atlflyer
Yellow Cabin Lights
Mon Sep 11, 2006 10:18 am
I flew to Miami last Thursday and back to Atlanta this morning on Air Tran, and I noticed that on both planes the light covers had turned a dark, unattractive yellow color. Parts of thel light cover looked ok, but the majority was a yellowish color. Does anyone know why lights on airplanes turn this particular color? Also, it seems to me that I only notice this on Boeing planes; Airbus seems to always have clean, white light.
EMBQA
RE: Yellow Cabin Lights
Mon Sep 11, 2006 10:25 am
For the same reason overhead florescent lights do the samething. The light effects the plastic and causes it to brittle and turn yellow.
[Edited 2006-09-11 03:25:55]
lincoln
Mon Sep 11, 2006 10:35 am
Quoting ATLflyer (Thread starter):
Quoting EMBQA (Reply 1):
More percisely, IIRC, it's the UV output of the lights which causes the plastic to change color as well as become more brittle. It also causes colored paper to fade (witness any display in a school/office building).
Lincoln
777wt
Either it's the heat from the light causing the plastic to turn that color or it's the plastic turning brittle as a result.
That happens to lamp covers in offices too.
atlflyer
Mon Sep 11, 2006 11:02 am
Then why does it only seem to happen on Boeing planes and not Airbus?
EMBQA
Mon Sep 11, 2006 11:17 am
Quoting ATLflyer (Reply 4):
The type of plastic used for the lens...
The age of the aircraft...
The type of bulb used...
Also, many newer aircraft are going the LED bulbs.
Quoting Lincoln (Reply 2):
Lincoln
Yup, I just didn't want to go that deep... but glad you added it.
warreng24
Mon Sep 11, 2006 11:47 am
It is correct.
Most aircraft use florescent lighting. Florsecent lighting is very common, cheap, and is very energy efficient (compared to incandescent lights).
However, florescent lighting provides a very large spectrum of light waves. Most are towards the upper end of the visible spectrum.
The florescent lights have a layer of phorphorus on the inside of the blub. This phorphorus flilters out all the wavelenghts that are above the visible light waves. This is mostly ultra-violet light. Sometimes as the bulb's age, the phorphporus ages as well, and allows a greater amount of ultra-violet light through.
Ultra-violet light adversely affects plastics. It clouds them, yellows them, and makes them brittle. Look at most car head lamps. The lenses are sometimes made of plastic. As the car ages (and is affected by ultra-violet light from the sun) the plastic will turn yellow or get cloudly. This is especially true of "clear" plastics.
The plastic resin used by Boeing's suppiler must be more supectiable to yellowing than the plastic resin used by the Airbus supplier.
On the other hand it may just by the bulbs. Warm White florescent bulbs produce a "warmer" more reddish-yellow light. Cool White florescent bulbs produce a "cool" more pure "white" light. AirTran (as the OP mentioned) might prefer using the Warm White bulbs.  Smile
As we move to LED based lighting, the yellowing of the plastic shouldn't occur as LED's emit a much narrower spectrum of light (more visible light and not as much ultra-violet).
Tod
Mon Sep 11, 2006 11:43 pm
Quoting Warreng24 (Reply 6):
Most operators chose warm white because they feel it makes that cabin appear less stark. CX is one of the few that go with cool white.
And the LED systems allow for ajdusting the color as required.
Tod
