s and the nAAtives (other than the engines). It is probably pretty basic to many of you, but I am new here and am curious:
I don't understand the why the exits differ between the two types. They are both -200s, right? It would seem to me that the structural differences between "typical" overwing emergency exits (like on a 737) and the large exits (like on a 777) would be significant. Is this an option that AA and TWA exercised differently, or was it a change in design?
I've always wondered about that.....
atrude777
Wed Sep 06, 2006 2:05 pm
Quoting Jman40 (Reply 13):
In the cockpit, TWA has the switches differently then AA's 757. Thats the first thing, so at first TWA pilots from the 757 could NOT fly on the AA 757 due to different configurements.
2nd, TWA requested a mid gallery with a Lav in the middle, thereby giving a bit more space and room to move around.
3rd, TWA requested PW engines, when AA went for RR.
So there quite a few obvious differences, and of course you have the regs ending in TW and etc etc.
Hope this answered it.
Alex
jacobin777
Wed Sep 06, 2006 2:37 pm
Quoting Atrude777 (Reply 10):
Thanks for the correction!  checkmark
"Up the Irons!"
kevindca
Wed Sep 06, 2006 2:51 pm
With the exception of the smaller overhead bins, the lack of power ports, and the almost complete lack of closets, I prefer the ex-TWA 757's over the AA version. It's possible to board the a/c at 2L easily because there aren't 2 seats in the way (9 B and C on the AA birds), and having the cabin broken up by the exits and lavs makes the plane seem more spacious, more of a wide-body feel I guess. I hope they see lots of life with their new owners!
Lucky42
Wed Sep 06, 2006 3:17 pm
You will notice that nw also has 2 different 757's they have pratt engines but the 55 series a/c have no over wing exits and the 56 series do.
SLCUT2777
Wed Sep 06, 2006 3:32 pm
Quoting KevinDCA (Reply 16):
DL is in dire need of more 752s like these former TWA birds and will put them to great use going from JFK to smaller less sizable Europe destinations, and from SLC and the west coast to OGG and KOA in Hawaii.
monorail
I don't think anyone has mentioned this yet. Another noticable difference (and another reason why I like the ex-TW birds) is the IFE. Ex-TW's still have drop down LCD's rather than the ceiling mounted televisions you'd find in the nAAtive 757s and 738s. It does make a difference if you're trying to watch the programming.
Playoffs? Don't talk about playoffs!
SLCUT2777
Wed Sep 06, 2006 3:47 pm
Quoting Monorail (Reply 19):
 checkmark
kevindca
Wed Sep 06, 2006 3:57 pm
Very true. Viewing the IFE on AA aircraft is especially difficult from the window seats thanks to the expanded overhead bins. You almost have to crane your neck to see the screen from some seats!
AAtakeMeAway
Thu Sep 07, 2006 12:20 am
Quoting 777STL (Reply 12):
I don't know if they are the same type of seats or not, but the ex-TWA Super 80s have been recovered, but the seats were not replaced. So, if the ex-TWA 757s and Super 80s have the same seats then it would have been possible to recover the seats on the 757s; they just chose not to because the subfleet wasn't going to be staying with AA long term. That's just my guess though  Smile
