SInGAPORE_AIR
Lufthansa First A380 Delayed From Jan-> Summer '08
Fri Sep 15, 2006 7:54 pm
Lufthansa said it won't get its first superjumbo until the summer of 2008, rather than January of that year as expected.
Now, Lufthansa has only been assured of getting one plane in 2008, Stefan
Schaffrath, a spokesman, said in a telephone interview today.
He declined to give a month for the delivery or the start of operations, saying only it would be in the "summer.''
"We'll still be the first in Europe to use the A380,'' Schaffrath said.
More at Bloomberg
Lufthansa is a Member of Star Alliance - The Airline Network for Earth, and KrisFlyer - the Frequent Flyer Programme from Singapore Airlines Limited.
manni
RE: Lufthansa First A380 Delayed From Jan-> Summer '08
Fri Sep 15, 2006 8:37 pm
Before anyone jumps to conclusions, such as Turner was right, the article dates from september 4th.
Also,
"The carrier, Europe's second-biggest, after Air France-KLM Group, had originally expected to receive the first of 15 A380s on order at the end of 2007."
Looks to me in line, with the 6 month delay announced 3 months ago. LH expects to take delivery, roughly half a year later than planned.
(the end of 2007 includes 31/12/07 and the summer of 2008 starts at 21/06/08)
SUPPORT THE LEBANESE CIVILIANS
JAAlbert
Fri Sep 15, 2006 11:45 pm
So what sorta route does an airline use just one plane on? I imagine using one aircraft on a long haul route will be very inefficient in terms of staffing.
For instance, say LH 738 flies the A380 FRA to HKG on Monday. On Tuesday,LH 738 flies the route using a 747. Tuesday, LH 739 flies the 380 back to FRA with a fresh 380 crew while Monday's crew continues its layover. On Wednesday LH 738 flies the 380 back to HKG with a fresh 380 crew. On Thursday, LH 739 flies the 380 back to FRA with Monday's 380 crew. On Friday LH 738 goes out with Tuesday's crew and the cycle repeats. Meanwhile the same cycle is repeating with the 747 crew. So it looks like an extra crew is required to maintain the route with only one jet and the airline is forced to give the crew a layover with an extra day.
Can the cabin crew switch between A380s and 747s or is the entire crew dedicated to only one aircraft type?
Is such a staffing issue a problem for an airline?
Gr8Circle
Sat Sep 16, 2006 12:20 am
So, apart from SQ, QF and EK, who else is slated to receive 380's in 2007?
Quoting JAAlbert (Reply 2):
I definitely think that should be possible.....of course, pilots will not be able to switch.....
airbazar
Sat Sep 16, 2006 12:23 am
Just about any trans-Atlantic route they feel could use the A380. Most likely JFK.
mspguy
Sat Sep 16, 2006 2:21 pm
 checkmark
someone did a good job at their homework!!!!!!
If it ain't broke, DON'T touch it!!!!
Lp0815
Sat Sep 16, 2006 3:52 pm
Quoting Singapore_Air (Thread starter):
LH is NOT a member of KrisFlyer.
While it is correct that KrisFlyer members can accrue and redeem mileage on LH flights, LH maintains its own FF program "Miles & More".
Time waits for nobody
SInGAPORE_AIR
Sat Sep 16, 2006 3:56 pm
Quoting Lp0815 (Reply 6):
Who are you?
zvezda
Sat Sep 16, 2006 4:46 pm
In the case of LH, probably FRA-ORD or FRA-IAD.
Quoting Gr8Circle (Reply 3):
It's looking like only SQ have a good chance of receiving any WhaleJets in 2007.
Lp0815
Sat Sep 16, 2006 8:46 pm
Quoting Singapore_Air (Reply 7):
Who are you?
What has this got to do with my post?
Send me a PM if you want details
SInGAPORE_AIR
Sat Sep 16, 2006 8:48 pm
I don't think I can as I am not a first Class Member. But if you send me a blank e-mail through my profile I will reply immediately.
Lumberton
Sat Sep 16, 2006 8:58 pm
Quoting Singapore_Air (Reply 10):
I'm not either, but I frequently use the IM feature.
"When all is said and done, more will be said than done".
