axio
AirNZ 737 Emergency Landing At AKL
Tue Sep 12, 2006 6:05 am
http://tvnz.co.nz/view/page/411749/828589
I assume this was fairly recent given the lack of information.
Anybody at AKL have anything further?
There are a couple of cancellations from AKL on the AirNZ website as well (NZ415 to WLG, NZ517 to CHC). Are these related?
Time for a new viewing deck at AKL!
ZKOJH
RE: AirNZ 737 Emergency Landing At AKL
Tue Sep 12, 2006 7:24 am
happend this morning, 12 sep NZ time, NZ503 with 94 PAX on board, just read it at work
Vietnam time..
Freedom904
The report suggests it was an under carriage problem i would think the cancelation of the other flights were to check if there are anymore problems with the other 737's.
NZ560
Tue Sep 12, 2006 9:19 am
Quoting Axio (Thread starter):
According to One News. 4 other flights are affected. I would say this is due to the aircraft not being able to operate the flights. Any idea what the rego is?
-OJL RIP Also to the 7 onboard
nzrich
Tue Sep 12, 2006 10:04 am
I believe it the 737 300 ZK NGJ
"Pride of the pacific"
ZKNBX
Tue Sep 12, 2006 4:23 pm
3 News showed NGJ in the hanger... How did they put the fire out?
NZ1
Crew
Tue Sep 12, 2006 4:26 pm
Quoting Freedom904 (Reply 2):
I can assure you that it was a little more serious than a small undercarriage problem.
Quoting Nzrich (Reply 4):
Indeed it was NGJ
NZ1
NZ1
Head Forum Moderator
planemanofnz
Tue Sep 12, 2006 4:40 pm
3 News said that NZ had agreed to an interview but had later declined.
Apparantley there was a problem with the landing gear and the aircraft had to turn back to Auckland but once landed smoke started coming into the cabin from the cockpit. The P/A system was not working so the F/A had to manually tell everyone that they were evacuating via the emergency slides from the doors.
All of this was according to several witnessess who were interviewed on One news.
NZ560
Tue Sep 12, 2006 4:42 pm
Thanks for that.  Smile
Quoting NZ1 (Reply 6):
And I suppose you can not tell us a little bit more?  crossfingers
777ER
Crew
Tue Sep 12, 2006 4:43 pm
TVNZ reporter Cameron Bennett was on board the flight. He said "shortly after take off passengers were informed by cabin crew that there was a problem on board. At that point he says the plane made a low descent and headed back to Auckland Airport.
Bennet says the plane made a smooth landing, but the cabin began to fill with smoke as it was taxiing back to the gate.
At that point the captain decided to evacuate passengers and crew via chutes
http://tvnz.co.nz/view/page/411319/828589
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
ZKNBX
Tue Sep 12, 2006 4:52 pm
Electrical problem - PA not working + smoke on board... how did they put the fire out?
TG992
This would be correct.
NZ560
Tue Sep 12, 2006 4:54 pm
So this would of meant an over weight landing due to the 733 not being able to dump fuel? Because I have not heard in any reports about them flying around to burn off fuel.
NZ1
Crew
Tue Sep 12, 2006 5:10 pm
Quoting NZ560 (Reply 12):
No it wasn't overweight. The fuel load to CHC is only about 7200kg, max. Well below the max weight for the 733.
Quoting NZ560 (Reply 8):
Not at the moment, no. Ill wait and see what pans out at work tomorrow first. May be able to tell you a bit more tomorrow night.
NZ1
NZ1
777ER
Crew
Tue Sep 12, 2006 5:14 pm
I would rather land ASAP instead of flying around the dump fuel, maybe the fuel was dumped while heading back?
NZ1
Crew
Tue Sep 12, 2006 5:25 pm
Quoting 777ER (Reply 14):
The 737 does not have fuel jettison capability 777ER.
NZ1
NZ1
NZ560
Tue Sep 12, 2006 5:26 pm
Quoting NZ1 (Reply 13):
Thanks NZ1. Once again you are very helpful.  Smile
airnewzealand
Tue Sep 12, 2006 5:27 pm
Great they all got out, and the crew did their job well done!!!
Goes to show that we aernt their just to serve Food and drinks!!!!
NZ1
Crew
Tue Sep 12, 2006 5:33 pm
Quoting Airnewzealand (Reply 17):
Yes well done. With reading the trip report, OOR and what has been reported in the media, it seems they did an outstanding job.
NZ1
NZ1
zkeye
Wed Sep 13, 2006 6:10 pm
Any update NZ1? I know you may not be able to comment.
Bring out the gimp
NZ1
Crew
Fri Sep 15, 2006 5:04 pm
Quoting ZKEYE (Reply 19):
I can tell you that the root cause was an electrical fault with the Stand-By Power Relay. This caused the Ram-Air inlet doors to remain closed when the aircraft landed, which in turn overheated the packs, causing smoke to fill the cabin.
NZ1
NZ1
NZ560
Tue Sep 19, 2006 8:27 am
Very interesting. Thanks for that.  Smile
