SR800
Departures On R/W 09L At LHR?
Wed Sep 20, 2006 4:57 pm
Are there any LHR experts out there who can let me know if 09L at LHR has ever been used for departures...even back in the 1970s / 80s (when it was 10L)?
I have travelled through / visited LHR 00s of times, but have never seen it being used for departures, so just thought I'd ask the question.
Feroze
RE: Departures On R/W 09L At LHR?
Wed Sep 20, 2006 7:42 pm
The Cranford Agreement prevents 09L departures except in emergencies:
Departing aircraft normally do not use the northern runway on easterly operations due to the Cranford Agreement. This is an oral agreement between the Government and the residents of Cranford which has existed since the mid-1950s.
This agreement was designed to protect the residents of Cranford, which is very close to the eastern end of the northern runway, from the high noise levels experienced on the ground from departing aircraft which are at low altitudes over Cranford. However, overflight is permitted when necessary, for example when the southern runway is closed, e.g for maintenance works
http://www.heathrowairport.com/porta...9e58532010VgnVCM100000147e120a____
g) The Cranford Agreement (as it applies today)
29.This is a 1950s undertaking to avoid easterly take-offs from the northern runway (09L) over Cranford when ever possible. Until the main runways were extended westward in the 1960s Cranford was the nearest residential area to the airport situated under the approach and departure tracks. It is not a written agreement, but is understood to have been a "best endeavour" undertaking given at a public meeting in 1952. The main effect of the restriction is to require take-offs to use the southern runway (09R) during easterly operations, which in turn means that most easterly landings must overfly Windsor and Poyle to use the northern runway (09L), thereby precluding runway alternation during easterly operations in the daytime.
http://www.dft.gov.uk/stellent/group...s/page/dft_aviation_503451-03.hcsp
[Edited 2006-09-20 12:43:52]
silverfox
Wed Sep 20, 2006 8:48 pm
In recent years the only departures i have seen on it was Concorde, until some work was done so it could use 09R
I go back to visiting LHR since 1960 (not a mistype!!!) and cannot recall any t/o from 09L(10L)
Ron
EZYAirbus
Wed Sep 20, 2006 9:02 pm
Ive seen departures off of 09L for about an hour in 2004 when i was working at British Airways, apart from then, never seen it
http://www.glenneldridgeaviation.com
Bellerophon
Wed Sep 20, 2006 9:32 pm
SR800
I've flown several departures from 09L in the last five or so years, due to 09R either being closed, or being too rough when resurfacing work was in progress, however, in general terms, Feroze is correct.
09L is not used for departures, unless there is no viable alternative runway available.
Bellerophon
dalb777
Thu Sep 21, 2006 1:38 am
Any problem with 27R for landing? Aircraft fly over the same neighborhood when landing on 27R as they do when taking off from 9L. My guess is that landings are a little quieter than takeoffs, so they don't create as much as a problem???
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
UAL777UK
Thu Sep 21, 2006 5:29 am
Quoting Dalb777 (Reply 5):
No problems for landings at all, their cannot be for the reasons stated above, the take off's will be on 9R.
planesarecool
Thu Sep 21, 2006 6:37 am
9L was often for departures while the end of 9R was being resurfaced. Many aircraft which would have used up a lot of the runway used 9L as 9R had been shortened by quite a lot due to the work. On the last sunday before the Concorde retirement, I saw 5 other aircraft use 9L, an Emirates B777-300, a Singapore B747-400, Virgin A340-600, Thai B747-400 and Virgin B747-400. All 6 departures (inc. Concorde), made sharp turns straight after departure.
B747-437B
Thu Sep 21, 2006 5:42 pm
9L is periodically used for departures as well when there is a big backlog of flights due to depart before the night quota kicks in - they sometimes launch 2-3 of those off 9L simultaneously with 9R to clean things up before they turn into pumpkins.
"The A340-300 may boast a long range, but the A340 is underpowered" -- Robert Milton, CEO - Air Canada
