jr
How Is DL (Connection) Doing On LGA-DFW
Thu Sep 21, 2006 1:26 am
Flew on the DL connection route from DFW to LGA and back this weekend. The flights had about 25-30 empty seats in each direction. How is this route doing for DL? Is it expected to stay for the long run? With all the JFK expansion are there any plans of a possible DFW-JFK route addition or maybe even a move of the LGA route to JFK?
Thanks.
I've flown on 9V-SPK.
28thguy
RE: How Is DL (Connection) Doing On LGA-DFW
Thu Sep 21, 2006 7:32 am
I don't know LGA-DFW is doing, but I'd bet a dollar that it would be discontinued if AA dropped LGA-ATL.
akizidy214
Thu Sep 21, 2006 8:03 am
Its kind of hard to compete when AA has 15 daily departures and Delta has 3. Also don't forget about CO with there 6 daily departures to EWR. I don't think this route will be around much longer for Delta. On the JFK situation look for B6 to try JFK-DFW before delta. They are just waiting, for the final decision on the wright amendment.
DCA
worldtraveler
Thu Sep 21, 2006 8:12 am
AA already flies JFK-DFW which makes it even less attractive for DL or B6.
The point of both DL's ORDLGA and LGADFW service as well as AA's ATLLGA service is so both carriers can serve the top 10 markets from LGA. DL is using E170s on both AA hub flights while AA has a mix of RJs and mainline so neither airline is spending a whole lot of resources on the service. From a strategic standpoint, it's probably worth it for both carriers.
jfklganyc
Thu Sep 21, 2006 8:15 am
"I don't know LGA-DFW is doing, but I'd bet a dollar that it would be discontinued if AA dropped LGA-ATL."
AA will not be dropping that route anytime soon. LGA-ATL is a cash cow. The flights are always, always full. They even upgraded some of the Eagle flights to MD 80s.
As for DL doing LGA-DFW 3x a day, even when DFW was a hub, DL had mailine service 4x a day on the route.
I am quite surprised that DL doesn't have 2 a day to JFK.
PJ
akizidy214
Thu Sep 21, 2006 8:24 am
Quoting JFKLGANYC (Reply 4):
AA isn't doing that well on this route. Sometimes MD 80's only have 40-50 passengers. But I agree they will not discontinue the route.
[Edited 2006-09-21 01:28:48]
DCA
LGA777
Thu Sep 21, 2006 9:25 am
I am sure the folks who work at DL LGA probably wish it would go away. I don't think operator Shuttle America is doing a great job on on time performance, and DL's LGA Terminal is often short on gates. The 170 parks on a regular jetway gate, whereas the Comair CRJ-700's and smaller park on the hardstand. Because of the frequent delays it is not uncommon, in fact almost routine for a 757 to be holding for the gate the 170 is on to open up ! At least the ORD 170's are out of the way at the Marine Air Terminal, a smart move I believe on DL's part !
LGA777
Cubsrule
Thu Sep 21, 2006 10:04 am
If l/fs are any indication, the ORD flights are doing fairly well. If DL can do all right there with far less frequency, the lack of frequency to DFW might not be as much of a handicap as we think.
MAH4546
Thu Sep 21, 2006 10:08 am
The flights do well, but it is not a "cash cow" and they haven't upgraded anything. It has been 3x mainline/2x Eagle since launch.
a.
luv2fly
Thu Sep 21, 2006 10:21 am
Quoting WorldTraveler (Reply 3):
Yes it is that thinking that lead them into bankruptcy! Run a flight because it makes you money, not because another carrier is flying into your precious hub.
SESGDL
Thu Sep 21, 2006 10:41 am
Quoting Jr (Thread starter):
I wouldn't be at all surprised to see a JFK-DFW with an E-170 or CRJ-700 in the next year or so, to connect with the European flights. It would leave JFK at 6-7pm and leave DFW the next day at 11-12:00n or so, getting into NYC in time for all the European flights. It would probably be smart to shift aircraft from one of the LGA-DFW flights in order to reduce the ground time of the plane. We'll see though.
Jeremy
S5FA170
Thu Sep 21, 2006 10:45 am
Shuttle America's on-time performance is right up there with Comair, ASA and SkyWest. Our performance is not any better or any worse than their's is. Everytime I have worked a DFW<->LGA flight we have been on-time. The only time I have ever been delayed on that route was when a ramper at DFW disconnected ground-power from our aircraft before our captain told us to, and the aircraft's computers shut-down because of it.
-Tony
Prepare doors for departure and cross-check.
DILF
Thu Sep 21, 2006 11:37 am
For what it's worth, I flew this route on Shuttle America/Delta Connection RT once and was very, very impressed with both the crew and aircraft. The flight down was about 60% or so full, but the return was a good deal more than that.
Great service - and tho that was my only experience with S5, i'd say they certainly have their act together! If only it were poss for S5 to replace Messy within the DL system !!!
NO MORE Trip Reports about SQ First Class! Or TG, CX or MH! E-N-O-U-G-H !!
Ex NWA
Thu Sep 21, 2006 12:28 pm
I'll be doing Shuttle America DFW-MCO Friday 9/22 in the AM. I will post a trip report to let you know my thoughts
N839MH
Thu Sep 21, 2006 3:12 pm
As for DFW-LGA....Shuttle America has been pathetic....their ontime performance is awfull, the delays and cancellations...unbelievable!!!!
Half the time S5 doesn't have a clue on whats going on and when there
flights will leave NY or arrive in DFW. Since they have been flying
LGA-DFW-LGA they have only been able to muster a 39.4% load factor
for 24 weeks of service!
Solution: One morning flight MCO-DFW-LGA (E170)
One morning flight DFW-JFK (MD88 or B738)
One morning flight LGA-DFW-MCO (E170)
The last flight of the night DFW-LGA...get rid of that flight. It has a ontime
percentage in the low 20%, with a load factor of 39.4% for the first 24 weeks.
S5 is just not dependable or reliable to offer customer service for which Delta is trying to provide!
Solodude!
panamair
Thu Sep 21, 2006 3:17 pm
Quoting N839mh (Reply 14):
It is not S5's responsibility to market and sell the flight; they are contracted to do the flying. It is Delta's responsibility to improve the loads.
