Adam727
Boeing 737-300 Question
Thu Sep 21, 2006 9:37 am
Ok this may seem like a dumb question but here is goes.
What is the Tire Pressure of a boeing 737-300?
futurecaptain
RE: Boeing 737-300 Question
Thu Sep 21, 2006 11:15 am
Google search seems to indicate it is 181 psi.
rootsair
Fri Sep 22, 2006 4:15 pm
Quoting Adam727 (Thread starter):
is that for some research you ae doing ?
A man without the knowledge of his past history,culture and origins is like a tree without roots
Tristarsteve
Fri Sep 22, 2006 6:02 pm
We use 185psi main and 165 psi nose.
Each airline will set its own pressure depending on MTOW, but it will be around these figures.
Boeing publish a chart showing the tyre pressure for each take off weight and you pick the pressure that correlates to your own MTOW so you dont have to change them all the time.
