danild
Pilot Goes For Xtra Flaps Seconds Before Landing
Thu Sep 14, 2006 11:27 pm
Hi all!
I came accross this very well made landing video of BA 777 YYZ-LHR and I noticed that seconds before landing the pilot seems to go for extra flaps. Or it sounds like it please let me know what that sound is before landing as it seems a little bit unusual that extra flaps would be aplied 2 seconds before touchdown specially on the T7 that seems to be a little slow to deploy.
http://www.flightlevel350.com/Aircra...h_Airways_Aviation_Video-6963.html
Danild
flyingbronco05
RE: Pilot Goes For Xtra Flaps Seconds Before Landing
Thu Sep 14, 2006 11:36 pm
That noise is associated with a pump. You heard it run before the flaps were extended and stops once the flaps are in their selected position, then you hear it again before the spoilers are deployed. You hear it once again as the spoilers are being retracted and once more when the flaps are being retracted.
Never Trust Your Fuel Gauge
MDorBust
Thu Sep 14, 2006 11:53 pm
The sound comes from pumps that are automatically activated at a pre determined altitude.
RE: What's This Noise On Landing In A 777 (by Bobster2 Aug 7 2006 in Tech Ops)
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
keego
Thu Sep 14, 2006 11:54 pm
Great Video! It sounds like the flaps and looking closley it does look like they move but I honestly dont know for sure! An interesting point is the aircraft landed on 09R which is very rare, only a couple of months ago there was a thread on take-offs from 09L and that they hardly ever occur. If the T7 was landing on 09R does that mean 09L was being used for T/O's?
Glareskin
Fri Sep 15, 2006 12:12 am
This seems like a typical T7 landing. A related question I've always have is if the flaps still only contribute to extra lift when deployed in the furthest position or if they also function as some kind of air brake.
Anyone having a good explanation for that?
Thanks.
There's still a long way to go before all the alliances deserve a star...
cle757
Fri Sep 15, 2006 12:15 am
Very cool video, I like the end where you can hear the flight attendant making the annoucements.
Cleveland the best location in the Nation
danild
Fri Sep 15, 2006 12:34 am
Thanks for your comments... I really was interesting to hear that pump... and I'm still puzzled on why it would be activated a couple of seconds before landing.
I also looved this video and another interesting point is how smooth that landing was... the little part between the flaps that moves (sorry I don't know what it's called) barely moves and I've landed on T7's before and that thing doesn't stop moving.
Thanks to all for the comments!
Danild
2H4
Fri Sep 15, 2006 1:39 am
Quoting Glareskin (Reply 4):
Typically, the first settings of flaps produce more lift than drag, while the lower settings produce more drag than lift.
2H4
Intentionally Left Blank
LHR27C
Fri Sep 15, 2006 2:12 am
Quoting Keego (Reply 3):
Before 7am both runways are used for landings due to the very high volume of inbound traffic.
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
B747-437B
Fri Sep 15, 2006 2:14 am
Mixed-mode operations are used during the morning arrivals peak with simultaneous approaches on both 09R and 09L. Departures are all on 09R though. The only time 09L is used for departures is during IROPs situations where aircraft have to be cleared quickly so as to not hit the night quota.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
Boeing747_600
Fri Sep 15, 2006 2:17 am
Quoting Danild (Reply 6):
those are the inboard ailerons. They make the small corrections that help maintain level flight. The outboard ailerons are furthur out on the trailing edge and are also used, although on some aircraft (I dont know about the T7) they are locked during cruise.
Ejazz
Fri Sep 15, 2006 2:56 am
At 30 feet on the B777-200 the Left and Right Hydraulic Demand Pumps and either the C1 or C2 Hydraulic Pump are commanded to run continuously, thats the noise you can hear.
Either C1 or C2 Pump is commanded on at gear down the other at 30 feet.
That is the flaperon between the flaps.
Etihad Girl, You're a great way to fly.
micstatic
Fri Sep 15, 2006 3:15 am
Cool video except that the author called it short finals. I hate when people call a short final, short finals.
S340,DH8,AT7,CR2/7,E135/45/170/190,319,320,717,732,733,734,735,737,738,744,752,762,763,764,772,M80,M90
Goldenshield
Fri Sep 15, 2006 3:46 am
Quoting Micstatic (Reply 12):
I totally agree, and have mentioned it before. Of course, English is a second language for many, so I can bend a little in that regard; however, for a native English speaker, saying, "That aircraft is on short finals approach," in colloquial use might be considered wierd, but in writing, it would be viewed as a poor grammar construct.
As far as the topic goes, the 9's are used all of the time; it's not 'rare' to use them.
danild
Fri Sep 15, 2006 4:01 am
Quoting Boeing747_600 (Reply 10):
Thanks for the clarification. It's good to know what a particular airplane part is called...
Danild
traineepilot
Fri Sep 15, 2006 4:20 am
Lower settings of flaps give you a considerable amount of extra lift with only a slight drag penalty. Thats why less flap is used on takeoff.
However, on landing, higher flap settings is used because yes, it gives a very good increase on lift, but as a penalty, you get a quite a lot of drag and on landing, you can use this to your advantage, hence, full flaps isnt used on takeoff.
There is no point explaining how flaps generate extra lift as it is not important here, but the only thing you need to know is the the full setting of flaps, you get a lot of drag and it also lower the stalling speed which, obviously is a good thing.
peterpuck
Fri Sep 15, 2006 4:21 am
They call it "finals" in England, where English is obviously the first language.
musapapaya
Fri Sep 15, 2006 4:22 am
I hate the dirty wings on this aircraft! Why cant they clean it more often? Wouldnt that be more efficient?
Lufthansa Group of Airlines
BOE773
Fri Sep 15, 2006 4:34 am
#3 spoiler panel did not go to full deflection on touch-down.
Got a minor prob there son. Pump less grease at those inbd and outbd flap track joints and center hinge on #5 spoiler panel. Clean the nipples off after greasing and you'll have a cleaner lookin wing. Yer starting to look like dirty AF planes.
philhyde
Fri Sep 15, 2006 4:35 am
In the thread linked above ("What's this noise...") they explain that the pumps are activated at a pre-determined height, which in this case is shortly before landing. The idea, I suppose, is that the hydraulic pressure needs of the aircraft will be higher after touchdown to operate things like spoilers, brakes, reversers, etc... There is enough hydraulic pressure to get things started but it needs to be maintained.
Canon junkie - Aviation Nut
danild
Fri Sep 15, 2006 4:40 am
Quoting Philhyde (Reply 19):
This makes a lot of sense!!!! Thanks for the answer!!!!
Daniel
Danild
robsawatsky
Fri Sep 15, 2006 4:46 am
Quoting Traineepilot (Reply 15):
Though be sure not to look for the answer in the typical school textbooks, they probably have it wrong.
traineepilot
Fri Sep 15, 2006 4:47 am
Quoting PeterPuck (Reply 16):
Please note we dont call it finals, the term 'finals' is normally used by people who don't fly. When I did my radio licence course (which in america they dont have for the PPL licence at least) we was taught that it is always 'final', not 'finals'.
traineepilot
Fri Sep 15, 2006 4:53 am
Quoting Musapapaya (Reply 17):
Yes, you are right. Having a clean and a wing that is polished reduces the boundary layer which in itself reduces drag and fuel burn.
KELPkid
Fri Sep 15, 2006 4:57 am
Quoting Traineepilot (Reply 22):
So do you all over there on the other side of the pond still do "bumps an circuits" and fly behind an "airscrew?" Big grin
traineepilot
Fri Sep 15, 2006 5:04 am
Quoting Robsawatsky (Reply 21):
Please note that I have just passed my aircraft technical exams relating this, and with 100% so im quite confident on the theory of lift and how flaps assist in this process at slow speeds.
traineepilot
Fri Sep 15, 2006 5:07 am
Quoting KELPkid (Reply 24):
From all the experience I have had from american aviation terminology, I find it hilarious how you get from A to B.
cumulus
Fri Sep 15, 2006 5:11 am
bumps an circuits
Circuits and Bumps!!!
What Goes Up Must Come Down, Hopefully In One Piece!
traineepilot
Fri Sep 15, 2006 5:14 am
Quoting Cumulus (Reply 27):
Please help me on this one, does that translate to touch n goes?
KELPkid
Fri Sep 15, 2006 5:18 am
Quoting Traineepilot (Reply 28):
That's affirmative. The late Bob Stevens (who wrote the "There I Was..." cartoon in Air Force magazine) had a hillarious comic back in the day on the (WWII-era) differenced between American and British aviation terminology (I believe it was titled "Pilot Prune vs. Roger Rudder").
traineepilot
Fri Sep 15, 2006 5:20 am
Quoting KELPkid (Reply 29):
HAHA, i love how people assume that because were british, we have a completely strange accent and terminology, lol. Id like to see that cartoon good buddy, cheerio old chap. Big grin
KELPkid
Fri Sep 15, 2006 5:23 am
Quoting Traineepilot (Reply 30):
Send me a PM, and I'll see if I can get you a scanned copy...my scanner wasn't working last week when I needed it  Sad
BOE773
Fri Sep 15, 2006 6:40 am
The spats on the alighting gear were being pulled along with the airscrew doing circuits and bumps on the aerodrome.
Hey, do you guys over there have to pay landing fees to land in farmer's fields?
You must be chocked by all that useless bureaucracy and cost to own and run a puddle jumper.
AirWillie6475
Fri Sep 15, 2006 7:58 am
The CRJ has this sound also and it comes on when the flaps and spoliers are being used.
socalfive
Fri Sep 15, 2006 8:05 am
It's actually quite simple, Flaps increase wing area, increased wing area= more lift, more lift=slower stall speeds, slats and flaps increase total wing area.
traineepilot
Fri Sep 15, 2006 8:06 am
Quoting BOE773 (Reply 32):
I wouldn't be surprised knowing what government we have. I heard in America, landing fees at reasonably small airports is small or non-existant. Here, landing fees are a nightmare.
mpdpilot
Fri Sep 15, 2006 8:38 am
I have always been told that flaps are used on landing to provide you with a steeper approach without the gain in airspeed is this correct?
Quoting Socalfive (Reply 34):
Flaps also change the camber of the wing which I think is where most of the new lift comes from. The flaps are also shaped like wings and do a lot more than just increasing the wing area. flaps also change the stall characteristics of the airplane to prevent them.
One mile of highway gets you one mile, one mile of runway gets you anywhere.
boo25
Fri Sep 15, 2006 9:25 am
Yeuch, i work for BA, and we have standard announcements - which you can add a bit to, if it sounds professional - - that was totally tacky, obviously loves the sound of her own voice and just too casual, CRINGE.............
Obviously worked in a bingo hall before............................
BOE773
Fri Sep 15, 2006 10:34 am
Quoting Traineepilot (Reply 35):
I honestly feel sorry for you folk over there saddled with the high cost of private flying. That whole bureaucratic quagmire needs to be turfed out and start off with a clean sheet. What are IAOPA doing, if anything, to lower the cost of private aviation?
Anyway, sorry for the divergence from the original topic.
Now would some of you rerun that video of the 77 and tell me why #3
spoiler board is not fully extended at touch-down and initial roll-out.
FlyboySMF2GFK
Fri Sep 15, 2006 10:53 am
Quoting MPDPilot (Reply 36):
It depends on which type of flap you're talking about. Fowlers increase camber and surface area. Plain and slotted flaps increase camber but not so much on the surface area (unless it's combined with a Fowler). Split flaps increase camber and surface area, but also have more of a drag penalty versus a lift benefit.
Fowler flaps:
Photo © Soetkin Vandecandelaere
Split flaps:
Photo © Mark Carlisle
Plain (some might say slotted) flaps:
Photo © Eric Patrick
Slotted Fowler flaps:
Photo © David James Clelford
Goldenshield
Fri Sep 15, 2006 11:05 am
Quoting FlyboySMF2GFK (Reply 39):
This has been brought up before in the tech forum. Cessnas have a flap that for the first few degrees acts as a fowler by moving out an inch or so, then drops sharply. During that process, a slot forms between the flap and wing.
FlyboySMF2GFK
Fri Sep 15, 2006 11:10 am
Quoting Goldenshield (Reply 40):
Right, not intimately familiar with Cessnas, but the Pipers I've flown are considered (just barely) slotted.
FlyDeltaJets
Fri Sep 15, 2006 12:16 pm
For a minute i thought I was looking at an AF 777
Very informative thread.
The only valid opinions are those based in facts
BOE773
Fri Sep 15, 2006 12:38 pm
It amazes me that a fairly modern wing such as the 777 has, uses a dozen VGs (Vortex Generators) along its outbd surface.
Hopefully an Engineer corrected that #3 spoiler panel that did not fully extend.
tristanhnl
Fri Sep 15, 2006 1:25 pm
Quoting Ejazz (Reply 11):
To add a little bit of input, yes, that part between the two sets of flaps is called the flaperon. Boeing was innovative in turning this inboard aileron also into a flap during landing (flap + aileron = flaperon). Previously designed aircraft such as the 767 have inboard ailerons that serve only as an aileron.
Along with the rudder on the vertical stablilizer, ailerons help turn a plane. But my guess is that on short final, when there is not too many major turns going on, that flaperon then functions as a flap to help add more drag on the wing. However if it is very windy during landing and the plane is getting jostled around, the flaperon serves as an aileron to make adjustments to maintain level flight, as Boeing 747-600 described. This is the reason why on one 777 flight you may notice the flaperon is lowered and stays still until touchdown (smoother air), and on another flight it's constantly twitching up and down (rougher air).
Hong Kong: truly Asia's world city!
KFLLCFII
Fri Sep 15, 2006 3:30 pm
Quoting BOE773 (Reply 43):
Photo © Vector Grafix
Photo © Benny Bartels
Photo © Sam Chui
Appears to be the correct position for that particular spoiler...
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
Geo772
Fri Sep 15, 2006 4:00 pm
Quoting KFLLCFII (Reply 45):
Not #3 spoiler at all, it was number 4.
The #4 spoiler is a bit different to the rest of the 'flight' spoilers on the 777 in so much as if all the flight control computers go seriously wrong spoilers 4 and 11 are cable operated to provide roll control. I don't think this has ever happened for real but is practised on the simulator.
Flown on A300B4/600,A319/20/21,A332/3,A343,B727,B732/3/4/5/6/7/8,B741/2/4,B752/3,B762/3,B772/3,DC10,L1011-200,VC10,MD80,
sevenforeseven
Fri Sep 15, 2006 5:10 pm
Fly by wire, Airbus were the pioneers.
thunder9
Fri Sep 15, 2006 5:46 pm
Quoting Sevenforeseven (Reply 47):
Actually, I believe that General Dynamics was the pioneer in that field with their relatively successful F-16 family of aircraft.  spin
-J
"Keep thy airspeed up, less the earth come from below and smite thee." - William Kershner
cumulus
Fri Sep 15, 2006 5:50 pm
Quoting Traineepilot (Reply 25):
Rumbling a 777 onto the tarmac at LHR is a far cry from pottering around the place in a C172 (or whatever you're learning in).
[Edited 2006-09-15 10:54:57]
